Preventing major failures
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco terror, Apr 6, 2013.
  1. Apr 6, 2013 at 9:33 PM
    taco terror
    taco terror [OP] 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    So is there a link to this? Searching turns up nada.
    I am wondering what major things should be checked/replaced so that they do not fail in the future and cause catastrophic damage. I have read that it is recomended to buy a new radiator as to not get the "pink milkshake." This is the stuff I am talking about
    Is there a link to a list of this stuff?
    How to check ball joints?
    What other crap needs to be done so something real bad dosen't happen?
  2. Apr 6, 2013 at 10:07 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I am at 120K and considering my truck is a highway commuter and I put nearly 171 miles a day, yes that number is correct, on it almost 3 times to week, maintenance is crucial so I do not get stranded. I just had a MAJOR service done to the truck, and this is what I did. The truck is payed off so even though it was pricey, it's still cheaper to maintain a used truck than to go out and buy a $30K new Tacoma.
    New:
    Timing Belt
    Water Pump
    All tensioner pulleys
    Cam seal
    Crank seal
    All belts
    Thermostat
    Fuel Filter
    Resealed rear main axel seal, fresh fluid
    Resealed oil pain seal
    Transmission flush
    Throttle body and injector system cleaning
    New Denso spark plugs/wires
    Complete radiator and engine block flush with fresh Toyota coolant
    New front pads, rotors, new brake fluid
    New Michelin AT2s, road forced wheel balanced
    I am probably missing something, but those are the major ones I can remember off the top of my head.
  3. Apr 6, 2013 at 10:16 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    When you do the timing belt might as well do the water pump and thermostat while you're at it. If you haven't done the coolant in awhile you could do that also since some will drain out anyways with doing the water pump. Keep up with oil changes and check the oil and the oil's smell and appearance to make sure you limit the build up of burnt oil on engine internals. Good advice is that a small leak, will eventually, turn into a bigger leak... Happened on my '88. Keep your tires balanced and aligned properly and rotate your tires. Do routine maintenance you should be fine.
  4. Apr 6, 2013 at 10:17 PM
    taco terror
    North Carolina
    Nice :thumbsup:
    I definitely need to do a lot of that, I just thought that recently I have read some pretty scary stuff. I've been seeing a lot about how there is a possibility for one small part to fail causing a lot of damage to a certain area.
  5. Apr 6, 2013 at 10:21 PM
    taco terror
    North Carolina
    Yeah I will do all that stuff when it comes time for the timing belt to be replaced.
    I wasn't so much talking about oil changes or small maintainence, I have always changed my oil every 3,000 and bought the expensive filter.
  6. Apr 6, 2013 at 10:23 PM
    Yamaha Dave
    THIS. Also get in the habit of popping open your hood and especially getting underneath your truck during the day and look for obvious signs of wear, leaking, damage etc... This is when you may catch a small problem before it compounds into something major, or better to catch it in your driveway than on the side of the highway at midnight.
  7. Apr 6, 2013 at 10:28 PM
    tacobell007
    Drew
    Western MA
    I was just saying that checking the oil you could catch a head gasket going or another issue and burnt oil left on internals can cause damage, but you seem like you shouldn't have to worry about that. I mean there are a couple sensors in the engine that if they throw a code you should replace sooner then later, like the knock sensor as an example.
  8. Apr 6, 2013 at 10:39 PM
    taco terror
    North Carolina
    Yeah, I do think my coolant is going somewhere. Reservoir is empty but there aren't signs of it dripping on the floor, and there is no water in my oil.:notsure:
    Yep, my O2 sensor threw one last year. Started my truck before school one morning and my check engine light was on, scared the crap out of me. I never wait if there is a sign of trouble to get something taken care of.
  9. Apr 6, 2013 at 10:57 PM
    tacobell007
    Drew
    Western MA
    I would have reset the ECM first before replacing the O2 sensor, but thats just me :eek: For the coolant, does your truck get up to the proper place for normal operating temperature?
  10. Apr 6, 2013 at 11:03 PM
    taco terror
    North Carolina
    My scanguage usually reads 186~188 (needle slightly below half) when shes fully warmed up. I can see a little coolant at the top of the radiator, its like none is ever in the res though.
  11. Apr 6, 2013 at 11:26 PM
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    Preventing major failuresimages_2fa8d91d14c7e46ce64551473990294de31bd6ef.jpg
  12. Apr 7, 2013 at 1:14 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Aside from fluids and fluid filters on their recommended intervals, the timing belt and water pump cover cleaning are the biggest thing (every 90k miles). Well, spark plugs could go out of gap and the spark plug wires apparently need changing from time to time. Air filter..... obviously. At 200-250k I'd like to change the pistons, gaskets and internal seals. But that may not be necessary.
    Luckily we aren't driving 4Runners, which need new radiators around 100k miles, or they started cross contaminating coolant and ATF....
  13. Apr 7, 2013 at 8:35 AM
    tacobell007
    Drew
    Western MA
    I would say top off the radiator and reservoir and then watch the level and see if it falls
  14. Apr 7, 2013 at 8:47 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You may have a pinhole leak in the upper part of the coolant system (hose or radiator). That would vent steam all the time, and not drip liquid. Happened to me once. Right after driving it, take a look and try to locate (or hear) the steam venting.
    The catastrophic failure that worries me the most, involve the lower ball joints. That could cause a serious accident. Most other items mentioned (outside the timing belt) would just cause the truck to run poorly.
  15. Apr 7, 2013 at 8:54 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Saw the pic of the condom and the thread title on the home page. I lol'd
  16. Apr 7, 2013 at 9:56 AM
    taco terror
    North Carolina
    That is actually one of the problems I was talking about. I have read that Tacomas can do it too
  17. Apr 8, 2013 at 6:10 PM
    x2468
    Im 99% sure it's not a tacoma issue. Although we use the same engine and trans, we don't have the same radiator. When i researched this in 4runner forums, a few different people said the issue doesn't effect tacomas. I've also never seen it raised as an issue on tacoma forums.
  18. Apr 9, 2013 at 11:21 PM
    RGosen
    RGosen Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    The big one most seem to overlook is the valve shims in the RZ motors. As the exhaust side gets to tight and you end up burning valves and then your getting in deep for cost. I just had mine checked and the right sise put in as they get to tight over time
  19. Apr 11, 2013 at 1:56 PM
    BigOly
    BigOly Well-Known Member
    Bay Area, NorCal
    14 MGM DCSB TRD/OR 4x4
    I agree 100%, I have the exact same mentality and is pretty much the main reason why I went with a used 1st gen VS. a spankin new 2nd gen. Now if $ wasn't an issue.....ehhhhh...well I probably would still keep my 1st gen. :p
