Prewired" backup camera 2008 taco ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Jul 9, 2016.
  1. Jul 9, 2016 at 10:51 AM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Is my 2008 Sr5 prewired ? If I wanted to add a backup camera how would I do it ? Any answer or link appreciated. Thanks in advance.
  2. Jul 9, 2016 at 10:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Start by looking in the tailgate area. Is there a harness that goes into the gate?
    Or just pull the tailgate liner off. The wire with a connector should be there to receive a camera plug if it is prewired. If it is take a very clear pic of the plug, so if you shop for a used or eBay camera, you can be sure to get the right one.
    If it is prewired, you should also have a harness plug somewhere over the mirror area. And you'll need the correct mirror for the harness. There are different mirrors that will have various combinations of functions, but suspect if you are prewired, you'd be able to run any correct mirror and get full function.
  3. Jul 9, 2016 at 11:16 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I don't think the camera option was available until either 2009 or 2012, so I don't think our 08's are prewired for it.
  4. Jul 9, 2016 at 12:50 PM
    george3
    New Jersey
    Thanks for taking the time to post all this information. I'll check it out.
  5. Jul 9, 2016 at 12:53 PM
    george3
    New Jersey
    U R probably correct - thanks for your input. I was hoping it would be easy. How hard would it be to install ??
  6. Jul 9, 2016 at 1:03 PM
    Fiend13
    Chad
    There was a guy on here who added it all to his.
    https://www.tacomaworld.com/threads/09-style-backup-camera-on-an-08-complete.20202/
    A lot of it is just running wires and mounting the camera where you want it. And if you want it on an aftermarket radio or the oem style mirror. If you with the mirror then you'll need to get the mirror and run the cable up the A-pillar and over to the mirror under the headliner. If for the radio then run the wire from under the driver seat and under the center console and up to the radio from behind.
  7. Jul 9, 2016 at 1:15 PM
    george3
    New Jersey
    Wow ! Thanks 4 the link. I did a search but didn't C it. Wonder how U fish wire thru the headliner without making a mess ? Thanks again. You guys on TW are the best.
  8. Jul 9, 2016 at 1:24 PM
    Fiend13
    Chad
    You'll have to remove the A-pillar to run the wire behind it. I think its just 2 bolts and then it pops off. Once off you should be able to tug on the headliner to pop it undone just enough to run the liner. Never removed a headliner before but I think it's just snapped in for the most part. Not positive though.
  9. Jul 9, 2016 at 1:46 PM
    george3
    New Jersey
    Thanks. I've never done it either. I do 99% of work on my Taco but never this.
  10. Jul 9, 2016 at 5:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    For the headliner you only need to have the leading edge pryed down a bit (not undone) to tuck the wire.
    I have my SCII above my mirror. I used a plastic bike tire tool to manipulate the headliner while I fed the cable across. Easy peasy.
  11. Jul 9, 2016 at 6:19 PM
    george3
    New Jersey
    Thanks for the input - Appreciated it.
  12. Jul 9, 2016 at 8:01 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    This is so awesome, I was just getting ready to ask the same thing because Im looking into buying another Tacoma and its a 2008. Thanks for the info guys
