PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Oct 28, 2014 at 9:08 PM
    #981
    ThomasMore66
    Dallas/Fort Worth & Durango
    Drill a hole and fill with what? I live in TX. It rains. Sometimes in a big way.
  2. Oct 28, 2014 at 9:13 PM
    #982
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Oct 28, 2014 at 9:18 PM
    #983
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I haven't ever done it or even researched it. I know lots of guys do it though. I get rain and snow here so it is just as big of a concern for me. This thread on ih8mud popped up on google and seems to have good results. Sure there is more than one way to do it.
    Check out this post further down. he used heyco water tight fittings. Looks really clean.
  4. Oct 29, 2014 at 2:15 AM
    #984
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    I've been under the impression of running the ligh bar wire down the side of the windshield to under the hood then run the switch wires threw the firewall into the cab. Seems legit
    Codyfish likes this.
  5. Oct 29, 2014 at 5:03 AM
    #985
    ThomasMore66
    Good to see others have thought about this too. I like the marine connector idea, but I was staring at my windshield this am wondering about running wires down the gap between the windshield and the post. Holes in the roof do seem wrong, but I have the XM antenna poking through the back of the cab where Toyota installed it.
  6. Oct 29, 2014 at 5:21 AM
    #986
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Hmmh similar to what I had in mind..Was thinking of actually fitting the light bar below the fairing and side mounting it to the actual rails and obliviously shorten the fairing. I'll hold tight until yours is installed and fitted with a light bar. And your right Heretic makes some killer, very detailed light bars indeed! Thats what your orange washers reminded me of them..Very good work and cant wait to see everything installed!
  7. Oct 29, 2014 at 5:26 AM
    #987
    Smiley52
    Smiley52 Insta: @Sm1ley52
    Danny
    Melbourne, FL
    2012 SR5 4x4
    :blahblah:
  8. Oct 29, 2014 at 6:17 AM
    #988
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    I have the same idea but my idea would need more area and different shape at the front most area of the side rails
    I'm slowly putting thoughts into action. Not much free time right now
  9. Oct 29, 2014 at 6:24 AM
    #989
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Yeah the configurations with the rack are almost endless. So many different ways you could adapt a light bar :goingcrazy:
  10. Oct 29, 2014 at 6:31 AM
    #990
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    Truth. Plus I have a 42" curved waiting to be install so there's a differance from the straight bar
  11. Oct 29, 2014 at 6:48 AM
    #991
    ThomasMore66
    So what was your plan on running the wires off the roof? I like to have a plan...execute the plan...
  12. Oct 29, 2014 at 6:49 AM
    #992
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This. I couldn't drill into the roof :eek:
  13. Oct 29, 2014 at 6:58 AM
    #993
    ThomasMore66
    Got a pic of this? Need a cleaver method for installing and keeping it all nice and tight in there. Clearly that little gap is large enough for a few wires. I installed an Ultragauge above my mirror and I couldn't believe how much room was behind the front interior post. My plan is to buy a sPod and run the wiring up to the overhead console. Just haven't had time to get it all together, but now I've seen this rack with the light and it's calling to me. That's a slick set-up. Do I need a roof-mounted light bar...
  14. Oct 29, 2014 at 7:36 AM
    #994
    OZ-T
    Peter North
    British Columbia
    I wonder if you could remove the satellite antenna and replace it with the marine bulkhead
    ready6delta likes this.
  15. Oct 29, 2014 at 8:52 AM
    #995
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Zach that this is awesome. Quick question, how much higher does the sides go compaired to the cross bars?
  16. Oct 29, 2014 at 9:00 AM
    #996
    zscott
    Zach
    Utah
    Maybe a 1/4 of an inch. Just enough to give the ends of the crossbars a decent load bearing surface. If you need something taller I will have a bolt on kit that adds a basket type rail around the sides soon.
  17. Oct 29, 2014 at 2:02 PM
    #997
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    I did and it was fine,I just used a lot of silicone
  18. Oct 29, 2014 at 2:05 PM
    #998
    OZ-T
    Peter North
    British Columbia
    Silicone tends to be a temporary waterproofing solution at least in my experience
  19. Oct 29, 2014 at 2:38 PM
    #999
    zscott
    Zach
    Utah
    I think it depends on the type, it seems that quality/composition varies greatly, although I don't have a ton of experience with waterproofing though. What are some alternatives you have used?
  20. Oct 29, 2014 at 4:01 PM
    #1000
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    Probably so, I'll keep my eye on it... there is probably a better way to do it... when I had it run in front of my windshield along the "weather stripping" it always went everywhere at high speeds so I got impatient and Jimmy rigged it by drilling
