PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Nov 18, 2014 at 6:58 PM
    #1141
    TheGreatPear
    TheGreatPear Well-Known Member
    Alex
    Gunsan, South Korea
    2013 DCSB TRD OR 4x4 V6 6 Speed
    Gotcha. You'll probably see an email from me soon!
    Just to be certain, Your toprack will bolt up to Yakima tracks correct? I'm planning on throwing a toprack on my ARE shell and want to be sure I'm getting the correct tracks.
    Thanks
  2. Nov 18, 2014 at 7:14 PM
    #1142
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Does make sense. I have an axe and shovel in my bed held with fist grips and they do sometimes twist or slide a little. If you google shovel mount rack and even google image it should give you some more ideas. Here's a quick one I found http://www.rockcreek.com/yakima-rac...Yakima+Racks&gclid=CP_VkoHZhcICFWUF7Aodh0EAlQ
  3. Nov 18, 2014 at 7:42 PM
    #1143
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    That is correct. Just need to know the width between the tacks when you order to get the right width of crossbars.
  4. Nov 18, 2014 at 7:50 PM
    #1144
    TheGreatPear
    Alex
    Gunsan, South Korea
    Cool so ill just need to get my tracks mounted on prior to ordering.
  5. Nov 18, 2014 at 8:26 PM
    #1145
    zscott
    Zach
    Utah
    Or order the ideal width of rack that will match the cab and then have them install the tracks to match.
  6. Nov 18, 2014 at 8:27 PM
    #1146
    zscott
    Zach
    Utah
    this is a common failure with Quick fists, MSO has theirs on top of the rack so the shovel sits flat and doesn't twist. One option if you have a short shovel with the end handle is to mount it like I did on my trailer. No twisting allowed this way.
  7. Nov 19, 2014 at 3:42 PM
    #1147
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    That's actually a great idea
  8. Nov 19, 2014 at 6:35 PM
    #1148
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Oh shit ...that's brilliant and I am a moron for not thinking of it :)
  9. Nov 20, 2014 at 7:40 PM
    #1149
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Zach, just curious, what are the measurements with your 30" light bar, from the edge of the deflector near the light to that outside edge where it slops down?
  10. Nov 22, 2014 at 2:24 PM
    #1150
    I3uller
    I3uller Well-Known Member
    Too far South
    I know there aren't too many photos of the long bed cab rac out there so I finally got a few pictures of the rack with the new basket add on in case anyone wanted to see it. Very impressed with Zach's product and would highly recommend it to anyone. Extremely modular and solid. I'll have some more photos up soon of it with some stuff mounted to it.
  11. Nov 23, 2014 at 3:55 AM
    #1151
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    What is the point of having the rack higher on only one end?
  12. Nov 23, 2014 at 5:41 AM
    #1152
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    My guess is to keep things from sliding, or to create a slightly raised secondary surface for storing objects above longer items?
  13. Nov 23, 2014 at 3:51 PM
    #1153
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Which cross bars are these? It looks like there are 2 t-slots on top, 2 on bottom and 1 on each end. Is that correct? I may have to order some of those.
    Nate
  14. Nov 23, 2014 at 4:07 PM
    #1154
    zscott
    Zach
    Utah
    ^^^^^^ I got an email from TSLOTS a couple days ago saying that various profiles will now be available in black anodized. Unfortunately most of them are larger. 1.5" x 3", 3" x 3", etc. Nothing applicable to these racks really other than what I already offer.
  15. Nov 23, 2014 at 6:50 PM
    #1155
    ThomasMore66
    Dallas/Fort Worth & Durango
    Which cross bars do you have? Can you run a RTT on this rack?
  16. Nov 23, 2014 at 7:36 PM
    #1156
    zscott
    Zach
    Utah
    I have had my RTT on both my cabrac and toprac using both types of crossbars. With the heavier crossbars I have always used 6 but have tried both 6 and 12 bar arrangements with the standard crossbars. The weight is so dispersed across different surfaces that I was never able to tell any differences.
  17. Nov 23, 2014 at 7:38 PM
    #1157
    zscott
    Zach
    Utah
    Yeah, I don't get it. I think the 1575 that I use for standard bars is a less popular extrusion for the majority of applications so it will unfortunately be one of the last ones they offer with anodization.
  18. Nov 26, 2014 at 6:22 AM
    #1158
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
  19. Nov 26, 2014 at 9:30 PM
    #1159
    Salt
    Salt ...
    Lyons, Colorado
    12' DCORSB TRD
    SnugTop XV with yakima rack. Factory Cab roof rack. Full bedrug. Debadged. Full OME suspention kit, 866's & Dakars. SPC UCA's. Slee Sliders. ARB front bumper w/ M8000 Warn winch. FJ TRD Wheels. Cooper ST Maxx, 255/85r16
    sub'ed. I'm Impressed.
  20. Nov 27, 2014 at 12:17 PM
    #1160
    ThomasMore66
    I love this rack. I have watched a couple of vids on installing various racks. I'm a little paranoid about screwing up the rubber strip. How do you guys recommend marking the holes to drill?
