Pro-Comp 7089 a 5 lug option?
Discussion in 'Wheels & Tires' started by Murphy, Dec 20, 2009.
  1. Dec 20, 2009 at 4:44 AM
    Murphy
    Murphy [OP] Member
    Good Morning and Happy Holidays!
    I have used the search function many times, and have not found a similar question answered. I have posted a picture of my truck below. As you can see it looks like a had four flats and needed to use the spare donuts and just never replaced them. The wheels are way to small. I have found a wheel that I like the look of and think it will go with the truck, the Pro-comp 7089 in black. Here is the link:
    http://www.procomptires.com/truck-jeep-wheels/pxa-series-7089-wheels.aspx
    I have a 2010 SR5 access cab with the 5 lug option, stock suspension, 15" rism. I am not interested in a lift at this point. I think the pro comp 7089's will fit as they have a 5 lug option 5 on a 4.5 bolt pattern, but I had some questions if anyone would be so kind to answer.
    The main question will they fit on my stock set up?
    Can I go with 17's or do I need to go with 16's?
    Do I order the 17x8's or the 17x9's?
    I am looking for a truck stance, where the wheel tire combo fill up the wheel wells without rubbing/clearance issues, and the tire/wheels match right up to the fenders & 1/4's and maybe stick out just a hair.
    Is there anything else I would need to order with these rims i.e. what type of lug nuts/spacers?
    I really appreciate your time and help.
    Thanks!
