Pro comp lift...
Discussion in 'Suspension' started by toyo freak, Feb 13, 2011.
  1. Dec 10, 2011 at 7:16 AM
    #481
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup:
  2. Jan 11, 2012 at 12:44 AM
    #482
    DV88
    DV88 Active Member
    Dustin
    Redding
    Rock Rails Rear Bumper in Progress Skid Plates in Progress
    more pics
  3. Jan 11, 2012 at 11:29 AM
    #483
    jdm.obp
    jdm.obp Well-Known Member
    561, FL
    3" Pro Comp, 5% all around, Antenna X shorty, Debadged
    Just got mine lifted on monday, will post pics up this weekend. Ride is a little rough, but holefully will smoothen out after I put some miles on it. My truck still has that slight rake to the front end, does anyone else have a rake as well? Will it go away after it settles or can I put a 1/4" spacer in there to level it out? Sorry if its already been discussed, but I've been through this whole thread numerous times and not in the mood to reread everything again. Thanks
  4. Jan 11, 2012 at 11:33 AM
    #484
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The rear should settle a bit.. it shouldnt be that much of a rake tho. You can take the sway bar off too to help the ride. Also, I have my rear tires at a power PSI than up front to soften it up. Helps alot. Usually run about 33 up front and 30 in the rear.
  5. Jan 11, 2012 at 11:50 AM
    #485
    jdm.obp
    561, FL
    sweet man, thanks.
  6. Jan 11, 2012 at 12:35 PM
    #486
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    Are you talking about the steering wheel shaking back and forth?
  7. Jan 11, 2012 at 12:39 PM
    #487
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No he means "rake". Where the front end is slower than the rear.
  8. Jan 11, 2012 at 2:13 PM
    #488
    Bo 159
    Bo 159 Well-Known Member
    Bo
    Clarkston, Washington
    2003 SR5 double cab
    Bilstien 5100s with Eibach coils, 2" toytec aal, K&N CAI, window tint, 32" bigorns, "toy" third brake light cover, rain gards, trail gear shackles
    hey im not trying to go a different way on this thread but it is titled as "pro comp". Has anyone on here heard anything good about the 4" lift pro comp makes. Im interested in it but i dont know of anyone who has it to ask them about it. i doubt if anyone will know anything about that specific lift but if you do i would appreciate the help. thanks
  9. Jan 11, 2012 at 2:18 PM
    #489
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm sure it would be just like any other drop bracket kit. Me personally... I avoid DB lifts.. but to each their own. they work.. but just not my cup of tea and useless.. Imo. Do they make a 3" for 1st gens?
  10. Jan 11, 2012 at 2:42 PM
    #490
    Bo 159
    Bo
    2003 SR5 double cab
    yeah but i have a three inch now. i want it taller is why i want it. i see a few guys on here with db lifts and still wheel them pretty good. i just dont like the price so thats why i wanted some information on it. i just cant find any reviews
  11. Jan 11, 2012 at 2:53 PM
    #491
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Youd be better off doing some trimming... And stuffing larger tires in there. That's where you get your lift and clearance. I know the 2nd gens can trim and fit 35"s with a 3" inch kit.
  12. Jan 11, 2012 at 2:59 PM
    #492
    Bo 159
    Bo
    2003 SR5 double cab
    im running 32x11.5 right now so bigger tires arent much of a concern right now. that lift allows 33x12.5 so thats not a huge difference. the only thing i would lose clearance on would be the front and im not exactly driving right over tree stumps ya know.
  13. Jan 11, 2012 at 3:01 PM
    #493
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just one more thing to get hung up on. And its a pretty vital area to losel clearace on. If you dont want to to run bigger tires, why the need for a 4" kit?
  14. Jan 11, 2012 at 3:14 PM
    #494
    Bo 159
    Bo
    2003 SR5 double cab
    well i would eventually run some 33s but not have them be 12.5 wide. and up until i could even get those tires, the stance would be taller. although i like the look of the bilstein and eibach setup, i just like the idea of a taller truck. as you can tell i think about this a lot lol
  15. Jan 11, 2012 at 3:59 PM
    #495
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ok, fair enough. :thumbsup:
  16. Jan 13, 2012 at 8:43 PM
    #496
    jdm.obp
    561, FL
    just got mine done monday, 265/75/16s on order
  17. Jan 13, 2012 at 8:48 PM
    #497
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    the spring rates on the 3 inch procomp lift are 730 pounds. so even though it states its a 3 inch kit most people go above that. for instance my regular cab was sitting 4 3/4 inches above stock the day it was done.
    i don't know if the first gen kit is the same as the one for the 2nd gens but, i would wager that the spring rates are still awfully high.
    fyi, it took an arb bull bar plate steel skids and a winch with steel line for it to begin to lower and smooth out a bit.
  18. Jan 13, 2012 at 10:14 PM
    #498
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    Doesn't thi lift state not for 4 cylinders access or regular cab tacos mainly for v6 double cabs
  19. Jan 13, 2012 at 10:21 PM
    #499
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    it does now i'm the last guy i know of to buy and instal one.
    i bought this kit and then had it turn out higher than the rcd drop bracket lift lol. so after like a month of back and forth i finally got them to change their vehicle and model specific choices for tacoma lifts. this was due to me, they also sent me out the arb bumper for free to help lower the front which actually worked pretty good but, its still way to stiff even after the addition of skids and a winch.
  20. Jan 14, 2012 at 9:28 PM
    #500
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Alot of good feedback on this lift. I have been running 5100s at 2.5 for the last year and now I wish I would have gone with this lift instead. So probably gonna add new coils soon or sell the 5100s and buy the pro comp lift
