Pro comp lift...
Discussion in 'Suspension' started by toyo freak, Feb 13, 2011.
  1. Feb 2, 2012 at 7:59 AM
    #521
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hmmm.. well hopeully you can get it figured out.
    Try airing down. Or just adding weight In the bed.. you'll love the difference. :D
  2. Feb 2, 2012 at 8:05 AM
    #522
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    Yea me to. Been dealing with this crap for 12K miles. Love the truck but this is getting old. I just want to figure it out and fix it
  3. Feb 2, 2012 at 8:09 AM
    #523
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    Do you have 1/2" wheel spacers on the front? They cause shimmy like you are describing.
  4. Feb 2, 2012 at 8:15 AM
    #524
    francis1291
    Yes I do. I installed everything at 10k miles then at 25k it starting shaking now I have 38k on truck. I have to have spacers cause my tires hit upper control arm with out it
  5. Feb 2, 2012 at 8:29 AM
    #525
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    That's more than likely your problem. Idk why it waited so long to manifest itself but every Tacoma I've rode in with small spacers shook like that. I've read that extended thread lug nuts will solve this but I haven't had any personal experience with them.
  6. Feb 2, 2012 at 8:37 AM
    #526
    francis1291
    There good spacers not cheap ones. There hub cemetric spacers. Idk if that makes a difference. I have put longer studs in also. That's the only way I could fit spacers
  7. Feb 2, 2012 at 8:41 AM
    #527
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Could you swap wheels with someone or have some steels sayin around.. if that fixes It, I'd just get new wheels man.. :/
  8. Feb 4, 2012 at 9:59 AM
    #528
    TXprotrd
    TXprotrd MarioAB
    Mario
    RGV TEXAS
    2011 T|X Pro TRD SuperWhite 4x4
    TRD exaust, Pro Comp lift, GY duratrac 265/75/16
    I have the 3" pro comp lift.. but it seems its lower in the front and higher in the back...:mad:
    Does anyone know whats wrong..??
  9. Feb 4, 2012 at 10:21 AM
    #529
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    Mine should be here Tuesday gnna install next weekend
  10. Feb 4, 2012 at 10:40 AM
    #530
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    leafs may need to settle still. Or do you have the tsb done? Mine sits level. I do air down a bit in the rear tho.
  11. Feb 13, 2012 at 9:10 PM
    #531
    tacoma98042
    tacoma98042 Well-Known Member
    Ok after a long thought out decision, I decided to go with the pro comp 3" lift.
    I had the lift installed 3 days ago with some new 285/75/16 Goodyear duratracs.. and so far so good!
    The ride quality isn't nearly as bad as some people make it out to be. Granted Im only 3 days into this lift, but I really like it! Decent price, and looks really good!
    I'd say for the non-offroader that wants to get a 3 inch lift to fit bigger tires and turn the Tacoma into a more aggressive looking truck, go for the pro comp lift!
  12. Feb 13, 2012 at 9:14 PM
    #532
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Same here finished mine Saturday night
  13. Aug 23, 2012 at 5:35 PM
    #533
    Patmac
    Patmac Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
  14. Sep 23, 2012 at 12:49 AM
    #534
    superman2481
    superman2481 Well-Known Member
    whats VSC mean?? i see one part number on 4wheelparts and another on truckaddons.com and id rather buy from truckaddons cuz of the price but trying to make sure itll work with my '09 prerunner v6 4.0
  15. Nov 12, 2012 at 7:06 PM
    #535
    BigD91
    BigD91 Well-Known Member
    Andrew
    Bay Area
    08 Double Cab 4x4 TRD Sport
    Lots of great info on this thread! Plan on installing this lift within the month!
  16. Nov 14, 2012 at 12:02 PM
    #536
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Don't do it. It's a pile. Save your money or get billys instead.
  17. Nov 14, 2012 at 12:15 PM
    #537
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :rolleyes:
  18. Nov 14, 2012 at 1:57 PM
    #538
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    For everyone suggesting just getting billies, I don't understand that...If you are complaining about the pro comp lift being stiff wouldn't billies set at 2.5 be just as stiff since they're maxed out? Plus that still doesn't get you a full 3 inches, and I would have to get an AAL in the rear which would give me too much rake then I would want, so then I'd have to get a leveling kit in the front?? I don't know it just seems getting a complete lift is simpler.
  19. Nov 14, 2012 at 2:03 PM
    #539
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Plus the fact that your adding preload to the billies.
    I haven't had a single issue with my kit. For the price, its a great full 3" complete kit. Also, i get multiple compliments on how smooth it is. Including other TW members.
  20. Nov 14, 2012 at 2:11 PM
    #540
    dlooney
    Dennis
    Wilmington NC
    That's what I'm thinking! By the way your truck is sick Moose, big inspiration of mine :D
