Pro suspension question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Foozer, May 5, 2019.
  1. May 5, 2019 at 1:22 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Adding a spacer to the top of the spring under hat is exactly what the pre-load adjustment does on King or Fox aftermarket. (This pre-load adjuster is exactly what you’ll be cranking down to get the height you desire with aftermarket shocks). The added weight will sag the front, and you can get that back by adding a spacer in the right place. Adding a spacer above the hat is where it gets a little risky as you can bottom the shocks before the bump stop. Now the spring rate or length on king and fox aftermarket might be different to the fox pro, that would be the only thing to warrant a swap. (But you could always change the spring in the pro shocks.)
    Pro-Taco, Foozer[OP] and whatstcp like this.
  2. May 5, 2019 at 1:25 PM
    mutely
    Depends on who you mean, but in general I personally would. It’s very apparent than most people don’t understand suspension on the 3rd gen forum, just look at all the “how much lift to fit X tires” posts, and and reply’s of Y inches. Complete crap, lift does not allow bigger tires on this particular suspension setup.
    Foozer[OP] likes this.
  3. May 5, 2019 at 1:34 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Only correction that I'd make... if you go aftermarket, use 700 lb springs. 3rd gens are heavier than the 2nd gens, so they ride better on the 700 lbers.
    But overall, very sage advice.
  4. May 5, 2019 at 1:34 PM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    All good information. I'm going to think on it for a few days and decide of I want to try the 1/2 spacer and super bumps or wait and do a full suspension swap
    Bertw192 likes this.
  5. May 5, 2019 at 1:44 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Would you recommend super bumps with the bump spacers or just the superbumps? And would 3/4" top plate spacer with super bumps be ok as well?
  6. May 5, 2019 at 1:49 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    If it were me, I'd keep the spacer as small as possible. Adding a winch and slimline bumper would only drop the front about 1/2". You only need a 1/4" spacer to counter act that sag.
    I would only install the super bump, no spacer with that small of a spacer plate.
    whatstcp likes this.
  7. May 5, 2019 at 2:08 PM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    as others have said, a small 1/4 or 1/2 top plate is absolutely fine, technically i’d consider it more a “shim” than lift spacer really, because your only making a small change. big spacers will cause you issues. i’m doing some 1/4” ones myself soon.
    The other thing that i don’t think was mentioned- coil spacers (between coil and top hat) with the pro shocks- it takes them out of the operating range they were tuned for. i mean, they work, but changes the bypass tune. (talked with fox about this recently)
  8. May 5, 2019 at 2:16 PM
    Chief 4x4
    Chief 4x4 Well-Known Member
    Tim Dean
    Mississippi
    2017 TRD 4WD
    TRD GRILL WET OKLOE SEAT COVERS RAPTOR GRILL LIGHTS NEW OFF ROAD BED DECALS SCS Ray 10'S 16x8 Gunmetal OVTune
    Very nice Tacoma.
    Foozer[QUOTED][OP] likes this.
  9. May 5, 2019 at 2:36 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Thanks man:)
  10. May 5, 2019 at 2:45 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    So 1/2" top plates and super bumps and I'm gold. I'll probably go that route
    Tim8 likes this.
  11. May 5, 2019 at 6:48 PM
    Tim8
    Tim8 Well-Known Member
    SoCal
    2019 Dcsb 040 Pro
    I’m also thinking of going that route, updates and pics would be appreciated. TIA
  12. May 5, 2019 at 7:24 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Just read on HS Offroad's website that 1/2 top plates do not require new bump stops as they are not a big enough spacer! Think I'm gonna pull the trigger
    Tim8, jmauvais and whatstcp like this.
  13. May 5, 2019 at 7:54 PM
    pro_rome
    pro_rome Active Member
    California
    ‘19 Super White TRD Pro MT
    What size tires are you running?
  14. May 5, 2019 at 8:02 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Currently 265/75/16s, reading up on swapping to 285/75/16 though
    Tim8 likes this.
  15. May 5, 2019 at 10:32 PM
    #35
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Any pro owners on here that would discourage 285s?
  16. May 14, 2019 at 7:50 AM
    #36
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Read some horror stories about top plate spacers, busting shocks. Now Im not sure about the 1/2" top plate..
  17. May 14, 2019 at 10:24 AM
    #37
    wolfman00
    matt
    '16 dclb
    small spacers like the .25 and .5 inch thick spacers cause no issues. the ones that cause problems are the thick ones. good rule of thumb- if the spacer has its own studs then you probably don’t want it.
    the thin ones are usually used to correct for leans and minor adjustments
  18. May 14, 2019 at 10:57 AM
    #38
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I guess im trying to figure out what adjustments I need to make to my bump stops, i figure if I'm changing the suspension by 1/2" the bumps will need adjustments?
  19. May 14, 2019 at 10:57 AM
    #39
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    Isn’t “stacking” lift a bad thing? Spacers+coil overs= bad idea?
  20. May 14, 2019 at 12:32 PM
    #40
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Does anybody have a straight answer on 1/2" top plate spacers and bumpstops? Bumpstops need adjustments? Has anyone ever heard of someone busting a shock with just a 1/2"?
