Pro suspension question
Discussion in '3rd Gen. Tacomas (2016+)' started by Foozer, May 5, 2019.
  1. May 14, 2019 at 10:24 AM
    #41
    wolfman00
    wolfman00 Well-Known Member
    matt
    Annapolis
    '16 dclb
    sortof stock. 5100s and thats it.
    small spacers like the .25 and .5 inch thick spacers cause no issues. the ones that cause problems are the thick ones. good rule of thumb- if the spacer has its own studs then you probably don’t want it.
    the thin ones are usually used to correct for leans and minor adjustments
  2. May 14, 2019 at 10:57 AM
    #42
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    I guess im trying to figure out what adjustments I need to make to my bump stops, i figure if I'm changing the suspension by 1/2" the bumps will need adjustments?
  3. May 14, 2019 at 10:57 AM
    #43
    KrnTaco08
    KrnTaco08 Well-Known Member
    City of Angels
    2017 TRD OR DCSB 4X4
    Isn’t “stacking” lift a bad thing? Spacers+coil overs= bad idea?
  4. May 14, 2019 at 12:32 PM
    #44
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    Does anybody have a straight answer on 1/2" top plate spacers and bumpstops? Bumpstops need adjustments? Has anyone ever heard of someone busting a shock with just a 1/2"?
  5. May 14, 2019 at 12:38 PM
    #45
    wolfman00
    matt
    Annapolis
    '16 dclb
    I would contact headstrong, or maybe even give camburg a call.
    whatstcp and Foozer [OP] like this.
  6. May 14, 2019 at 2:07 PM
    #46
    jmauvais
    jmauvais My momma sez Im speshul
    SoCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Never heard of anyone needing to do anything with bumpstops over 1/2”
    Foozer [OP] likes this.
  7. May 15, 2019 at 5:23 PM
    #47
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    Wouldnt it make sense to add a 1/2" spacer to the bump stop? If I'm moving the suspension down 1/2", add 1/2" to the bump? Am I thinking about this wrong?
  8. May 15, 2019 at 5:27 PM
    #48
    jmauvais
    SoCal
    ...stuff
    Yes you’re thinking about it wrong.
    Spacers displace articulation in the front suspension to add lift. It’s not a 1:1 formula.
  9. May 15, 2019 at 5:31 PM
    #49
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    So would a 1/4" spacer be more accurate? Or just leave it with no spacer?
  10. May 15, 2019 at 5:36 PM
    #50
    whatstcp
    whatstcp Professional incoherent spammer
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    You said you decided! lol Also, when you say 1/2" or 1/4" spacer do you mean the spacer thickness itself or what lift it will provide you?
  11. May 15, 2019 at 5:40 PM
    #51
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    I know!!! I'm paranoid haha, just wanting to make sure I do it right the first time. It will be a 1/2" top plate giving ~.75-1" lift. I want to make sure my bumps will still function properly
    TurboFire10 likes this.
  12. May 15, 2019 at 5:46 PM
    #52
    whatstcp
    Ed
    Fontana, CA
    If you're concerned about bottoming your shocks out before your bumpstops then just get the bumpstop spacers. Install your top plate spacers, install bumpstops with spacers, and cycle your suspension. If you need the spacers, then keep them. If your stock bumpstops are fine, then just sell the spacers on TW for a little less than what you bought them for.
    You're way overthinking this and I understand you don't want to damage your shocks. So get the bumpstop spacers and that's that.
  13. May 15, 2019 at 5:49 PM
    #53
    jmauvais
    SoCal
    ...stuff
    No. Spacer. Needed.
    whatstcp likes this.
  14. May 15, 2019 at 5:54 PM
    #54
    MattCowsmasher
    MattCowsmasher TTC #0010
    Temple, TX
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, long legged, big tars, debadged with a hood skewp
    Why not just put the winch set up on an go from there to decide what size of a spacer to get:notsure:
    Another option may just get a hidden receiver setup an put the winch in a cradle to mount only when needed.:ohsnap:
    Ps beautiful truck :drool:
  15. May 15, 2019 at 6:16 PM
    #55
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    How do you cycle the suspension?
    MattCowsmasher likes this.
  16. May 15, 2019 at 6:16 PM
    #56
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    Thanks!
    MattCowsmasher and whatstcp like this.
  17. May 15, 2019 at 6:18 PM
    #57
    whatstcp
    Ed
    Fontana, CA
    compress and extend.
    But trust me and the others that have posted on here, you are overthinking this and making it needlessly complicated. Contact Headstrong, Wheeler's offroad, and maybe someone like accutune to see what they say.
  18. May 15, 2019 at 6:22 PM
    #58
    MattCowsmasher
    Temple, TX
    Your welcome
    Curious as to see what route you go :thumbsup:
  19. May 15, 2019 at 6:24 PM
    #59
    Foozer
    Utah
    2019 6MT TRD Pro
    265/75/16 BFG KO2
    I contacted wheeler's and they couldn't give me a straight answer on if I would need spacers and which sizes with a 1/2" top plate.
  20. May 15, 2019 at 6:26 PM
    #60
    whatstcp
    Ed
    Fontana, CA
    Then try the others
