Probably our last Toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eyball, Jun 18, 2008.
  1. Jun 18, 2008 at 6:55 PM
    eyball
    eyball [OP] Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Well after owning my 2005 Tacoma for 4 months I have to say the older ones were built better and this will probably be our last Toyota. We have had 3 Trucks and 2 SUV's and this 2005 with is suspension issues is junk. You would think if you pay $18,000 for a truck that you can haul more than a couple hundred pounds or more than two people in it. I recently had 500 pounds of mulch in my double cab 4x4 and it bottomed out the entire way home except the freeway. I also went to a concert the other night with 3 of my buddies in the truck with me and the same bottoming out issue.
    My truck has 67,000 on it and I have already talked to the 800#. They just told me to go see the local dealer and they documented my call. The local dealer said $90 to check it out and then no guarantees.
    Anyway, to make a long story short I am upset that I ever purchased another Tacoma. Toyota does not stand behind their products for crap. What good is a 1/2 ton truck if it can only haul 200 pounds?
    At least I can tow my boat with it and bottom out all the way to the lake!:mad:
    Does anyone have a corporate address I can write a letter to and bitch? Maybe that will help.
  2. Jun 18, 2008 at 7:02 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    since ur past the mileage...all u have to do is either an add a leaf in the rear or just buy a new spring set. couple hundred $$ and its done
  3. Jun 18, 2008 at 7:05 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Selling will just make you lose money.
    Get a better leaf pack (Alcan, Deaver, ect) or do an add a leaf.
  4. Jun 18, 2008 at 7:21 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I have seen a few people that installed the ride rite air bag helper on their trucks and seems to work very well with a great ride when you want it and sturdy when needed. I don't have a toyota yet myself but these seem like reasonable options to me.
  5. Jun 18, 2008 at 8:25 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    No offense but, had you researched your purchase, you would've known about this issue. It has been discussed time after time after time on the various Toyota forums.
    But, here you are so go with what jhodge said. That's your solution.
  6. Jun 18, 2008 at 8:30 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    If other than the springs the truck serves you well-hell I would throw on a whole set of new corrected springs! I saw your pics-that's a dam nice truck and there aint nuthin out there that will top it. Sorry-just a fact:)
  7. Jun 18, 2008 at 8:40 PM
    rick
    rick `
    x2
  8. Jun 18, 2008 at 8:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    gotta agree with the rest of the guys.........get a decent set of springs, or even an aal.....it will make all the difference in the world. then......you'll still have the best truck available.......hands down:)!!
  9. Jun 18, 2008 at 9:01 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I'm thinking about installing SuperSprings and Bilstein HDs as a TSB alternative. Will the SuperSprings raise the level of the rear of my truck like a extra leaf spring would ? (I would hate that)
    Bjm0R
  10. Jun 18, 2008 at 9:38 PM
    Asgard
    Thanks a lot man, I think I'm going to try that. In terms of cornering and bodyroll should I install it in the front and rear or will rear installation be fine by itself ?
  11. Jun 19, 2008 at 12:38 AM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    I have upgraded suspension one way or another on just about every truck I have ever owned to suit my needs. If the only thing you don't like about the 3 year old used Toyota is the manufacturers choice of spring rates, that is not a very good reason to get rid of it and never own another. Some people would almost consider it a defect if it had the firmer suspension settings of the older trucks, so there is no way Toyota can please everyone. If you are happy with the ride height, just get a low arch add-a-leaf and some firm Bilsteins, at 67,000 mile it would need new shocks anyway. Since you bought the truck used and with the stated mileage, I don't think I would bother with the dealer for what looks like a 1 hr minimum charge just to look at it and tell you everything is correct as per the original build specs except for normal wear and tear. You have a very good truck, but if you decided to go out tomorrow and get a mid size 4 door truck, what brand and model would you look for that would perform as well as what you have now?
  12. Jun 19, 2008 at 3:58 AM
    tacoma man
    tacoma man Well-Known Member
    Rochester NY
    2018 Limited 4wd Magnetic Gray
    EYBALL
    You have a beautiful truck. You need to take the suggestions from the people here helping you. You can do magic with that truck. Sometimes problems can drive you nuts, but there are solutions. Stay cool and calm and it will work out. Toyota just bought me a new truck and I paid the taxes. Had to say goodbye to a 99 V6 TRD Access 86000 miles. Awesome truck. Could cry. I pick up a 2wd SR5 Access cab Impulse Red Pearl tomorrow. Don't you have that color? GOOOOOOD color!!! Keep the faith man and enjoy that truck. Good Luck.
  13. Jun 19, 2008 at 4:21 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Do what the people here have suggested & upgrade the springs. My truck is just like yours (Color & everything) & did the exact same thing w/ less than 3k on it. Fixed the suspesnsion & viola no more bottoming out. Been thru & thru a Toyota Truck owner since my first one in Oct of 1986. Can't remember one that didn't sag factory after awhile. The 4runners were the worst! So don't waste your time writing man, spend a little of the stimulus check & enjoy your new truck.
  14. Jun 19, 2008 at 5:04 AM
    eyball
    Dudley, MA
    Thanks guys! I am just pissed I have to spend more money I don't really have. Otherwise I do like the truck a lot.
    Xedge: What did you do to yours? Is the suspension work something I can do myself in a weekend? I am pretty good with cars/trucks but in no way a mechanic. I have never done any suspension work before.
    Thanks again for the info. I need to do something as I tow my boat and haul my bike with this truck often and also have a family of 4.
    Eyball
  15. Jun 19, 2008 at 8:10 AM
    Angus_NB
    Angus_NB Well-Known Member
    Riverview, NB, Canada
    '08 Tundra DC SR5 4x4
    I know how you feel eyball. I bought my '05 new specifically to haul an ATV. The truck bottoms out with 600-700 pounds in it. Toyota has stepped up and come out with the TSB but the problem I have is the dealer in my area. They are playing dumb (I hope they are playing). Never heard of the problem. Will not return phone calls.
    I can live with Toyota's products but I am getting tired of fighting with dealerships.
  16. Jun 19, 2008 at 8:18 AM
    Asgard
    I emailed them late last night and got a reply early this morning, they said the front is optional I would need it only if I had a winch or snowplow installed. Now that's customer service !
  17. Jun 19, 2008 at 8:19 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Eyeball as far as for doing it yourself go for it, very easy to do with minor tools and experience. If you are putting the add aleaf it souldn't take but a few hours to do. I never installed a lift before and did my whole truck in something like 6 hours, mainly because I was on the phone with work, had my 3yr old with me and neglected to realize that this truck needs metric tools which I have very few of. Not to mention 3 trips to town and we ate lunch. Go for it you'll be proud.
  18. Jun 19, 2008 at 9:02 AM
    gpspowell
    gpspowell Well-Known Member
    Denver, CO
    08 4WD TRD Off Road
    TRD Supercharger, TDR CAI, TRD Cat Back Exhaust, Old Man Emu 2 1/2" lift kit (886s & Dakars), Full All Pro armor inc. locker guard, Custom fuel tank armor, All Pro Rock Sliders, ARB front bumper, IPF 800XS Driving Lights, Ramsey REP 8000 winch, Centerline wheels, 285X75X16 Michelin LT AT2s, Snug Top shell, SoundLinQ audio interface for my iPod.
    My 2 cents here. For what you're describing, and your circumstances I'd recommend Air Lift levelers. They'll cost you a couple of hundred bucks and they're easy to put on yourself. The nice thing is that they are nearly infinitely adjustable. Run them with 5-10 lbs. for normal driving around, up to 40 -50 to tow the boat, put them up to 100 lbs. for a trip to Home Depot for 1000 lbs of landscaping material. All the while maintaining attitude and alignment, as well as comfort and a smile.
  19. Jun 19, 2008 at 9:21 AM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Try this instead of an AAL. I read all the threads about AAL and the TSB making the ride a bit more harsh so I passed on the leaf TSB and went with this http://www.activesuspension.com/. Very happy with the setup and no ride sacrafice. Handles my trailer a lot better a well.
  20. Jun 19, 2008 at 9:44 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Go through the 1-800 number and print out a copy of the TSB. They'll set everything up for you.
