Problem after 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justin144, Aug 9, 2012.
  1. Aug 9, 2012 at 5:48 AM
    justin144
    justin144 [OP] Well-Known Member
    justin
    Las Cruces, New Mexico
    2011 Taco 4X4 Dbl cab Long Bed
    Alright so I recently got a 3" lift installed by 4wheelparts. Everything is fine, but every now and then, when I turn, it sounds like the tires will rub really bad on something and a dash light will come on, along with a few real quick, high-pitched beeps. It happens so fast that I don't have the time to look at the dash to figure out what light is coming on before it goes away. The light is yellow and I think it's underneath the transmission gear indicator lights. I've had a bit of trimming done in the wheel wells, and it doesn't LOOK like it should rub, but maybe when the suspension compresses, it does?? :confused:. That's my only idea. If it is simply the tire rubbing, I wouldn't think that would set off a dash light, would it?
  2. Aug 9, 2012 at 5:52 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    first problem: you had your lift put on by 4wheel parts. They are hardley capable of even pulling the correct order off the shelf...let alone installing a lift.
    Second problem: the lift is affecting your Vehicle stability control (VSC). I believe you can take it in to the dealer and they can reset it for you and it should clear things up.
  3. Aug 9, 2012 at 5:53 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Sounds like the VSC system is kicking in....is it a yellow "!" popping up on the dash?
  4. Aug 9, 2012 at 5:57 AM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
  5. Aug 9, 2012 at 6:05 AM
    justin144
    justin
    Well that sucks to hear. A lot of people in the area recommended them before I decided to let them install it. I was thinking about doing it myself but don't have a spring compressor and they told me they'd do a free alignment, which they ended up charging me for. Also they left the plastic deals in the wheel wells flapping, and they tried to keep all my parts.. Anyways,
    Is the rubbing noise related to the VSC? The beeps and dash light ONLY come on when I hear that noise..
  6. Aug 9, 2012 at 6:10 AM
    justin144
    justin
    Thanks Dman, that picture is helpful. Though, I can't point out the light that's coming on. I've only seen it twice out of the corner of my eye, but it looked like it was where the "4LO" light is. Guess I'm wrong
  7. Aug 9, 2012 at 6:14 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    that noise is the ABS kicking on when as a result of the VSC being triggered. did you feel the wheel or truck pull at the same time?
  8. Aug 9, 2012 at 6:18 AM
    justin144
    justin
    I didn't, but it happened again this morning, as I was turning with my foot on the brake pedal, and it did have that vibration feel, as if the ABS was kicking in. You must be right.
  9. Aug 9, 2012 at 6:25 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What kind of 3" lift. Since no one else asked.
  10. Aug 9, 2012 at 6:33 AM
    justin144
    justin
  11. Aug 9, 2012 at 6:41 AM
    JonnyBb
    Arkansas
  12. Aug 9, 2012 at 7:03 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    ya, its your VSC kicking in. the beeping noise and the vibration of the brakes kicking in can be startling. it happens more often for me too (since i got my lift), but for me, its not that bad. like others have said, you can have your VSC recalibrated by the dealer. i think its about 20-30 minutes of labor.
  13. Aug 9, 2012 at 7:54 AM
    tim allan
    tim allan Well-Known Member
    Wv
    2017 double cab trd offroad
    it doesn't happen to mine, if you take it to a dealer to get an alignment done, make sure they reset vsc with the zero point call...
  14. Aug 9, 2012 at 2:07 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  15. Aug 9, 2012 at 2:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    pdf file in post #1 of that thread ^^^^^
  16. Aug 31, 2012 at 7:15 PM
    Bee22971
    Bee22971 Well-Known Member
    Garth
    Sacramento
    2011 DC TRD
    King 2.5 C/O, DSM UCAs, all pro leafs, and AllPro Sliders
