Problem with aftermarket Exhaust manifold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Christt, Jan 1, 2015.
  1. Jan 1, 2015 at 8:05 PM
    Christt
    Christt [OP] New Member
    California
    Hi crew, I have a 1998 toyota tacoma 2.4L Manual transmission.
    I had a bad exhaust leak because I had a cracked exhaust manifold. So I replaced it with another one that I bough from Ebay. http://www.ebay.com/itm/130944151058
    When I had to put the egr line back on to the exhaust manifold it wouldn't exactly fit. I had to really fight with it so it can bolt on to the manifold. I finally did with so much struggle. No more exhaust leaks but now I'm getting the p0401 for insufficient egr flow. What do you guys think the problem is?
  2. Jan 1, 2015 at 9:08 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Check the other end of the egr dump tube. Does it look like anything is wrong there? Even if the egr tube wasn't there, it wouldnt pop that code so I doubt that tube is your problem. It may have stressed the valve just enough to put a crack where it meets the plenem. Its definitely somewhere at the egr/plenum location where you'll find the culprit.
    I bought a cheap RockAuto one for mine and remember the egr port being way out of spec and it took a lot of muscle to get it to line up for the nuts/bolts to realign and tighten it. Mine didn't pop any codes after that.
  3. Jan 17, 2015 at 6:33 PM
    Christt
    California
    That's exactly what happened to me, it didn't really align. It also took a lot of muscle to realign. I'm going to check the egr and plenum. Also, will a 2002 exhaust manifold fit my tacoma, same fittings just looks like headers
  4. Jan 17, 2015 at 6:59 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yes!! The stock mini header will fit all the models that came with the cast manifold 2.4 or 2.7L.. going that route is a much better choice than a cheap aftermarket mani. No fittment issues and you won't be replacing another cracked manifold ever again.
