problem with window switch anyone local?
Discussion in 'Northern California' started by adower, Feb 15, 2013.
  1. Feb 15, 2013 at 12:10 PM
    adower
    adower [OP] Well-Known Member
    My passenger window switch will roll the window down. However it wont roll the window up. I am trying to figure out if its the switch? I would assume the whole thing would stop working if it were. Not just one way. Any help in what I should look into? I am. In sac. Ill bring ya a 6pack if needed!
  2. Feb 15, 2013 at 1:32 PM
    kalieaire
    kalieaire Well-Known Member
    Stanley
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    SnugTop Rabel, Demello Sliders
    Does it budge a little bit but seem like it does not have enough power to go back up?
  3. Feb 15, 2013 at 1:45 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    I had the same problem on the driver's side. Bought new switch from Maita Toyota for $195 and problem still same problem. When to the scrap yard and bought used Tacoma power window motor and solved the problem.
  4. Feb 15, 2013 at 2:50 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Honestly i would find someone with the same model truck as you first and just try their switch panel. then go from there.
  5. Feb 15, 2013 at 3:29 PM
    adower
    If I try on the passenger side it doesn't budge at all. Its like itsto not connected. Drivers side and it goes up perfect.
    I am going to try and pull the switch apart and clean it.
  6. Feb 15, 2013 at 3:31 PM
    adower
    How can the motor be bad if the driver side switch makes it go up? Wouldn't the motor not work at all?
  7. Feb 15, 2013 at 3:37 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    If you have a double cab, you could try to the PW switch from one of them. Maybe the drivers side switch?
    The door panels are cake to get off.
  8. Feb 15, 2013 at 3:38 PM
    PreRunnerSeth
    Apex, NC
    The switch panels can be pulled without taking the door panels off.
  9. Feb 15, 2013 at 3:40 PM
    adower
    Is that for a 1st gen? How do you remove the switch panel? I've tried searching but only 2nd gen tutorials pop up.
  10. Feb 15, 2013 at 3:43 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Had that problem too on my back passenger side. had the switch replaced and works like a charm now!
  11. Feb 15, 2013 at 3:46 PM
    Ryan DCFS
    East Bay Area
    That's far too simple. Though it makes sense...
    (I've only disconnected/removed mine when I pulled the panels to wrap the armrests.)
    Lol.
  12. Feb 15, 2013 at 4:02 PM
    PreRunnerSeth
    Apex, NC
    Yeah.. theres a clip on one end and a hook on the other. one end hooks under the arm rest and the other end is just held in by clips.
  13. Feb 15, 2013 at 5:33 PM
    CaliAsh
    CaliAsh Well-Known Member
    Jesse
    Left Coast
    2012 Taco TRD Sport DCLB
    Trail Limo
  14. Mar 7, 2013 at 4:06 PM
    Flip Dog
    Flip Dog Active Member
    Dave
    Santa Cruz, Ca
    Super White 4x4
    wow that video was very informative.
