Problems with A/C controls lighting
Discussion in 'Lighting' started by goat632, Apr 15, 2016.
  1. Apr 15, 2016 at 9:40 PM
    goat632
    goat632 [OP] Well-Known Member
    Central Texas
    The Great White Buffalo
    Running Boards, Plasti-dipped rims, Blacked out Interior, LEDGlow Lighting, Led dome and map lights, Kicker Speakers, CB Radio with PA speaker, Blacked out Emblems, Pioneer DD Head Unit, Paracord Wrapped Grab Handles
    Hey all,
    Just need some quick advice. Earlier this year, I installed a pioneer head unit in my '11. Of couse, I had to take out my A/C control panel. But, when I put it back, the right side light didn't light. I took it back off, saw that the bulb was loose, so I took it out and put it back in place. But of course, it didn't light up. So I took it back out to inspect the bulb more closely, saw it was fine, put it back in, it lit but only for a while, then went dark again. So I took it off one more time, removed the bulb.
    So to recap, this bulb has been removed 3 times, and reinstalled twice, AND THAT'S ALL IT TOOK to completely rub off all of the copper coating on the pcb where it screws in. So now, with most of the copper gone, it will not light. Please help me fix this. I was thinking about just taking it out and trying to tin where the copper rubbed off of it with some solder, but not sure if that will work. If it doesn't, could I just get some very small wire and solder the bulb directly to what little copper remains on the pcb?
  2. Apr 15, 2016 at 9:41 PM
    goat632
    Central Texas
    clarrification**
    The copper is not COMPLETELY gone, but almost so, enough to where when the bulb is screwed it it gets no connection
  3. Apr 15, 2016 at 9:48 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  4. Apr 15, 2016 at 10:32 PM
    goat632
    Central Texas
  5. Apr 15, 2016 at 10:58 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Very easy to apply, and works well. However, it is not like an etched trace, so the conductive paint will scratch off rather easily, which means if that bulb is continually inserted and removed, the paint may need to be reapplied.
  6. Apr 16, 2016 at 2:53 AM
    goat632
    Central Texas
    Will it hold up just to get it in once?
  7. Apr 16, 2016 at 5:55 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    It will probably hold up once. No guaranties, but worth a try.
  8. Apr 16, 2016 at 11:21 AM
    goat632
    Central Texas
    agreed, thanks a lot man
  9. Apr 17, 2016 at 6:37 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  10. May 12, 2016 at 8:21 AM
    goat632
    Central Texas
    It did not, I put the paint on the pad and it rubbed off after one time of turning the bulb in. That stuff is super fragile. Im thinking about just tinning it, just flood the pad with solder. Thoughts? Suggestions?
  11. May 12, 2016 at 8:29 AM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Sorry to have misled you. Hoped it might have worked in your case.
    You could try a solder pad, but not sure how good of a connection you will get with the bulb not soldered to it, but just resting on it.
    You may have to go with the soldered wire step.
  12. May 12, 2016 at 8:31 AM
    goat632
    Central Texas
    Hey don't worry about it man! Worth a shot!
    So wiring the leads of the bulb to the copper pad?
