problems with the front end of my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by mfkokoska, Mar 24, 2011.
  1. Mar 24, 2011 at 4:08 AM
    mfkokoska
    mfkokoska [OP] Active Member
    matt
    sydney ns canada
    i have a 03 trd with a 2.5 daystar lift kit. i was noticing a humming noise and viberations coming from the front end and a could feel it under my feet when im driving and passenger side. i took it to a machanic who specializes in toyotas. he said the front left axle is fucked(due to the lift because my angles are off) so i got one and he put it on. when i pick my truck up he told me that there is still humming coming from the front end and it sounds like a wheel bearing but dosent know witch one because when he puts the truck on the hoist the left wheel wont spin freely because of the lift and thats how he determines which one it is. he says i should get a proper lift with dropped suspension.
  2. Mar 24, 2011 at 2:43 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    He's an idiot. First... He replaced a part that wasn't even bad, and now second he "thinks" it's a wheel bearing? Yea, sounds like he "specializes in toyota's". Rotate your tires.
  3. Mar 24, 2011 at 2:45 PM
    98tacoma27
    Ben
    Not Beech Creek
    X2, the part he replaced goes through the wheel bearing. He should have been to see that.
  4. Mar 24, 2011 at 2:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    If the left wheel won't spin freely, it's the bearing or the brake, NOT THE LIFT.
  5. Mar 24, 2011 at 2:49 PM
    Supra TT
    Eric
    Indiana
    Also.. Proper lift with DROPPED SUSPENSION? :eek:
  6. Mar 25, 2011 at 8:09 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Is your truck 4x4? If it is, put it in 4wd and see if the humming/vibrations stop. If it doesnt do it while in 4wd, then its a bearing in your front diff.
  7. Mar 25, 2011 at 8:40 AM
    mfkokoska
    matt
    sydney ns canada
    yea when my truck is in 4wd it goes away. so is it my diff bearing for sure?
  8. Mar 25, 2011 at 10:50 AM
    mikracer
    San Luis Obispo, CA
    Everything I've read on this forum and TTORA suggests that its a bearing (cant remember which one) in the front diff. The problem is, its expensive to replace because of the labor involved. Of course if you're mechanically inclined and can do such a project, its not as expensive. I didnt know how to do it so I just lived with it. Fortunately, it appears that the bearing wont fail for an extended period of time. There are some guys that have driven on the vibration for several years. The vibes are exaggerated with the lift, so if you take your spacers off, it should be much less.
    I ended up selling my 4x4 because it was an Xtra cab and I needed a double cab. I now have a double cab prerunner so I wont ever have that problem again. I think theres a thread in the 2nd gen forum regarding this as well.
  9. Mar 25, 2011 at 3:22 PM
    mfkokoska
    matt
    sydney ns canada
    thanks for the info guys
