PROCOMP 7089 16" VS 17"
Discussion in 'Wheels & Tires' started by Gabe911, Feb 12, 2012.
  1. Feb 12, 2012 at 2:21 PM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    I have read enough in the threads that say the 16" will fit fine without rubbing the brake calipers. My question is for those running 16" and 285's are there any issues with balancing and would 17" make a difference?
    Any other wheel recommendations?? thanks
  2. Feb 12, 2012 at 3:50 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    wheel/tire size between a 16/17 shouldnt have any effect on the balancing or not
  3. Feb 12, 2012 at 3:50 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    And almost all balancing issues are due to the tires, not the wheels.
    i.e. uneven wear, lateral runout, radial runout.
  4. Feb 12, 2012 at 3:51 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
    ...but you can run standard size tires on 17"s. I personally am more of a less wheel more tire type of guy. So I vote 16s :cool:
  5. Feb 12, 2012 at 3:52 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    I have 16s .tires are cheaper
  6. Feb 12, 2012 at 4:47 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Thanks for all the comments good knowledge here really appreciate it...and I am the same ...more tire less wheel...it took me forever but its OME complete with 285 KM2's ...just have to pull the trigger on the wheels and put this stuff on ...this site has been awesome....should have my build page up with in a month...thanks again
  7. Jun 18, 2012 at 5:21 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    Older thread revival.
    Just ordered these from Discount Tire in 17 inch. The guy said they were -8 offset, but said the computer didn't say what the backspacing is. He said there is only one option in their computer for this wheel in that size / lug pattern. Since I can only find them online in 4.5 backspacing, I am guessing that is what they are.
    I guess my question is, is -8 offset correct? I'll be running 265 70 Duratracs on stock suspension and would prefer no trimming.
  8. Jun 18, 2012 at 6:54 PM
    KPT
    09 Prerunner
    What is the width of the wheels? we need that in order to calculate backspacing.
  9. Jun 18, 2012 at 7:05 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    17X8
    Thanks! I was hoping you could help :thumbsup:
  10. Jun 18, 2012 at 7:07 PM
    KPT
    09 Prerunner
    That would be approx 4.25" BS then.
  11. Jun 18, 2012 at 7:10 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    So.. Do you think rubbing will be an issue?
  12. Jun 18, 2012 at 7:11 PM
    KPT
    09 Prerunner
    Very minor rubbing on the black plastic, if any.
  13. Jun 18, 2012 at 7:12 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    I can live with that. I'll update after they are installed for future reference.
    Thanks for your help!
  14. Jun 18, 2012 at 7:14 PM
    KPT
    09 Prerunner
    :thumbsup:
  15. Jun 20, 2012 at 7:21 AM
    Scope3334
    Scope3334 Well-Known Member
    Maryland
    2012 White Tacoma TRD Sport
    Aries Bull bar, Westin Nerf bars, WeatherTech Deflectors, OEM Roof Rack
    Mine fit great. I had the 17"x8 with 265.70.17 with stock suspension with very very very little rubbing on mud flaps at full lock. Used some sand paper and took 1/8 inch off and was fine. Now with the OME 3" lift no rubbing.
  16. Jun 20, 2012 at 12:16 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    Good to know. Thanks!
  17. Jun 22, 2012 at 2:32 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    Hey Keith-
    My wheels came in today and I had them installed. I noticed on the box, they say "0" offset vs the "8" I was quoted. What does that make the backspacing now? I am wondering if it wont be enough....
  18. Jun 22, 2012 at 2:47 PM
    KPT
    09 Prerunner
    That's would make them 4.5", you'll be good to go.
  19. Jun 22, 2012 at 2:51 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    You are the man! Thanks for all of your help.
