Procomp 7089 hubcentric or not?
Discussion in 'Wheels & Tires' started by Dashe, Nov 5, 2009.
  1. Nov 5, 2009 at 12:51 PM
    Dashe
    Dashe [OP] Well-Known Member
    David
    Charleston
    Black Double Cab SR5 4x4
    debadged, Grillcraft grille with FJ emblem, KC SlimLite Driving Lights behind grille, Bilstein 5100's, Eibach 1.6" lift springs, add-a-leaf, Pro Comp 7089 wheels, BFGoodrich A/T 285/75/16, Dynomax Super Turbo muffler, CB with Wilson Flex antenna
    I searched for this info, and didn't come up with a definite answer so I'm posting here. i apologize if I just missed something. I am about to order some 7089's as they are running a discount and offering free shipping at 4wheelparts.com. They are offered in hubcentric and non-hubcentric (lug centric I assume) models. I'm pretty sure I need the non-hubcentric ones for a 2009 DC, but I want to check before I drop $400+ on them. Thanks for your help.
  2. Nov 5, 2009 at 12:55 PM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    lug centric for our trucks.
  3. Nov 5, 2009 at 12:55 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    For the 05+ Tacoma they only come in a lug centric version. Just make sure you get the shanked lugs.
  4. Nov 5, 2009 at 12:57 PM
    Dashe
    David
    Charleston
    excellent. thanks guys. are the stock lugs shanked?
  5. Nov 5, 2009 at 1:02 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  6. Nov 5, 2009 at 1:27 PM
    Dashe
    David
    Charleston
    wheels are ordered. can anyone direct me to the specs for those lug nuts?
  7. Nov 5, 2009 at 1:50 PM
    cntstan
    cntstan Well-Known Member
    Chuck
    Wisconsin now, North Carolina will always be HOME
    08 DC SR5 4X4 ; 94 Ford Bronco
    3" Toytec coilovers, rear AAL,satoshi'd grill,ARE topper,TRD exhaust, All Pro winch bumper, Warn winch, All Pro skid, Pro comp 7089's, Supersprings, Wet Okole seat covers
  8. Nov 5, 2009 at 1:54 PM
    mjp2
    NJ
  9. Nov 5, 2009 at 2:02 PM
    PreRunnerSeth
    Apex, NC
    The lugs in the first link are not correct. I know this is what 4WP will sell you for this application but they are not correct. there has been lots of discussion on this one. These wheels are lug centric. standard acorn style lugs dont always center the hole in the wheel over the lug well. Plus they dont provide much thread coverage on the tacoma. you need shanked lug nuts that fit over the lug and in the hole in the wheel like the ones in the upper right in the second link. these provide much better thread coverage and center the hole in the wheel with the lug. do a search ive gone into this before with these wheels. unfortunately no one has found this type of lug nut in black.
  10. Nov 5, 2009 at 2:10 PM
    mjp2
    NJ
    Do you have any close-up pictures? If you do, I'd like to see the difference between the two where they make contact with the wheel.
  11. Nov 5, 2009 at 2:13 PM
    cntstan
    Chuck
    Now I'm confused. Are you saying the ones in MJP2's link (part# 21138ETXL) are the correct lugs? If so, I guess I screwed up and need to order some. I haven't noticed any ill effects from the pro comp ones.............yet.
  12. Nov 5, 2009 at 2:39 PM
    Dashe
    David
    Charleston
    are you talking about item number 21138BC? (black 12x1.5)
    as far as the center caps, i think im going to go without. i kinda like the look better, and it'll be one less thing to tear up on the trails. Thanks for the offer though.
  13. Nov 5, 2009 at 2:55 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just so you guys know. We carry many different styles of Lug Nuts rom Gorilla. Both in regular chrome and black chrome. The ET (extended thread) nuts come in chrome and reach down into the wheel so that you get more bite on the stud.
  14. Nov 5, 2009 at 3:42 PM
    PreRunnerSeth
    Apex, NC
    This is the lug nut im talking about. they also help to center the wheel on the lug better than just the tapered type. In the gorilla link above its the ET-XL style. See how there is a shank on the thread side that goes into the hole on the wheel.
  15. Nov 5, 2009 at 3:44 PM
    PreRunnerSeth
    Apex, NC
    You may never see problems. but, without the shank its easier to misalign the wheel and cause problems as well as Dan said you dont get as much bite on the lug.
    I will try to do a graphic to show the difference.
    Heres a primitive graphic... to show. think of it as a cut away side view.
    Blue would be the wheel
    black the hub
    green the lug
    red shanked lug nut
    Yellow unshanked lug nut
    You can see that the unshanked lug nut relies on the taper to center the wheel hole over the lug. friction can sometimes prevent it from centering completely. the shanked lug nut the shank centers the wheel hole over the lug. this is especially important in a lug centric wheel. you can also see that the shank covers more of the lug providing a stronger connection to the hub.
  16. Nov 6, 2009 at 7:20 AM
    mjp2
    NJ
    Great info and excellent explanation! Looks like I was shipped sub-optimal lugs when I bought my wheels. I'll be upgrading in the near future.
    Thanks!!
  17. Nov 6, 2009 at 8:37 AM
    PreRunnerSeth
    Apex, NC
    unfortunately gorilla doesn't make this type in black. so youre kinda stuck with chrome... but my chrome lugs are actually growing on me a little. just a tiny bit of accent to the wheels then just all darkness.
  18. Nov 6, 2009 at 8:44 AM
    mjp2
    NJ
    If you've ever seen my truck you'll realize that lug color isn't much of a concern. My main focus is making sure stuff stops breaking every time I use the thing. :p
    I upgraded my wheel studs to longer ones earlier this year. I just posted details in this thread earlier this morning:
    http://www.tacomaworld.com/forum/wheels-tires/58328-2005-2010-tacoma-wheel-studs.html#post1096472
  19. Nov 12, 2009 at 8:38 PM
    Dashe
    David
    Charleston
    Stoked! Shanked lug nuts on the way too. Can't wait!
  20. Nov 12, 2009 at 8:46 PM
    cntstan
    Chuck
    POST PICS..............when they're on of course:D.
