ProComp tires work?
Discussion in 'Wheels & Tires' started by RubberTank, Aug 25, 2011.
  1. Aug 25, 2011 at 8:26 PM
    RubberTank
    RubberTank [OP] Well-Known Member
    Thousand oaks, CA
  2. Aug 25, 2011 at 8:29 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    They should but the backspacing is pretty low. Those would stick out pretty far. If you're a second gen (which I'm assuming) probably 1.75"
  3. Aug 25, 2011 at 8:41 PM
    RubberTank
    Thousand oaks, CA
    so should i go for the 4" or 4.5" backspacing, i want them to stick out, but not too far
  4. Aug 25, 2011 at 8:42 PM
    malander
    max
    01 limited trd 4x4
    4.5" should stick out an inch I believe if you are a second gen. Maybe someone with a second gen will chime in to verify that but I'm 95% sure
  5. Aug 25, 2011 at 8:47 PM
    RubberTank
    Thousand oaks, CA
    yeah Im a 2nd gen. I think im gonna go with the 4.5" backspace. thanks for the help
  6. Aug 25, 2011 at 8:48 PM
    malander
    max
    01 limited trd 4x4
    No problem buddy
