Product of the day: NoLoss Valve Caps
Discussion in 'Sierra Expeditions' started by FlyingWil, Jan 25, 2011.
  1. Jan 25, 2011 at 7:54 AM
    FlyingWil
    FlyingWil [OP] Well-Known Member Vendor
    Wil
    Sonoran Desert
    01 DC Expedition Ready
    Shrockworks Front Bumper, LightForce 240's, PIAA 510's,T-Max 9000 competition winch with Outback (longer drum) and modified brake wireless controller and Masterpull line with Viking safety thimble, Rugged Ridge Hawse, Daystar Winch isolator, SAW Racerunner 2.5 coilovers, Safari Snorkel, IBS dual battery system with RBM, Scangauge II, Total Vision self spotting kit and monitor with aux output and remote, Low Tek Gauge pod with Cyberdyne gauges for fridge and battery, Yeasu FT-7800 head unit mounted in ceiling linner and speaker Larson Hood mount, Uniden Pro 520XL CB radio in the ash tray location,'lil Wil Mag mount antenna, Odessey 1200 MJT & Die Hard Plat. dual batteries, Can-Back with extra mounts, Blue Sea 12 st Fuse Box, 100 Amp 100 Amp Relay, Extremeaire & 5 Gal air tank w/ 145 psi switch, Custom bed drawer system, Engel Mt-45 with TwoZone, protective covers, and Engel Slide Eezi-Awn 1600 RTT w/ Ikea LED light mod, and sheet set, CBI offroad Expedition rear bumper, jerry can tir
    [​IMG] [​IMG]
    These No Loss Valve caps are built for NATO military vehicles, providing a seal if the valve core fails. This brass cap with knurled outer surfaces will not stick to your brass valve stems. Inside the No Loss Valve cap is a quality 0-ring for a positive air tight seal. Guaranteed not to leak even if the valve core is missing. The retaining strap keeps the No Loss Valve cap attached to your valve stem. No more losing caps, storing them in your mouth (yuck!) or fumbling in cold weather with gloves on. Forget to screw your No Loss caps back on?? Retaining strap is strong enough to withstand 80 mph speeds with the No Loss cap just hanging there!! Can be used on any valve stem.* The list is endless. From 4WD's, RV's, sports cars, motorcycles, ATV's, Semi Trucks, construction equipment, farm equipment, planes, mountain bikes, to go karts.
    Available in 4 or 5 Packs.
    *IMPORTANT NOTE:
    No Loss Caps can only be used on brass valve stems. Do not use on aluminum valve stems such as those equipped with TPMS.
  2. Jan 25, 2011 at 7:58 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    Looks like a cool product. To bad we can't use them with the TPMS.
  3. Jan 25, 2011 at 1:32 PM
    FlyingWil
    Wil
    Sonoran Desert
    We're working on one that will work with TPMS
  4. Jan 25, 2011 at 1:40 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I would buy those (ones that work with TPMS).
    Do these come in black? Looking for my brother's jeep.
  5. Jan 25, 2011 at 1:48 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Those are cool, but i wouldn't buy them just because i know some punk kid would probably steal them off my rims.
  6. Jan 25, 2011 at 4:34 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    Two words: Red Loctite :D
    That should slow them down... unless they bring tools.
  7. Jan 25, 2011 at 4:44 PM
    FlyingWil
    Wil
    Sonoran Desert
    Actually this has never been an issue for me. I've been running them since '05.. Most of the time the retaining strap is enough of a deterrent to keep them on. I have had a few where I come out to the truck and have one of them just hanging by the retaining strap, but other then that I have never had one go missing, even with numerous trips to bad neighborhoods and having the truck parked in boarder cities in Mexico.
  8. Jan 25, 2011 at 4:45 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Is it a plastic strap that holds pretty tight? Kinda looks like a rubber ring that can be pulled off with a little force
  9. Jan 25, 2011 at 5:04 PM
    cc350
    cc350 Retired Member
    ^^ Or dry rot.
  10. Jan 25, 2011 at 5:08 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    cool product
  11. Jan 26, 2011 at 8:01 AM
    FlyingWil
    Wil
    Sonoran Desert
    The retaining strap is an ABS plastic, it will hold the cap on (if left unscrewed and hanging) at speeds upto 80 MPH.
  12. Jan 26, 2011 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just so folks know, The only reason these arent to be used on the TPMS valve stems, is due to them being aluminum. There is a chance they can corrode and/or stick (corrode) to the stems. This can be avoided by using a very little bit of anti sieze on the threads of the valve stem. Im going to be getting a set to try out on the TPMS valve stems, and will report back.
    NOTE: doing this voids the warranty on the valve caps, so you wont be able to call Will up screaming that the valve caps made your truck loose its wheels, and or you lost your job, and your Wife left ya.....
  13. Jan 26, 2011 at 8:48 AM
    FlyingWil
    Wil
    Sonoran Desert
    Correct... If the caps are taken care of, and are used frequently we have not found them to be an issue. We have them on our FJ Cruiser, and have not experienced an issue using them. But we are airing down, and up at least once a week. The disclaimer is mainly to take responsibility off of us since there is the chance that it could corrode to the valve stems on TPMS equipped vehicles. With proper care and usage of the NoLoss caps, I would not see a problem with using them... its the ones that only occasionally remove their valve stem caps that have a higher likely-hood of corrosion.
    Gen 1 Taco's no problem, Gen 2's care must be used. We're going to give a set to Chris, and let him report back some real world results, and not information from us.
  14. Jan 26, 2011 at 1:05 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Let me think a little longer, I may just buy these.
    Do they come in a black?
  15. Jan 26, 2011 at 2:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, when I put these on, I saw the ones I had on the truck were Aluminum. I dont see an issue.
  16. Jan 26, 2011 at 2:05 PM
    FlyingWil
    Wil
    Sonoran Desert
  17. Jan 26, 2011 at 2:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I will :eek:
  18. Jan 26, 2011 at 2:28 PM
    bioman
    bioman New Member
    PreRunner
    Stock.
    Not a bad idea. Do they sell these anywhere locally?
  19. Jan 26, 2011 at 2:54 PM
    FlyingWil
    Wil
    Sonoran Desert
    Where is local?
  20. Jan 26, 2011 at 3:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
