Programmable Voltmeter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scout23, Aug 27, 2010.
  1. Aug 27, 2010 at 8:05 PM
    Scout23
    Scout23 [OP] Active Member
    Southcoast, MA
    2010 Tacoma TRD
    Just picked up a new toy. A programmable voltmeter from Lascar Electronics.
    http://www.panelpilot.com/
    You can set the display as an analog meter or bargraph or a combination. All colors are changeable. You can set a splash screen to display on start up. I used the same one that I had on my headunit.
    I wasn't sure where to put it. I didn't want to cut holes in my dash or console so I cut a plastic piece to fit behind cupholders and covered it with vinyl. It's a tight press fit but I can remove it and leave behind no scars. I have room to add a second meter (monitor current maybe?).
    Any ideas on other locations or uses?
  2. Aug 27, 2010 at 8:21 PM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    wow that looks great. very clean install :thumbsup:
  3. Aug 27, 2010 at 8:22 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    looks good. you dont have the vehicle dynamics gauges on the pioneer head unit? mine shows volts, slope, clock, MPH, etc.
  4. Aug 27, 2010 at 8:24 PM
    Scout23
    Southcoast, MA
    2010 Tacoma TRD
    No. I wish I did. Do you have a AVIC Z110-BT or Z120BT?
  5. Aug 27, 2010 at 8:28 PM
    The_Hodge
    SC
    old ass N1
