Programming a chip key
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonah, Jan 1, 2025.
  1. Jan 1, 2025 at 7:45 AM
    Jonah
    Jonah [OP] Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    Happy New Year all!
    A few months ago I picked up a 2014 TRD/OR that came with 2 sets of keys and fobs. I've been using one key without any issues. Yesterday I tried the other key and it wouldn't start the truck. It unlocks the doors and turns in the ignition no problem but just cranks the engine and won't start it. My assumption is that the chip isn't programmed correctly.
    Is it possible to reprogram the key yourself, or does it require a locksmith and/or special software? Has anyone done it successfully? It stresses my OCD to only have one working key.
  2. Jan 1, 2025 at 7:55 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You can program fobs yourself but the chip key requires software/laptop.
    Hopefully you can find a locksmith who can do it cheaply, although buying the equipment/software yourself is an option too. Lots of threads on that here.
  3. Jan 1, 2025 at 8:15 AM
    haydendoesmith
    haydendoesmith Well-Known Member
    15 DCSB TRD Sport 4X4 Auto
    I've done it myself. Bought the blank transponder keys and Toyota Techstream off Amazon. Total cost was about $100. Some notes to consider depending on your location. My Home Depot refused to cut transponder keys. Ace Hardware cut the key using an automated key cutter and it didn't work. A local locksmith cut the key manually and it worked perfectly. The $100 upfront cost included the two keys wasted by Ace Hardware. I then used Techstream to program it.
  4. Jan 1, 2025 at 8:17 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you try turning the key over?
    Sometimes when it's been away from the truck a while, it doesn't quite sense the chip.
  5. Jan 6, 2025 at 2:24 PM
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
