Programming a different fob?
Discussion in 'Technical Chat' started by Mack83, Feb 8, 2021.
  1. Feb 8, 2021 at 8:45 PM
    Mack83
    Mack83 [OP] Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    My wife's 2015 Sequoia only came with one fob, and I thought it would be nice to get her something that's a little bit better than just a replacement for the stock one. Would it be possible to use a different key/fob from another Toyota? A newer one I was thinking, from an Avalon or something.
    I know how to do the programming itself, just not sure if it would work with something other than the same style key/fob it's supposed to use.
  2. Feb 9, 2021 at 8:54 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As far as I know it needs to be two from the same vehicle.
    I am sure it can be done but have nothing that new to play with.
  3. Feb 10, 2021 at 6:41 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    A good locksmith could give you some options. There are also various websites that sell aftermarket ones. The FCC ID needs to match for the transmitter and some keys have an "H" or other letter stamped in the key which deals with the transponder chip that's used to start the vehicle. So these two items need to match at a minimum.
  4. Feb 18, 2021 at 2:59 AM
    r34p3r666
    r34p3r666 Well-Known Member
    Diamond Bar, CA
    6-Speed Tacoma Baja T/X, TRD Supercharged
    i purchased 2 OEM fobs and key blanks for my Tacoma, got an OBDII to USB unit, came with Toyota techstream software for my Windows laptop, took about 5min to program both fobs and keys. Puente Hills Toyota wanted $15 to cut each key and $150 to program them. I went to Norwalk Toyota, they cut the keys for free. Easy peasy.
  5. Mar 3, 2021 at 9:15 PM
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
