Programming in Python
Discussion in 'Technology' started by RAT PRODUCTS, Apr 4, 2013.
  1. Apr 4, 2013 at 1:17 PM
    RAT PRODUCTS
    RAT PRODUCTS [OP] RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I'm writing a program for class and I am struggling. Python is the programming software we use. The task:
    User inputs-
    enter the number of mouse traps (ie. 60 is our test number)
    are you an iowa resident? (y/n)
    Outputs-
    Subtotal (ie. 115)
    Tax (ie. 0 if iowa resident is answered n, 6.9 if iowa resident is answered y)
    Total (ie. 115 or 121.9, depending on tax)
    My code so far is attached. When I run the code, I get a sytax error at the colon after if res == y:
    I'm not sure what to do to make this work. I've tried everything I know.
  2. Apr 4, 2013 at 1:19 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Clemson,South Carolina
    05 PreRunner and 2004 Lexus IS300 Sport Design
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I did python my first semester in college.
    Is raw_input("") a valid input reading code? i've never seen that.
  3. Apr 4, 2013 at 1:23 PM
    RAT PRODUCTS
    Farmington, MN
    raw_input is used when the input is a string and input is for integers.
  4. Apr 4, 2013 at 1:31 PM
    Shaowei
    Shaowei Well-Known Member
    New Mexico
    05 Tacoma 4x4 LB
    Try this:
    if res == 'y':
    blah blah blah
    else:
    blah blah blah
    The variable 'res' is a string. You need to compare it to a string. Without the quotes around y, Python considers it a variable and not a string. Hope this helps!
  5. Apr 4, 2013 at 1:39 PM
    RAT PRODUCTS
    Farmington, MN
    Tried it and I get the same syntax error. :( I'm gonna leave it like this though, since you are probably correct.
  6. Apr 4, 2013 at 1:43 PM
    Shaowei
    New Mexico
    05 Tacoma 4x4 LB
    Upon further inspection, the raw_input line in your attached image is missing a closing parentheses. I changed mine to match yours and I get the same error. Make sure you have closed off your parentheses in raw_input.
  7. Apr 4, 2013 at 1:44 PM
    travel_taco
    travel_taco Gentlemans Sausage
    CO
    09 Rust Bucket
    anti-fuel saving mods
    x2, thats what i was thinking the error could be coming from
  8. Apr 4, 2013 at 1:50 PM
    RAT PRODUCTS
    Farmington, MN
    You are correct sir! Can't believe I missed that! Thank you much.
  9. Apr 5, 2013 at 5:33 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ...also, you can add a slight bit of robustness/improvement when dealing w/ string comparisons...
    for example:
    instead of;
    if res == "y":
    use;
    if res.strip() == "y":
    the strip method will remove any leading and trailing whitespace from strings...
    also, you may want to ensure that the "case" doesn't matter;
    if res.lower() == "y":
