Project DIY: Truck-bed Pullout Kitchen (and BS)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Arlaghan, Aug 22, 2017.
  1. Sep 26, 2017 at 11:29 PM
    #81
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    T-nuts are ideal for this. Basically a washer with 3 folded teeth combined with an insert nut. You can even recess them to get a flush surface.
    Ever thought about sliding the stove part out from under the upper cabinet? Means a longer hose but avoids the flipping over hassles. Edit- might even fit between the main rails over some bottom mount glides
  2. Sep 26, 2017 at 11:31 PM
    #82
    Arlaghan
    Arlaghan [OP] Well-Known Member
    Alex
    Redmond, WA
    2017 Red TRD Off-Road
    Yeah, this was one of my earlier designs (before I started this thread). I didn't want to go through the trouble of ordering a special hose (Cook Partner uses proprietary connections) and I didn't want the additional setup of connecting the hose externally, so I tried to avoid moving the stove in relation to the propane tank. I'm lazy like that. :D
  3. Sep 26, 2017 at 11:35 PM
    #83
    Arlaghan
    Alex
    Redmond, WA
    BTW, base is completed. (Sorry, my battery died as I was about to take a picture.) I've started on building the platform to hold the ARB fridge. Due to the way it's meant to be mounted, I'll put one continuous piece of marine plywood on the left slide-out. With the fridge up front, there is enough room to fit either the Action Packer or even an Ozark Trails cooler back there (not 100% sure on the cooler, but I think it could fit). I'll get photos tomorrow.
  4. Sep 26, 2017 at 11:52 PM
    #84
    Arlaghan
    Alex
    Redmond, WA
    Bah!!! I just re-measured my Cook Partner stove and realized I made a mistake. It's not as tall as I originally measured it, which means the folding flaps won't clear the sides of the cabinet - awful glad I didn't cut any of those pieces yet. I'll have to readjust everything again in Sketchup. It won't really change the look of anything, just make the detachable cabinet slightly taller (by about 3/4").
    :facepalm:
  5. Sep 27, 2017 at 12:03 AM
    #85
    Ulysiss
    Ulysiss Well-Known Member
    Ulysiss
    La Puente, SGV
    2013 Long Bed, PreRunner, TRD Sport
  6. Sep 27, 2017 at 10:51 AM
    #86
    empheezie
    empheezie Wicket is my navigator
    mikey
    Silicon Valley
    2017 DCSB Off Road
    I have faith in you!
  7. Sep 27, 2017 at 11:33 AM
    #87
    Arlaghan
    Alex
    Redmond, WA
    Hah! Thanks. This could have been a costly mistake both in time and materials (I optimize my plywood with a cut diagram).
    Also, have I mentioned my trip to Utah is in 9 days???
    :goingcrazy:
  8. Sep 27, 2017 at 11:35 AM
    #88
    empheezie
    mikey
    Silicon Valley
    2017 DCSB Off Road
    I'm hyped for you.
  9. Sep 27, 2017 at 4:42 PM
    #89
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
  10. Sep 27, 2017 at 8:40 PM
    #90
    Arlaghan
    Alex
    Redmond, WA
    Alrighty, photos as promised. Having made the fridge platform, I have zero concerns about fitting the cooler behind it. The Action Packer fits with room to spare, almost making it feel like wasted space.
    CoachRed74, dziner, daohaus and 5 others like this.
  11. Sep 28, 2017 at 10:34 AM
    #91
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    looking really good man!
    Arlaghan[QUOTED][OP] likes this.
  12. Sep 29, 2017 at 11:47 AM
    #92
    Arlaghan
    Alex
    Redmond, WA
    I've cut all but six pieces last night. Tonight I plan to pick up some epoxy resin. Hope to get most of the assembly done this weekend. I'm starting to have doubts that the 12 gallon tank will arrive in time, so I'll have to come up with a backup plan. :mad:
  13. Sep 29, 2017 at 9:41 PM
    #93
    bagleboy
    Scott
    Norcal, Santa Rosa
    Stacked milk crates with 1 gallon water jugs?
  14. Sep 30, 2017 at 10:51 PM
    #94
    Arlaghan
    Alex
    Redmond, WA
    I'll use my 7 gallon Aqua-tainer if I have to. Was really looking forward to having the 12-gallon tank, though. :(
  15. Sep 30, 2017 at 10:59 PM
    #95
    Arlaghan
    Alex
    Redmond, WA
    Made a bunch of progress today. All the basic assembly is done. The removable cabinet and the stove cabinet still need to be a little modified so one sits over the other with a lip. I also need to cut the holes for the slam latches and drill some holes to mount these to the slides. I'm hoping to get all of this done tomorrow so I can disassemble and apply some finish. I've decided not to use epoxy resin. After reading up on it, it doesn't do well under direct UV light, so I'm just going to go with regular spar varnish. It's not like I'm building a boat or something. :D
    OK, on to the photos. This one is the whole kitchen. It's composed of three separate pieces: The fixed cabinet and tray for propane and water tanks, the removable cabinet, and the stove cabinet below it. If you look closely, you'll see the removable cabinet is slightly taller than the fixed cabinet. This is because I need to cut the lip and recess so it "locks" onto the stove cabinet. Don't pay any mind to the goofy shape of the cabinets. Apparently my phone does some wide-angle crap when I take photos.
    Here, I'm just trying things on for size. It's not attached to the drawer slides yet, I just wanted to check on clearances:
  16. Oct 1, 2017 at 12:03 AM
    #96
    bagleboy
    Scott
    Norcal, Santa Rosa
    looking good! Hope you have enough time to seal and assemble.
  17. Oct 1, 2017 at 9:09 AM
    #97
    upTOPOverland_Drew
    Drew
    Littleton, CO
    keep it coming! psyched for this!
  18. Oct 1, 2017 at 9:48 AM
    #98
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  19. Oct 1, 2017 at 9:09 PM
    #99
    Arlaghan
    Alex
    Redmond, WA
    Made a little more progress today - not nearly as much as I would like, so after I post this, I'll head back down and try to crank out some more. In any case, here's what I've got:
    How it will sit when all tucked away:
    Here you can see that the removable cabinet sits too high. Super annoyed with this because to fix it, I'll have to remove the hinged flap on the stove cabinet, tape it back on, and pass it through the table saw.
    Things are starting to take shape. I've learned it's incredibly difficult to cut stainless steel piano hinges without the proper tools. It's hard to tell in the photo, but the ends I cut look like crap. But... it works.
    I haven't installed the catch for the latches yet. I also plan to install a cable or chain to hold the door open at 90-degrees to use as a counter. I also need to cut and attach the short piano hinge for the fixed cabinet.
    With the removable cabinet gone, the front flap of the stove flips down. In hindsight, this could have stayed closed permanently. I didn't realize how much room I would have to access the knobs on the stove - turns out there was plenty of space. Oh well. I do have plans to hang something off of this, but I guess even that could have been done with a closed cabinet.
    One thing I've learned in this: The removable cabinet, while not heavy (empty) is incredibly awkward to carry and put away, so I'm going to attach handles. The only options I have are to attach them to the top (still awkward, as I'm short) or on the sides - which means one will be on the hinged door. It seems pretty strong, so I'm hoping that's fine, since that's the way I'm leaning. :D
    dziner, daohaus, Chipskip and 2 others like this.
  20. Oct 1, 2017 at 11:02 PM
    #100
    bagleboy
    Scott
    Norcal, Santa Rosa
    Better keep some Advil handy for when you move that sucker loaded.
    ScottyR and Arlaghan[OP] like this.
