Project: Jeep
Discussion in 'Other Builds' started by chris4x4, Apr 7, 2014.
  1. Sep 23, 2014 at 7:13 AM
    #281
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think this is the first time I have only had one cracked. In the past, it's always been 2 or more. And yes, it sucks.
  2. Sep 23, 2014 at 8:07 PM
    #282
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Report on the Donaldson Air filter:
    Best silica level I have gotten with the OEM filter was 11 ppm. Best ever on an OEM filter was 10 ppm (Toyota). This test was done during one of the driest times on record out here. 0" rain, and the best days had "marginal" air quality. Now.......In the past, when I ran a K&N filter, Blackstone actually sent me a note back asking if I was even running a filter at all, as the silica levels were so high. A "7 Layer" gauze filter was only marginally better (TRD, and AIrAid). AFE filter had a ppm in the hundreds (Cant remember if it was 200+ or 300+), the Donaldson filter came back at 9 ppm. 9PPM! Better then OEM, and flows better! Now, its not cleanable, but you can remove it, tap the crap out of it, and run it longer. There is a test truck out there with 150,000 miles on the same filter, and it still flows within specs. Donaldson says its good for 100,000 miles, and given my experience with them, I have no doubts. IN construction applications, that called for a 250 hour change of primary filter (And trust me, out here you change them sooner), a Donaldson filter lasted 2560 hours before failure. Yes....I ran it until it collapsed. The CAT filter I tested before that went 289 hours until the engine tried to suck it into itself. Anyone considering, or that has, and aftermarket intake, and if you want to keep your truck for a while, and off road, or live in a place with dust, THIS is the filter to run.
  3. Sep 28, 2014 at 6:57 PM
    #283
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    Didn't see a taco application
  4. Sep 28, 2014 at 7:00 PM
    #284
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Might need an aftermarket intake to use it. Give Andy at GotExhaust a call and talk to him.
  5. Sep 28, 2014 at 8:14 PM
    #285
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yo dog........I gotz litez for me litez!
  6. Sep 28, 2014 at 8:51 PM
    #286
    richardbui23
    Richard
    Arlington Texas
    Stacy
    Dawg*
  7. Oct 14, 2014 at 8:04 PM
    #287
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You need the icon coilover kit for that beast.
  8. Oct 15, 2014 at 5:40 AM
    #288
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I don't have the money for that
    The oem stuff is surprisingly doing well.
  9. Oct 15, 2014 at 6:46 AM
    #289
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    How will the oem stuff fare when you ween yourself from the malls and shopping centers?
  10. Oct 15, 2014 at 6:55 AM
    #290
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
  11. Oct 15, 2014 at 11:11 AM
    #291
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well......I've already been in the rocks, and took a pretty hard hit I'm the center when I dropped off a 3 foot vertical. The main skid pushed in about 1/8" at most. right now, I don't think I'm beating them hard enough to justify replacement, and they seem to be doing very well in the hits that I've given them
  12. Oct 15, 2014 at 12:49 PM
    #292
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Evidently, when I ordered my jeep, I check a skid plate package that's not mentioned or something. aside from the Rubicon sliders and other skid plate, I have a skid plate for the EVAP canister as well as everything else exposed underneath the vehicle.the only thing I don't have a skid plate for is the drive shaft and some parts of the exhaust. It's surprisingly well protected.
  13. Oct 15, 2014 at 12:51 PM
    #293
    Large
    Large Red
    Got any pics of the undercarriage?
  14. Oct 15, 2014 at 12:54 PM
    #294
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, e either. everyone who has looked underneath my jeep and seeing the coverage has been impressed, even other jeepers
  15. Oct 15, 2014 at 12:54 PM
    #295
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    and there's a good chance it could just be a new thing for the 2013 line
  16. Oct 15, 2014 at 1:02 PM
    #296
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I will when I get a chance. The 10a jeeps may have the same coverage. Haven't seen the underside yet.
  17. Oct 15, 2014 at 1:03 PM
    #297
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    all I know is, there's a lot of guys online that are bitching about not having a skid plate for the EVAP canister, and only having small protection for the fuel tank. I poked my head under my Jeep, & I find a skid plate on the EVAP canister, and another skid plate that starts behind the front tires, and goes all the way to the back covering the entire fuell tank
  18. Oct 15, 2014 at 1:04 PM
    #298
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    and the rock sliders that come from the factory very easily support the entire weight of the Jeep
  19. Oct 15, 2014 at 1:10 PM
    #299
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Damn there's actual life in this thread.
    On to important stuff, when's Julie dropping by here?
  20. Oct 15, 2014 at 1:12 PM
    #300
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    given the jeeps that I have seen online that have burned down, I think the fire resistance is low. However, I have not tested this
    Not sure. She's under the weather today.
