Project: Jeep
Discussion in 'Other Builds' started by chris4x4, Apr 7, 2014.
  1. Dec 22, 2014 at 9:35 AM
    #421
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    came across a group of 4x4s once trying to pull a truck out of mud ruts perpendicular to the rutted trail,using chain. Apparently it wasn't working so the pulling truck was going to take a starting run with slack chain. One of the wives/ girlfriends was there holding her baby standing 10' away watching. I loudly put a stop to that before someone got killed. first thought was eff'in idiots,but they just did not know what they were doing. likely failed physics classes.
  2. Dec 22, 2014 at 9:44 AM
    #422
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    :rolleyes: Thanks ... Damn you Sarah :mad:
    That's the scary part ... Innocent bystanders would be the ones killed or maimed. :(
  3. Dec 22, 2014 at 9:53 AM
    #423
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I don't recall saying "Please" or "sorry" just 'STOP'
  4. Dec 22, 2014 at 11:12 AM
    #424
    bzzr2
    bzzr2 Well-Known Member
    How about some build in here!!!?! I see tons of bs! My heep is due to arrive any day..
  5. Dec 22, 2014 at 12:51 PM
    #425
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :rolleyes: You're gonna be disappointed here. :sorry:
  6. Dec 22, 2014 at 2:02 PM
    #426
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Indeed
  7. Dec 22, 2014 at 3:20 PM
    #427
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :cool:
  8. Dec 24, 2014 at 8:09 PM
    #428
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  9. Dec 24, 2014 at 9:32 PM
    #429
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Dec 24, 2014 at 9:41 PM
    #430
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    That video cracked me up!
  11. Dec 25, 2014 at 12:07 PM
    #431
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Tail gate storage added:
  12. Dec 25, 2014 at 12:08 PM
    #432
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hood "Nipples" removed, and replaced with 1/2" Hillman plugs.
  13. Dec 25, 2014 at 12:10 PM
    #433
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Merry Christmas to the Jeep. Nice!
  14. Dec 25, 2014 at 12:18 PM
    #434
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Julie.....*cough*..."Gabby", also got me some Rampage locking hood latches, but i'll put those on later. Eating Turkey right now :)
  15. Dec 25, 2014 at 12:20 PM
    #435
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Julie got them for me, via GotExhaust (Andy). Andy doesn't normally carry them, but you might want to contact him and see what he says. They are CoverCraft. The version for use in Jeeps without subwoofers are a little larger in length.
  16. Dec 25, 2014 at 12:20 PM
    #436
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Gabby always has been very thoughtful. :)
  17. Dec 25, 2014 at 12:21 PM
    #437
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    She really is! :)
  18. Dec 25, 2014 at 12:34 PM
    #438
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo. Holds very securely to the tail gate too. Uses double sided tape, that, when used with the included Primer, seems to hold like it was welded to the tail gate......and instantly too.
  19. Dec 26, 2014 at 3:20 PM
    #439
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Dec 26, 2014 at 3:27 PM
    #440
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Impressive technology on these jeeps. You can add an external latch mod to keep the hood in place.
