Projector headlights on ebay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Calamity_taco, Apr 11, 2017.
  1. May 14, 2017 at 11:23 AM
    #41
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I'm running LED...OPT7 Fluxbeam
    ChadsPride likes this.
  2. May 14, 2017 at 9:42 PM
    #42
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I am currently running hid because there was rumors flying around about the leds not working too well with projectors but everything else on my truck is led so I might risk it and give it a shot. Your opinion, better or worse for output?
  3. May 15, 2017 at 1:51 PM
    #43
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Put a set in my truck on yesterday and I love the way they look. I didn't check to see if the high beans work but am going to run innovited hid's.
    Npizano, Coot83 and ChadsPride like this.
  4. May 16, 2017 at 5:10 AM
    #44
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Cool look man, what color you got on your ride?
  5. May 16, 2017 at 7:01 AM
    #45
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Avery satin khaki green
    Coot83[QUOTED] and ChadsPride like this.
  6. May 16, 2017 at 7:07 AM
    #46
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Pretty funny man that you are in va. Maybe I can see this beast sometime?
  7. May 16, 2017 at 8:59 AM
    #47
    Darkgoatracer
    Nick
    Northern VA
    Stock
    For sure. I've been asking on the nova thread if they do meet ups or anything
  8. May 16, 2017 at 9:00 AM
    #48
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Lately we have been on a Mexican fix, but I think we try to meet on Tuesdays when possible. Just throw out the invite man, Im sure peeps will be in. Where are you located anyway?
  9. May 16, 2017 at 9:07 AM
    #49
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Manassas
  10. May 16, 2017 at 9:07 AM
    #50
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah not bad man.
  11. Aug 25, 2017 at 5:08 PM
    #51
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Do any of you guys have pictures of the stock output on these headlights?
    Currently have retrofitted headlights with FX-R 3.0's but really love the look on these. I was planning on getting them and getting the retrofit kit from @TRSAndrew
