Projector Headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Colby8583, Apr 3, 2008.
  1. Apr 3, 2008 at 9:00 AM
    Colby8583
    Colby8583 [OP] Member
    Huntsville, Tx
    2007 Toyota Tacoma Prerunner
  2. Apr 3, 2008 at 1:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    as long as they are SAE/DOT approved, then thats all that matters.
    PS- if u really want those, u can get em shipped on ebay for like $180-190
  3. Apr 15, 2008 at 11:16 AM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    can you fit an hid kit in the projectors?
  4. Apr 15, 2008 at 1:29 PM
    The_Hodge
    SC
    i would hope so. to get the complete benefit of real HID kits, u need a projector headlight, IIRC.
  5. Apr 15, 2008 at 7:55 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    good looking out jhodge
  6. Apr 15, 2008 at 8:10 PM
    The_Hodge
    SC
    yeah...if the HID kit will fit in stock headlights....and stock bulbs will fit in the projectors....then they definately should
  7. Apr 15, 2008 at 8:13 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    i just confirmed this by looking at the bulb size i didn't know what the kit consisted of.
  8. Jul 23, 2008 at 6:26 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
  9. Aug 11, 2008 at 10:51 PM
    salquezada80
    salquezada80 Member
    08 prerunner access cab
    none
    Bout HID conversions. I found a site called Mod-Express. I got a kit for 240ish. I bought some H1 kit for my old civic. They look sweet. I think H4 is the taco stock bulbs. Im not sure if they fit right into the housing or if you have to mod the socket some.
  10. Nov 20, 2008 at 9:08 PM
    craziemofo
    craziemofo Member
    ontario, ca
    05 2.7 tacoma
    put in a nav system billit grill
    the housing kit that i bought (dual halo projector headlights) say not to use HID bulbs. they don't say why not to. my thoughts are that:
    1) the bulb will get to hot and could burn or melt the hoousing (don't know that much about HID bulbs so i could be worng)
    or
    2) they bulbs would be to bright and possible illegal so they don't want you to install them.
    any ideas? ot thought?
  11. Nov 20, 2008 at 10:25 PM
    salquezada80
    salquezada80 Member
    none
    Typically HID bulbs run much cooler than regular halogen. Usually, anything that is aftermarket that is not DOT approved is ILLEGAL. Cops usually know what cars came with HID stock. As long as you have them aimed correctly and they are not in peoples eyes, you should be fine. Fix it tickets arent too pricey either if you by chance happen to get pull over for your lights. I had em in my last car and no problem. If the manufacturer suggests that you dont install HID, give em a call, see what they reason is. It wont hurt to ask.
    Sal
