Projector w/Halo head light review
Discussion in 'Lighting' started by yodatoyota, May 24, 2014.
  1. May 24, 2014 at 11:10 AM
    yodatoyota
    yodatoyota [OP] Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
  2. May 24, 2014 at 11:45 AM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Do a retrofit. These are crap
  3. May 24, 2014 at 11:58 AM
    Yota64
    Yota64 Professional Threadjacker
    I think you have a lot of alternatives for less than $600...?
  4. May 24, 2014 at 12:41 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Pretty sure you can get those for about $100 somewhere else
  5. May 24, 2014 at 3:27 PM
    Yota64
    Yeah please don't spend that much, I would cry and I don't even know you
  6. May 25, 2014 at 6:13 PM
    Lpfan420
    Lpfan420 Well-Known Member
    06 base 4x2
  7. May 26, 2014 at 11:43 AM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Same pos lights
  8. May 26, 2014 at 5:46 PM
    yodatoyota
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    AWESOME! I was unaware that there was cheaper ones out there. I thought 600 was relatively cheap. guess I should do more research....
    But one more thing. So do these halo kits actually function as good headlights? as in can you actually see at night or are they just a "cool factor" type of light?
    Thanks again
  9. May 26, 2014 at 6:00 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I can't seem to find any that fit a 2012. They only go up to 2011...
  10. May 26, 2014 at 6:08 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
  11. May 27, 2014 at 2:52 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    They're terrible quality and output. Retrofit your stock lights like everyone is saying!
  12. May 27, 2014 at 3:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Had the first ones listed and they weren't all crazy bad like people are making out. The lows were brighter than oem with an H7 Philips Xtremevision halogen bulb and brights were better too. Mine did not leak. Of course I did not pay any stupid $600 for them either, more like $200 shipped. They held up fine for several years then the LEDs on one side started having short in them and was tired of LED and halo shit so just went back to BHLM oems. You can get the 2nd kind linked and they will be better than the first ones since they are HID but still with the blingy LED stuff everywhere and still not as good as retrofitting good projectors. Past a certain point, they are all just lights and it's a personal choice....my personal choice was to leave mandatory lighting Philips H4 Xtremevision halogen and HID up my optional lighting - fogs and Hella 500s. Better result than any of the other combos I've tried. Haven't committed to $600 retros and the LED H4s didn't do it for me either.
  13. May 27, 2014 at 5:41 PM
    yodatoyota
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    okay so how would one do a retofit? if I were to go that direction. do you buy a kit? or is there a tread on here that says how to do it? sorry for all the questions. I know how to change the oil and tires on my truck and thats basiclly it. Im a huuuge newb with this stuff.
  14. May 27, 2014 at 6:17 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    theretrofitsource.com and more like $300
  15. May 27, 2014 at 6:27 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Oh, so they're are moving up the to do list. Haven't looked lately.......
  16. May 27, 2014 at 7:55 PM
    Yota64
    Sub'd for this question, I am in the same boat
  17. May 27, 2014 at 7:58 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
  18. May 29, 2014 at 1:07 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The coating on these will come off easily, then you'll have disgusting oxidized lights. I've blasted the coating off with a pressure washer before.
  19. May 29, 2014 at 6:22 PM
    yodatoyota
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    Thanks for the link 808TacoMan.
  20. May 30, 2014 at 9:49 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Go to theretrofitsource.com and hidplanet.com
    Andrew at the retrofit source is great and takes his time answering questions. Hidplanet is a forum that has a lot of info that will basically walk you through the retrofit process. It's not overly difficult, just take your time. You have to heat the housings in an oven say 250° for about 5-10 minutes to pry apart the housing. Once you get the lens off, it's a matter of mounting the projector and covering it with the shroud. Then you have to seal it back up typically by reheating in the oven. Mouting the projector will vary depending on the type you are using. You also have to align the projector (up/down, side/side as well as twist) before sealing it all up.
    I did a retrofit on my former (nontoyota) truck and the light output was great. I actually started with ebay lights similar to those posted above and the light output was horrible.
    If you've never driven a vehicle with hids, keep in mind that there is a cut off of where the light doesn't shine above. Aftermarket retrofit kits tend to have sharper cut offs versus OEM. My last truck was a full size 3/4 ton and the lights were fairly high off the ground. With them properly adjusted, I would not illuminate stop or street signs and the cut off moves around as you go over bumps and dips. There is a dip near my house that the light cutoff would almost drop off to just in front of the truck with pitch black darkness beyond. That being said if I were to do it again, I'd only consider an OEM prejector lens so that there is some light 'bleed' above the cut off.
