propeller shaft bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by checksix, Apr 15, 2011.
  1. Apr 15, 2011 at 5:08 PM
    checksix
    checksix [OP] Member
    wisconsin
    black no frills
    bull bar, hitch, tonneau
    In the scheduled maintenance log it says to re-torque propeller shaft bolt. I have a 2009 reg cab tacoma 4 cyl 2 wheel drive manual, and @ the dealer and a mechanic said I didnt need to worry about this, but why is it listed? When stopping, after a momentary delay, I feel a slight push like if I had a load it just shifted forward. The mechanic said this was also normal, just the springs rocking. But with no load I wonder if this propeller shaft bolt has something to do with it. Any ideas if this really is normal?
  2. Apr 15, 2011 at 5:23 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    sounds like axle wrap...a aal will help
  3. Apr 15, 2011 at 5:58 PM
    JKD
    JKD Well-Known Member
    I tried to torque those with a crowfoot adapter on my torque wrench. Started to round off the nut...gave up. I'm going to need a box-end adapter.
  4. Apr 15, 2011 at 6:11 PM
    jandrews
    '09 FourDubDee TRD OR
    Just get a couple 14mm box wrenchs and get them good-n-tight. Unless you're a teensy tiny human being, you'll torque past the 65# torque spec of the driveshaft bolts getting them to "tight as I can get 'em".
    Just make sure they're good and snug and relax.
  5. Apr 17, 2011 at 8:32 AM
    OffroadToy
  6. Apr 17, 2011 at 8:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^
  7. Apr 17, 2011 at 8:55 AM
    OffroadToy
    How many propeller shaft bolts on the 4WD...8?
  8. Apr 17, 2011 at 9:07 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    X2 ?. I would like to be sure I have done them all when I'll do it.
  9. Apr 17, 2011 at 9:48 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  10. Apr 17, 2011 at 10:02 AM
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Dayton
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    Yes, its 8. Just did this a few weeks ago...
  11. Jul 1, 2012 at 9:40 AM
    blueshead
    blueshead New Member
    Hemet, CA.
    '12 access cab 4x4
    If your truck is two wheel drive, you won't have a propeller shaft bolt. There's probably a note on your schedule somewhere. My truck has the same bump or thump. Nothing to worry about.
  12. Jul 1, 2012 at 10:16 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just for reference a crow foot and will effect the torque reading as it adds to the length of the wrench:
    The complication with a crowsfoot on a torque wrench is that the scale is calibrated to its center of rotation (where you would normally put a socket), but the lever arm (the perpendicular distance from the center of the bolt to the hand grip on the wrench) will be longer or shorter than that depending on how you apply the crowsfoot. To make it just a bit more complicated, the more force you put on a torque wrench, the more it twists--this doesn't effect the length of the lever arm in normal application where a socket is centered on the rotation point, but when using a crowsfoot, the length of the lever arm could actually increase or decrease as the wrench starts twisting. In the example shown below, if the wrench reads 100 foot-pounds torque, the actual torque with the crows foot is 100 x 20/18 = 111 foot-pounds.
  13. Jul 1, 2012 at 2:23 PM
    JKD
    My 2wd has prop shaft bolts. I can't really imagine how it would be held on otherwise, unless it had slip joints at both ends.
  14. Jul 1, 2012 at 2:32 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yes we all have bolts. No that's not your issue. You probably don't even need to tighten.
