Proper fuse for audio system
Discussion in 'Audio & Video' started by OMAC4, Sep 18, 2011.
  1. Sep 18, 2011 at 5:58 PM
    OMAC4
    OMAC4 [OP] avidoffroad.com
    Obed
    Chandler, AZ
    2004 Tacoma sr5 access cab
    Once I finish all the currently pending mods I will update this section.
    Hey tw. I need some help determining what size fuse to use with my setup. I have a Kenwood KAC-8150D rated at 1000w max and 500w rms. I will be using 4awg power and ground wire and most likely and agu fuse and holder. Now, I have been trying to find stuff online to answer my own question, but have been running into walls with everything I try. Maybe one of you can help :D. Thanks!
  2. Sep 18, 2011 at 6:10 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    I would think 50-60 would be good I have a 50
  3. Sep 18, 2011 at 6:14 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Many are confused, as a maximum you fuse to protect the wire not the amp. The fuse should be within about 18" of the battery and before the wire goes through any metal (like a grommet from engine compartment to passenger compartment). In this use the fuse's job is to prevent an electrical fire. A 4 AWG wire should never carry more than 125 Amps of current. You can of course fuse smaller, down to the size of expected maximum amplifier draw (I am running 4AWG and my fuse is at 80 amps).
    A good read can be found at Basic Car Audio Electronics (BCAE), look in their fuse section for specific advice about wire sizing and fuse ratings.
  4. Sep 18, 2011 at 6:22 PM
    OMAC4
    Obed
    Chandler, AZ
    Hey thanks man. reading it now.
  5. Sep 19, 2011 at 6:48 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    +1 on max fusing for the power cable, but most of us should be fusing for the max amp draw that we expect to see since most power wires are oversized for the actual draw used. In your case, if you think your going to get 1000W, then the max amp draw should be between 1000W/12V=83A and 1000W/14.4V=70A, personally I would use the lower amp value as the fuse.
    FYI, I am running 0 guage wire to a 400W amp with a 30A fuse. Yes, I know the power wire is way oversized, but I only wanted to pull power wire once.
  6. Sep 19, 2011 at 8:33 AM
    OMAC4
    Obed
    Chandler, AZ
    VERY HELPFUL! Thanks!
