Proper Tire Pressure
Discussion in 'Wheels & Tires' started by bobzilla, Jun 16, 2016.
  1. Jun 22, 2023 at 3:06 PM
    #41
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
  2. Jun 22, 2023 at 3:07 PM
    #42
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    you run the max pressure? that's not what you're supposed to do
    i've been pretty bad wear on the outside edges of my front tires. Not sure if it's an alignment issue, a PSI issue, or a just a truck-thing.
  3. Jun 24, 2023 at 12:58 PM
    #43
    rickabillie
    rickabillie Member
    2007 Tacoma 93 Truck
    So I just got some used (guessing %70 left) Michelin LT245/75/16 for about $250.
    From reading the thread I think I'm going to go to the 29lbs recommendation on the badge.
    07 Taco double cab 4l
    Hard roll top, with a rack
    I carry maybe #200 of tools regularly
    My two girls and I are the common passengers.
    I carry up to #300 on the rack occasionally with maybe an extra #100 in the bed once or twice a month.
    Should I make any adjustments for the LT tires or for what I carry?
    Also, I got new sensors on Amazon which work until I get on the highway, then I have to use the tire shop reset, so I think one is bad, can I register the TPMS myself, if I have a bad sensor and have to swap?
  4. Jun 24, 2023 at 2:40 PM
    #44
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If your stock tire was a P245/75/16/109 @ 29 psi, your adjusted pressure for a LT245/75/16 is 41 psi.
  5. Jun 24, 2023 at 2:50 PM
    #45
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
