Proper tire pressure
Discussion in 'Wheels & Tires' started by ryker, Nov 18, 2017.
  1. Nov 18, 2017 at 10:33 AM
    ryker
    ryker [OP] New Member
    Wilburn
    2013 Toyota Tacoma V6 TSS Sport Series
    None
    I just bought a 2013 Toyota Tacoma V6 TSS Sport Series. This is the cleanest used vehicle I have ever seen. One owner with 79,000 miles. All tires are new Good Year Wrangler 265/65R17 112 T. the pressure shown on tires is 51PSI. This is not what the manual calls for and it rides sort of rough. The truck has the tire pressure warning system.
    What pressure should I use? any assistance will be appreciated.
  2. Nov 18, 2017 at 10:38 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Look inside your driver's door jamb it tells you the correct tire pressure for the 265/65/17 tires
  3. Nov 18, 2017 at 10:45 AM
    ryker
    Wilburn
    None
    Thanks, Unchained. Found it in the door jam.. Have a fantastic day.
  4. Nov 18, 2017 at 10:48 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Anytime that's what we are all here for
  5. Nov 18, 2017 at 10:51 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The pressure on the tires is the MAX (for heaviest load ability) and since tires are used on different vehicles, you need to adjust for your vehicle and your load. The door jam numbers are a place to start IF the tires are the ones the truck was sold new with.
    The true way to judge the pressure is to perform the CHALK TEST!
    https://www.tacomaworld.com/threads/chalk-test-dynapro-atm-at-16-000-miles.226635/
  6. Nov 18, 2017 at 10:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sidewall max pressure is never the operating pressure.
    Do what @Unchained 5150 says.
    Then do a chalk test on the tread and tweak as required, assuming your alignment is correct.
    Unchained 5150 likes this.
  7. Nov 18, 2017 at 10:53 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Correct just did that chalk test myself with my new different size tires. But I would bet since he put the same size tires on the stuck tire pressure will be just fine
    Clearwater Bill likes this.
  8. Nov 18, 2017 at 10:55 AM
    David K
    Different tires have different air needs... even if the same size.
  9. Nov 18, 2017 at 11:26 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
