Propper Extended Lug Nuts (ET) for aftermarket wheels (Pro Comp 01 Series in this case) on Tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mark1285, Mar 14, 2017.
  1. Mar 14, 2017 at 6:35 AM
    mark1285
    mark1285 [OP] Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    Have done a ton of reading and it took me until today to figure this out completely and make me happy.
    Bought ProComp wheels 17x8 for my new Tacoma, got given your standard lug nut (conical for off road wheels). Was not thrilled at the centering and thread engagement when I tightened them up. I got 4 full turns but i would prefer a little more, and it seemed I had to make more turns than I was used too as i tightened the wheel to 90ft-lbs. Also it seemed that the lugs had a lot of threaded space remaining behind the conical seat.
    Kept reading about wheels and tires and came across an Amazon review about ET (Extended Thread) Lug nuts for these wheels and immediately knew that they were probably what I needed.
    https://www.amazon.com/12x1-5-Close...1&sr=1-37&refinements=p_6:A2A65CUIZM9PM8&th=1
    So I ordered a set and will be installing them shortly. I'll report back if they in fact seem better.
    I'm willing to bet that a lot of people on here will be wanting to change their lug nuts on their after market wheels to something with this shape. Should avoid the pinching and wear you can get as the wheels tighten.
    I believe this setup along with the very tightly matched Bore on my ProComp wheels vice my toyota (108 vs ~106.5) will give me an OEM quality Hub Centric Mount up all around. Agree? Disagree? Anything wrong with my logic? Hope this helps someone like me somewhere trying to get everything right.
  2. Mar 14, 2017 at 9:33 AM
    Jlg24
    Jlg24 Well-Known Member
    Louisiana
    I used gorilla lug nuts e/t long shank from wheelers off-road. They put my
    Pro comp wheels where they should be. I've had zero issues and they came in black. Also a plus that you can order individual lug nuts so it's easy to get the exact number you need, plus they had the best price I could find.
    YotaDan and T4RFTMFW like this.
  3. Mar 14, 2017 at 9:34 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    X2.
    @YotaDan
    Jlg24[QUOTED] likes this.
  4. Mar 14, 2017 at 10:21 AM
    obz
    obz Well-Known Member
    Utah
    2017 Silver Sky TRD Sport 4x4
    X3
  5. Mar 14, 2017 at 2:53 PM
    mark1285
    Mark
    Great that apparently some people knew these were the right lug nuts. My local shop didnt seem to have a clue about it. But i also got 3 1/2-20 lugs out of the batch that were supposed to be all metric so go figure. Gotta take care of every little thing yourself.
  6. Mar 14, 2017 at 2:55 PM
    mark1285
    Mark
    From Wheelers:
    These nuts are a little harder to find at tire or parts stores, they feature an extended thread section/centering barrel that increases thread contact and helps center the wheel even better than a standard acorn style nut. Not all aftermarket wheels will be able to use this type of nut with the extended thread section/centering barrel, check the dimensions in the image to determine if these are correct for your wheels.
  7. Mar 21, 2017 at 7:02 PM
    WZ KTM
    WZ KTM Member
    Colorado
    17 TRD OR
    OME/Dakar SPC LR 285/75/16
    Rockefelluh likes this.
  8. Mar 21, 2017 at 10:51 PM
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    What is the proper lug nut thread pattern and lug style for our factory wheels?
  9. Mar 21, 2017 at 11:05 PM
    Metonymy
    None (yet)
    Thank you. Going to replace the silly chrome lug nuts on my Pro. Why Toyota didn't include black ones baffles me.
    Sucky that I have to buy two sets though to get the 24 since they are sold in sets of 20. Ugh.
  10. Mar 22, 2017 at 12:14 AM
    duckytw
    duckytw Well-Known Member
    Or 1 set and a set of matching wheel locks
  11. Mar 22, 2017 at 12:49 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  12. Jun 4, 2021 at 8:03 PM
    cjc208
    cjc208 Well-Known Member
    CJ
    Boise, ID
    2017 Tacoma SR Access Cab 2.7l 5speed 4WD
    265/75/16 goodyear duratrac, 16" sr5 anthracite wheels CBI Baja Front bumper / skid plate
    old thread but can anyone tell which lug nuts I need when changing from stock steel wheels to aftermarket? I just purchased a set of these from a local guy
