Protecting back of rear seats ...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aaronb43, Aug 19, 2007.
  1. Aug 19, 2007 at 6:15 PM
    aaronb43
    aaronb43 [OP] Well-Known Member
    Edmonton AB Canada
    07 SR5
    ... when the seats are folded down. Has anybody come up with a novel idea? I am trying to find a material to lay on the back of the seats to prevent objects from sliding etc..
  2. Aug 20, 2007 at 7:44 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    My solution is a towel...... i'm not as innovative as pb2themax though, i'm sure he has installed some kind of griptape coated titanium plates on the back of his seats using some kind of technology i've never heard of...
  3. Aug 20, 2007 at 8:30 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    And I'm a sh!t disturber????:p
  4. Aug 20, 2007 at 10:08 AM
    Manofs
    Manofs Well-Known Member
    hey maverick, where did you get your extra set of D rings, i have been trying to find some and have had no luck. did you have to go back to the dealer
  5. Aug 20, 2007 at 10:41 AM
    nd
    Nate
    Greenville, SC
    yes you are, now stop disturbing the sh!t!!! ;)
  6. Aug 20, 2007 at 11:20 AM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    Try the grey rubbery stuff you use to line the trays of your tool box. It is cheap, doesnt let things slide around, and is easy to cut. You can get it ant any store that sells shop supplies.
  7. Aug 20, 2007 at 3:13 PM
    maverick491
    South Jersey
    I got the D-rings from toyotapartspeople.com
    The actual link to the part is in this thread as well as a discussion about mounting options and the detailed write up of my install
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/2269-bed-tie-downs.html
