PS78 Build
Discussion in '2nd Gen. Builds (2005-2015)' started by PS78, Jun 10, 2011.
  1. Jan 27, 2015 at 8:41 AM
    #301
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Watch it with that stuff. Homer just had problems last weekend with his Moog parts
  2. Jan 27, 2015 at 8:49 AM
    #302
    PS78
    PS78 [OP] I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    what problems did homer have with his kit? wrong parts or what?
  3. Jan 27, 2015 at 8:51 AM
    #303
    NC15TRD
    Nick
    PA
    I just saw his post that he was having trouble with his cams and such. Said he'd go OEM and maintain them better would be better
  4. Jan 27, 2015 at 8:52 AM
    #304
    NC15TRD
    Nick
    PA
  5. Jan 27, 2015 at 9:21 AM
    #305
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Yeah I checked that part as well while under there. No notches like yours have.
    Phil I can hear the sound and I replayed the video multiple times looking at different parts and I can't see anything out of the norm. Gonna need to take it to a tech to look it over.
  6. Jan 27, 2015 at 9:24 AM
    #306
    PS78
    Rancher
    2011 DCSB TRD OR
    thanks eric, my plan of attack as it sits is to have brian look at it in a couple weeks after i installed the new UCA's and need an alignment and 295's mounted balanced :D
    If i need to get new bushings this summer than so be it, ill deal with that when the time comes but yeah id love to actually have a tech look at it, i left the gopro mount on my frame just in case too, and can get another to mount in front tomorrow.
    I wanna say this is the best plan of attack
  7. Jan 27, 2015 at 9:30 AM
    #307
    PS78
    Rancher
    2011 DCSB TRD OR
    bumping this to the last page
    Ok, i am in need of some help. Im having some funky sounds coming from my front end suspension items.
    Sound really started accuring after the gulches trip with some of you, i noticed it while on first parts of the trail where my suspension was cycling pretty heavily from side to side.
    Since then ive been hearing the sound while hitting a water runoff dip in my neighborhood while turning, this morning i put a GoPro just above the cab mount and drove straight over the water runoff dip and then turned around and repeated 3 times.
    Sounds are at
    :10 seconds (just before starting the truck)
    1:22 seconds (hitting water runoff dip)
    1:49 seconds (hitting water runoff dip)
    2:16 seconds (hitting water runoff dip)
    Anyone with insight its greatly appreciated!!
    https://www.youtube.com/watch?v=UxSRKO2Azjk&feature=youtu.be
  8. Jan 27, 2015 at 12:08 PM
    #308
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Not too sure about the last three, but look at the close end of you LCA at 0:10. It looks like it pops out or something when that clunk noise is heard. I watched at the other times (sounds like different noise) and it seems that your LCA moved a little at the same spot, but that may just be a coincidence.
    Possibly a loose bolt or bad bushings? I dunno.
  9. Jan 27, 2015 at 12:12 PM
    #309
    PS78
    Rancher
    2011 DCSB TRD OR
    yeah the movement at :10sec is the most movement of the LCA close to the cab with the popping into place. That was just me getting back into the truck as well just before putting it into gear.
    Im not convinced its my LCA bushings just yet either. Im going to mount a GoPro up front looking back on the UCA and see if i cant track down the noise to the UCA area.
  10. Jan 28, 2015 at 8:36 AM
    #310
    PS78
    Rancher
    2011 DCSB TRD OR
    Sounds are at
    :10 seconds
    1:22 seconds
    1:49 seconds
    2:16 seconds
    I also posted this video in my build thread to try and keep my thoughts together over in that thread.
    https://www.youtube.com/watch?x-yt-cl=84924572&x-yt-ts=1422411861&v=UxSRKO2Azjk
    Video 2 looking at the UCA from the front fender wall looking towards the cab
    (my initial thoughts were its coming from the LCA, but looking at this angle there seems to be a lot of body flex on that forward section of frame mounts) Lower left of video every time the noise happens. Frame mount bushings? who knows
    sounds at
    :20sec
    :34sec
    1:30sec
    1:58sec
    2:23sec
    https://www.youtube.com/watch?v=gEKsN5npdvE
  11. Jan 28, 2015 at 7:46 PM
    #311
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    cant really make out what kind of noise it is from a video pretty hard to diagnose it without seeing it
  12. Jan 28, 2015 at 8:11 PM
    #312
    PS78
    Rancher
    2011 DCSB TRD OR
    That's the thing, I can't recreate the noise unless driving, no rub marks showing, removed sway bar when installing the front bumper wondering if I need to put it back on?
  13. Jan 28, 2015 at 8:58 PM
    #313
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Hey Phil I don't know if this will help or if you even tried doing this but try and cycle you axle. Basically put that side up on a jack stand and place a floor jack underneath your LCA and jack it up and down. See if you could recreate the sound. In the video you have a lot of moving parts. Try moving all the parts manually one at a time. Maybe you might find the noise. It's worth a try.
    Edit maybe I should of read your pervious post before posting. I was just so into the vid. vvvv but Gramps brings up a good point about the bumper bolts.
  14. Jan 28, 2015 at 8:59 PM
    #314
    Gramps
    Gramps
    07 TRD DC 4x4
    Now that you bring up frame flex and that second video it sounds more like Aluminum. I bet it is those frame supports that came with the Pelfry bumper with that funky bolt going through the frame. I bet they aren't tight enough!!!!
  15. Jan 28, 2015 at 9:49 PM
    #315
    PS78
    Rancher
    2011 DCSB TRD OR
    I thought about frame flex but the GoPro was mounted to the underside of the wheel well and that was flexing and made it look like the frame was flexing, understand?
    I'll try and tighten bolts all over the front end tomorrow though!! Thanks for the help fellas
  16. Feb 13, 2015 at 6:05 PM
    #316
    PS78
    Rancher
    2011 DCSB TRD OR
    Getting prepped for next weekend.
  17. Feb 13, 2015 at 6:22 PM
    #317
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Well hello sexy..... :D nice Phil.
  18. Feb 13, 2015 at 6:56 PM
    #318
    Gramps
    Gramps
    07 TRD DC 4x4
    BJ is backwards...
  19. Feb 13, 2015 at 7:01 PM
    #319
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Is this related to the mystery noise?
  20. Feb 13, 2015 at 7:48 PM
    #320
    PS78
    Rancher
    2011 DCSB TRD OR
    Ball joint is installed per instructions with SPC out, am I really backwards?
