PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 25, 2018 at 5:54 PM
    #2061
    Forge
    Forge Well-Known Member
    Rick
    You looking to put spacers in front? Your rake still about 1.5?
  2. Feb 25, 2018 at 5:56 PM
    #2062
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    I have the Wheeler's 5 leaf heavy duty pack.
  3. Feb 25, 2018 at 5:59 PM
    #2063
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    Going with .75" BORA spacers all around because I am putting 255/85-16s on and I'm looking for just a little additional UCA clearance. Rake seems to be holding firm at about 1.5". I'll check it again after I get the spacers/tires on and an alignment done.
  4. Feb 25, 2018 at 6:00 PM
    #2064
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    thanks! i did Baja Design Squadron sports
    all plug and play...i did a vid on it :thumbsup:
    DavesTaco68 and SC4333[QUOTED] like this.
  5. Feb 25, 2018 at 6:00 PM
    #2065
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    How much lift did that leaf give you...pic??
  6. Feb 25, 2018 at 6:01 PM
    #2066
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    I'm up in Bel Air, MD. Should be installing mine in the next few weeks. I also have a lift in my garage. :)
  7. Feb 25, 2018 at 6:03 PM
    #2067
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    I measured today to compare what I took a few days after and it's about the same. I've added 200 miles between the 2 checks and full tank of gas on both occasions as well.
    ZekeR7[QUOTED] likes this.
  8. Feb 25, 2018 at 6:05 PM
    #2068
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I guess I’ll be that guy, I preferred the stock OR suspension for everyday on road driving. Although I do love the improved aesthetics.
    Not saying I hate the ride of the Pro kit, but as much as I don’t miss the body roll and nose dive of the stock setup, I do miss the soft/plush ride.
    I’ll run these for a while, but unless my disposition on the setup changes (and assuming I still have the truck when the time comes), I’ll likely be swapping out to some Kings of a Fox setup.
  9. Feb 25, 2018 at 6:06 PM
    #2069
    Jon8251
    Jon
    Southern MD
    That will make the install go much easier
  10. Feb 25, 2018 at 6:07 PM
    #2070
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Bumper swap will fix that. It's stiffer due to the spring rate change. Stocks has 550# rating and these have 600# rating. Also, some people were ordering kits from ebay that were the Baja kit thinking they were the pros and those are way stiffer with 650# rating. You would get that plush ride again once you add appropriate constant weight.
    oscolivar1 likes this.
  11. Feb 25, 2018 at 6:11 PM
    #2071
    backcountryj
    Jonathan
    GA
    Lucky you. Makes sooooo much easier.
    I knocked my install out yesterday at a local mod day with some other members. We did everything at a members shop with a lift. Total install took about 5hrs (and plenty of BSing), front/rear and ECGS bushing replacement.
  12. Feb 25, 2018 at 6:16 PM
    #2072
    backcountryj
    Jonathan
    GA
    I was aware of the spring rates. And I knew it would be slightly more firm than stock. I did my homework before buying.
    The digressive valving of the massive shock adds to the firm ride. That’s why I’ll end up going King/Fox, progressive valving.
    My response was meant more to answer the numerous people asking for real world feedback.
  13. Feb 25, 2018 at 6:18 PM
    #2073
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I put on the SSO slimline bumper with the 600lb spring and it changed the ride...it was way to soft. It went back to nose diving and I fell the suspension was almost bottoming out on putholes etc. Switched to 650 spring and it was a perfect!
    I will add that I have the 6112 but it almost the same so...just my 2 cents.
    Tibetan Nomad likes this.
  14. Feb 25, 2018 at 6:23 PM
    #2074
    ZekeR7
    I ordered Demello's new Aluminum bumper that is about 10# heavier than slimline w/ a 50# winch. Hopefully that doesn't bottom it out, but honestly I don't feel the nose diving in my stocks right now. What brand of springs did you end up getting? If it starts bottoming out, when I get the bumper, I will swap over.
    oscolivar1[QUOTED] likes this.
  15. Feb 25, 2018 at 6:31 PM
    #2075
    Forge
    Rick
    Hey BC...before I bought these I was going to go with Bil5100 and crank to level...from what you have read and this kit would you choose these over the Bil5100/
  16. Feb 25, 2018 at 6:37 PM
    #2076
    backcountryj
    Jonathan
    GA
    Yes I would still buy these over 5100s, but that’s just me. For a budget/entry level pricing lift, this kit is about as good a value as can be had right now.
    Forge[QUOTED] likes this.
  17. Feb 25, 2018 at 6:41 PM
    #2077
    North222
    North222 Well-Known Member
    Thanks for the honest review! I would love the look and performance of this kit, but hate to sacrifice what I consider to be a decent ride (although mine is a 2014 with the OR suspension). Most of my travels are on roads and highways and I like the comfort of the stock shocks. How does your setup feel going over potholes and railroad crossings? Have you done any washboard roads?
  18. Feb 25, 2018 at 6:42 PM
    #2078
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    You might be okay, take it for a ride and see how you like it, it probably wasn't bottoming out, I can just feel that the added weight was really pulling me down on some of the roads I've encountered.
    I also lost .25" of lift if that bothers you at all. If your planning on adding more weight up front like sliders, battery, winch etc I would just make the switch...I bought 650lb Eibach springs for 190 and sold the 600lb springs for 100.
    https://www.tacomaworld.com/threads/bilstein-6112.421995/page-53#post-16991045
    Heres a review on the 650 switch. I will also add that I just added mobtown offroad slider which is 140lb and it dropped the front a little less than a .25" which I'm okay with as it gives me more rake and makes the ride better imo. IMG_1916.jpg
  19. Feb 25, 2018 at 6:49 PM
    #2079
    backcountryj
    Jonathan
    GA
    Most of my driving these days is on road as well. Time will tell how long this kit stays on my truck. The ugly ass red coils don’t help.
    Honestly I haven’t put enough miles to give you solid feedback regarding railcrossings, potholes, washboard, etc.
    I’ve put about 50 miles on the truck since finishing up the install yesterday. Barely enough miles to say it’s a firmer ride and I’m not super stoked on that, but it looks great.
  20. Feb 25, 2018 at 6:51 PM
    #2080
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    You saying the overload should bend backwards?
