PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Jan 30, 2018 at 8:04 PM
    #201
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    Whatever helps you make your future suspension purchase justifiable. :thumbsup:
  2. Jan 30, 2018 at 8:07 PM
    #202
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    See, your confusing what you want with what others want. Not everyone needs or wants to have a sky high truck.
    Big Dustin, Deucer01, Skydvrr and 3 others like this.
  3. Jan 30, 2018 at 8:12 PM
    #203
    TPC
    TPC Well-Known Member
    TIM
    DELAWARE
    2017 DCSB TRD SPORT
    There is also still the option to add the toytec coil spacer shim for another 1.5 inches. This is no different than adjusting the clips on a 6112. $180 on the spacer set and you are still $250 cheaper than the bilstein 6112/5160 set.
    bladsville likes this.
  4. Jan 30, 2018 at 8:13 PM
    #204
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    This shock/strut/coil is a huge upgrade from the 3rd gen stock suspension. Side by side it's waaaaaay beefier and the shocks are much higher quality.
    It's nearly the same as the 6112/5160 setup which is an upgrade of 5100 Which themselves are an upgrade over stock.
    I think your opinion leaves a lot to be desired.
    Lots of people want to level their truck a little and add another inch or two of clearance and not deal with vibrations or other issues.
    sdsurfer, Forge and bladsville like this.
  5. Jan 30, 2018 at 8:13 PM
    #205
    i_cappi
    Canton, Oh
    Your right, but it's what I HAVE not what I want or hope to get. But I've seen time and time again this exact setup being swapped out for something more capable. There isn't many Pro owners that run this and are still happy with it. Especially the front. 5160's Are pretty decent out back though even lifted.
  6. Jan 30, 2018 at 8:17 PM
    #206
    Lt. Dangle
    Ohio
    Lots of third gen pro owners swap out the fox's for something better. There is always something better, but to some the best is not the overall goal, just better. Some of us aren't looking for much, and at the price these are being blown out at its worth a shot. Some may move on, others may not.
    Skydvrr, Dylla34 and i_cappi[QUOTED] like this.
  7. Jan 30, 2018 at 8:17 PM
    #207
    i_cappi
    Canton, Oh
    I will apologize too you guys though. I'm in here quarreling about something I'm not interested in.
    And I do run 5160's out back with Dakars and I'm just mixing what I went through on suspension myself.
    Skydvrr, 09 Redneck and Lt. Dangle like this.
  8. Jan 30, 2018 at 8:19 PM
    #208
    TRD-OffRoad_Ben
    TRD-OffRoad_Ben Well-Known Member
    Ben
    2016 TRD OffRoad LB
    Does anyone no The spring weight on these?
  9. Jan 30, 2018 at 8:23 PM
    #209
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Where do the rear resis mount?
  10. Jan 30, 2018 at 8:24 PM
    #210
    i_cappi
    Canton, Oh
    Thier clamps that bolt into factory holes, literally takes minutes.
  11. Jan 30, 2018 at 8:29 PM
    #211
    Lt. Dangle
    Ohio
    I saw it in my research but can't find it now, but i'm thinking it was 550# or 600#.
  12. Jan 30, 2018 at 9:43 PM
    #212
    tow-coma
    tow-coma Well-Known Member
    So now you have two settings instead of the 5 you get with real 6112. I don't see the savings. If you buy from ARC, it's about 100 difference
  13. Jan 30, 2018 at 10:04 PM
    #213
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    Can we just all get over the back n forth and hear from someone who actually put this on a 3rd gen and got measurements?
  14. Jan 31, 2018 at 9:08 AM
    #214
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    I’m curious about this as well. Everybody references the 3rd gen as being 1” higher than 2nd gen. I just measured a 15 compared to 17. I measured ground to frame in 2 different spots and both were the same with same size tires. Measured installed coil length from top mount to lower bolt and both were the same. Everyone references center hub to fender height which will be different between the gens since the fenders are different.
    I’m contemplating ordering the kit for my 16. It would be 620 after taxes from my dealer. Might wait another week and see if anyone has real world install numbers
  15. Jan 31, 2018 at 9:09 AM
    #215
    tow-coma
    we're just going by what Mike "Seatbelt" Sweers told us when the truck came out....
  16. Jan 31, 2018 at 9:11 AM
    #216
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Haha it's not about the lift... at least it shouldn't be. I roll on Kings with less than 1" lift up front, stock height rear and 265s. Is a way better setup than 3" 285s for what I do with my truck.
    nevadabugle, wyant and Sharpish like this.
  17. Jan 31, 2018 at 9:13 AM
    #217
    i_cappi
    Canton, Oh
    The Only scenario that's better is if you dont wheel.
    I'm sure the street cred is worth it for 2k. :rolleyes:
  18. Jan 31, 2018 at 9:21 AM
    #218
    Doggman
    Alabama
    2017 TRD OR MT
    Meh. If wheeling only includes extreme crawling where approach angles are everything then yeah sure. Otherwise, no. I didnt get my Tacoma as a dedicated crawler...not many do. Skipping the lift gets almost all of the performance while being way better on road. Sure you don't get the look but thats not what its about to me.
    TRD-OffRoad_Ben and schultzj01 like this.
  19. Jan 31, 2018 at 9:24 AM
    #219
    i_cappi
    Canton, Oh
    Well what's it about then? You'd get the same performance out of this kit for a 1/4 of the money you spent. Doing whatever it is you do.
  20. Jan 31, 2018 at 9:47 AM
    #220
    Doggman
    Alabama
    2017 TRD OR MT
    It's about suspension performance. The suspension isn't there to create ground clearance. It's there to maintain stability over rough terrain. As far as comparing Kings to this kit, I'm gonna refrain in this thread.
    schmack b and PNW/TRD Steve like this.
