PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Mar 5, 2018 at 10:04 AM
    #2341
    Sev
    Sev Well-Known Member
    Burbank CA
    2017 DCSB TRD OR 4x4
    Wrapped up the install yesterday. HeadStrong aal and a 1/4” spacer up front. Hardest part by far was getting the brake line spacer to line up.
    The following numbers were taken on stock wheels and tires.
    Before:
    l/f- 34 5/8
    r/f- 34 7/8
    l/r- 35 7/8
    r/r- 36 3/8
    After 30 miles:
    l/f- 37 1/2
    r/f- 37 1/2
    l/r- 37 7/8
    r/r- 38 1/2
    Like everyone has said ride feels slightly stiffer on the road but not bad.
  2. Mar 5, 2018 at 10:07 AM
    #2342
    RadoTaco
    RadoTaco Well-Known Member
    Justin
    18' Tacoma DCSB TRD OR White
    @Sev Overload in or out? Also what size tires?
    Looks awesome!
  3. Mar 5, 2018 at 10:28 AM
    #2343
    Sev
    Burbank CA
    Overload in. 265/70 17 ko2’s
    Thanks
    RadoTaco[QUOTED] and Rocky.Mtn like this.
  4. Mar 5, 2018 at 10:36 AM
    #2344
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    @Sev looks awesome! This was my plan with 0.25" Spacer and Overload in. Any issues with clamp install from the AAL?
    You've got a lot of lift there! Keep us updated on the settling please.
    RadoTaco likes this.
  5. Mar 5, 2018 at 10:45 AM
    #2345
    Sev
    Burbank CA
    Thank you. Do you mean the factory spring clamps? If so I had to cut them off. Otherwise the install went smoothly. It helps to mount the jackstands as high as possible so you can drop the diff lower to give yourself room.
  6. Mar 5, 2018 at 10:47 AM
    #2346
    Rocky.Mtn
    Canada
    Exactly - how many clamps did you end up having to cut? Angle grinder?
    Thanks for the tips.
  7. Mar 5, 2018 at 10:52 AM
    #2347
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Bilstein can but no point unless they replace the body.
    However someone may want those extenders. Those things are pricey.
  8. Mar 5, 2018 at 11:03 AM
    #2348
    Sev
    Burbank CA
    The rear clamp definitely needed to be cut. I may have gotten away with the front but cut that too. Yes, grinder with a flap disc then pry the clamp open and off. Then ground down the rest of the rivet.
  9. Mar 5, 2018 at 11:37 AM
    #2349
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    I just did the rear on mine but yea it's close on the front.
    I'm digging those F5s you got.
    Sev[QUOTED] likes this.
  10. Mar 5, 2018 at 12:00 PM
    #2350
    Forge
    Forge Well-Known Member
    Rick
    Which spacer did you buy for the driver side?
  11. Mar 5, 2018 at 12:05 PM
    #2351
    Sev
    Burbank CA
    Thanks.
    1/4” from headstrong on both sides.
  12. Mar 5, 2018 at 12:11 PM
    #2352
    Forge
    Rick
    Ahh...without the spacers would you have been same height on L/F and R/F? Some people get the lean on driver side some have not.
  13. Mar 5, 2018 at 12:14 PM
    #2353
    Sev
    Burbank CA
    In theory I would have been 1/2” lower but who knows. Yes some people are still getting a lean even though the coils are set on different levels.
    Forge[QUOTED] likes this.
  14. Mar 5, 2018 at 12:16 PM
    #2354
    Forge
    Rick
    Yeah I have HS AAL on the way (hope it will be in the mail sooner or later)...wondering if I should go ahead and order spacer...I hate reworking something...Not sure if there is an easy way to add spacer after the fact.
  15. Mar 5, 2018 at 12:18 PM
    #2355
    Sev
    Burbank CA
    You would have to remove the coilovers again. If you want a spacer I”d order it and do it all at once.
  16. Mar 5, 2018 at 12:23 PM
    #2356
    Forge
    Rick
    To install the spacer it just sits on top of shock...no need to mess with spring?
  17. Mar 5, 2018 at 1:44 PM
    #2357
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    I almost got there.
  18. Mar 5, 2018 at 1:48 PM
    #2358
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Thanks! Seems like 1.8 is the magic number. How does it drive at 1.8?
  19. Mar 5, 2018 at 1:49 PM
    #2359
    Forge
    Rick
    Are you level in front or is driver side little lower?
  20. Mar 5, 2018 at 1:54 PM
    #2360
    wjrichardson
    WI
    2017 TRD/OR/AC
