PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Mar 10, 2018 at 12:38 PM
    #2421
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You drill holes all the way around in the rubber,and then just knock out the remaining rubber with a screw driver and hammer.Easy
  2. Mar 10, 2018 at 1:35 PM
    #2422
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    The fronts are side specific. The driver's side perch sits higher to correct the "taco lean". They are labeled LF and RF. There are only 3 hardware bags in the kit. One bag is for the rear brake line and two are for the rear reservoir mounts.
  3. Mar 10, 2018 at 1:39 PM
    #2423
    93truck
    93truck Well-Known Member
    Jon,
    Thank you greatly for the reply. Can you please check out my pics and let me know if these are20180310_145904.jpg 20180310_145905.jpg correct/incorrect?
  4. Mar 10, 2018 at 1:42 PM
    #2424
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  5. Mar 10, 2018 at 1:44 PM
    #2425
    93truck
  6. Mar 10, 2018 at 1:45 PM
    #2426
    Lt. Dangle
    Ohio
    Where'd you get your kit from?
  7. Mar 10, 2018 at 1:48 PM
    #2427
    93truck
    Dealer in Fairfax, OFT
  8. Mar 10, 2018 at 1:54 PM
    #2428
    Jon8251
    Jon
    Southern MD
    If you bought it from the dealer then they should be able to make it right.
  9. Mar 10, 2018 at 1:58 PM
    #2429
    93truck
    Hoping the fact that it is a discontinued kit does not cause any issues with getting the right part/spring
  10. Mar 10, 2018 at 2:24 PM
    #2430
    Jon8251
    Jon
    Southern MD
    I think you'll be the first one on here to test the availability of individual parts since they discontinued the kits. Good luck and let us know how it works out.
  11. Mar 10, 2018 at 2:36 PM
    #2431
    93truck
    Hopefully all others with the kit checked the part numbers prior to doing anything, I hope people didn't install with mismatched parts. I will def report back with info i receive, thanks again for the prompt reply.
  12. Mar 10, 2018 at 3:02 PM
    #2432
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    Dang it, I got to go check!
  13. Mar 10, 2018 at 3:11 PM
    #2433
    MikesORTaco
    MikesORTaco Member
    LV NV
    Quicksand TRD OR
    I had the Bilstein Pro kit installed (Goodyear Tire) a few days ago with the headstrong progressive AAL on my 17 OR DCSB. I left in the overload leaf. Some thoughts after 300 miles:
    Lift/'levelness':
    On the driver's side the truck as a difference of ~1.25" between front and rear (rear high). The passenger's side has a delta of 2.25" with the rear an inch higher on pax side than driver's side. Gas tank is full. I'm hoping that over time it balances out - I QC'd the install and everything is similar on each side - no obvious reason for the extra 1" on passenger rear.
    Ride quality:
    Like everyone else says, you 'feel' more through these shocks/struts. It isn't harsh at all, feels great in turns, no more floating. You feel minor things through the steering that weren't apparent w/ stock suspension. Over big potholes or a string of uneven/poorly maintained pavement the suspension really dampens everything out a lot better than the stock OR. Overall, I am very pleased with the change. I plan to take it off into the desert tomorrow - I would guess I'll be similarly thrilled.
    Post-install issues:
    I have a minor vibration accelerating between 6-12 mph. I crawled under the truck this afternoon to check U bolt torque and found one side was loose. I tightened that and took it for a spin again and I'd say 50% of the harshness is gone. Goodyear installed what looks like 2 degree shims, I think, hard to tell. ***edit: turns out the shim is stock, they didn't add anything.*** I am going to drive the truck around another week and start messing with washers and carrier bearing. After the install/lift, the steering was canted to the left and obviously out of whack a bit. I drove like that for ~250miles and took it to my dealer for alignment today. Truck now drives perfect, minus the vibration.
    Rob Daman likes this.
  14. Mar 10, 2018 at 3:21 PM
    #2434
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Any chance that they installed the shocks on the wrong side? Driver's side shock has the spring set at a different height to account for the taco lean
    Taco crazy and na8rboy like this.
  15. Mar 10, 2018 at 3:25 PM
    #2435
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Is the front same left to right? (Height)
  16. Mar 10, 2018 at 3:26 PM
    #2436
    MikesORTaco
    MikesORTaco Member
    LV NV
    Quicksand TRD OR
    I don't think so, it is my understanding the fronts are the only ones that are different, right? Both fronts seem to be sitting roughly level, close enough there isn't a significant difference. It's only the back right that looks bizarro.
    When I see the truck from that side I think I want to take out the OL. When I see it from the other side, I'm happy. When it finishes settling perhaps there will be more reason to drop the OL.
  17. Mar 10, 2018 at 3:29 PM
    #2437
    na8rboy
    WI
    Look and see if you can see the notch in shock body below spring on driver side. It's strange your back is off that far. It would be if the installed fronts on wrong sides.
  18. Mar 10, 2018 at 3:31 PM
    #2438
    draheimtacoma
    draheimtacoma Active Member
    Jordan
    2017 Tacoma 4x4 XP
    Did my fronts today along with Camburg Uniball UCA's. Going to try and finish up with the rears and an icon AAL tomorrow.
  19. Mar 10, 2018 at 3:34 PM
    #2439
    MikesORTaco
    MikesORTaco Member
    LV NV
    Quicksand TRD OR
    SHIIIIITTTTT. You are right. LF and RF on the wrong dang side. Sheesh, man. Unbelievable. Seems as if they will be fixing and aligning. Damn. You get what you pay for.
  20. Mar 10, 2018 at 3:38 PM
    #2440
    na8rboy
    WI
    Sorry to hear that. At least we caught it right away.
    MikesORTaco[QUOTED] likes this.
