PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Mar 25, 2018 at 5:33 PM
    #2681
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    A/X or A/V? You said A/V on your first post. I've see photos of both springs A/T, and both A/V so far in the thread. The only A/X I saw had a 4Runner part #. I will keep scouring the thread.
    EDIT : Saw your edit, so you've got A/X. I'll have to see if any other photos so an A/X with the correct part #.
  2. Mar 25, 2018 at 5:35 PM
    #2682
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    A/X I fat fingered first post.
  3. Mar 25, 2018 at 5:39 PM
    #2683
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    I have an a/x and a/z with a/x on the drivers side.
  4. Mar 25, 2018 at 5:41 PM
    #2684
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    X2 ... I was thinking about getting a set, would like to know as well
  5. Mar 25, 2018 at 5:44 PM
    #2685
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
    Can you still buy this or is too late?
  6. Mar 25, 2018 at 5:52 PM
    #2686
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Probably a little late now
  7. Mar 25, 2018 at 5:55 PM
    #2687
    Itsgottabeyourbull
    Tulsa Oklahoma
    If anyone purchased a full set and ended up going a different way, let me know. I’d be willing to pay shipping as well.
  8. Mar 25, 2018 at 6:03 PM
    #2688
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    This shows the A/T on the driver's side perch, no passenger side shown.
    This shows the A/T on the driver's side, no information on the passenger.
    This shows an A/T on the passenger side, no info on the driver.
    This has the A/V on the driver, A/T on the passenger.
    A/V Passenger, A/T Driver
    A/T Both
    A/V and A/T, no information on which side was which.
    A/V on both.
    A/T on driver's side, nothing on passenger.
    A/X on driver's side, nothing on passenger.
    So...can we assume all these springs are the same? Maybe the A/X, A/T, A/V, A/Z are just some sort of production code? It appears that Toyota interchanges them when they mount side to side.
    My head hurts.
  9. Mar 25, 2018 at 6:49 PM
    #2689
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Good grief, you guys are gonna make me open my box and check what the hell I got like 6 weeks ago. Between this and some people getting 4runner springs...
    MikeyMcFly likes this.
  10. Mar 25, 2018 at 7:25 PM
    #2690
    Forge
    Forge Well-Known Member
    Rick
    Reading this makes me wonder if the Taco version of the kit the springs are the same but the shocks are set different for Taco Lean.
  11. Mar 25, 2018 at 7:28 PM
    #2691
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    The perches are for the lean. The instructions say to place the upright that has the higher perch on the driver’s side.
    What I am trying to figure out is why the springs have different codes. The only thing that makes sense is AC vs DC or AT vs MT.
  12. Mar 25, 2018 at 7:31 PM
    #2692
    joeythetruckguy
    joeythetruckguy Well-Known Member
    Joey
    Orange County, CA
    2017 Metallic Tacoma TRD Off Road
    What is the difference between the TRD springs and the springs that come with the Bilstein 6112?
  13. Mar 25, 2018 at 7:52 PM
    #2693
    Forge
    Rick
    Went and checked mine. Left says AV and right has AT
  14. Mar 25, 2018 at 8:41 PM
    #2694
    Carrot Top
    Carrot Top Well-Known Member
    Mark
    Las Vegas, NV
    2016 Inferno Tacoma TRD 4x4
    Both of mine say A/V.
    I guess it doesn't mean anything.
  15. Mar 26, 2018 at 4:49 PM
    #2695
    AzDevil
    AzDevil Member
    Scottsdale, AZ
    2017 Quicksand Sport 4x4
    Bilstein Pro suspension, 255/85/16 DC Extreme Country on 16x8 Pro Comp series 32, BAMF eco grill
    I removed my sway bar last week in an attempt to get rid of the front end clunk I got since installing the suspension. With sway bar off there is definitely more body roll. Shocks do soak up bumps better though. Didn't off road with it off but i looked for all the pot holes and rough roads I could find...and it was smoother. You can tell the shocks are able to work independently and that you're using more of the shocks travel (my tires had never rubbed until sway bar was off and it was just once going up my rounded curb to the driveway). That being said, I put mine back on. I didn't like the body roll. I also got more feedback through the steering wheel, vibrations and a little wobble. I wouldn't say it was unsafe by any means; but having two small kids in car seats i didn't like all the extra motion....kinda have to hold on when turing it you'll slide out of your seat lol. But I think these coilovers are firm enough to ditch the sway bar if you want the extra articulation. I say just try it and see if you like it. Takes maybe 30 minutes, don't even have to lift truck off the ground.
    Age315[QUOTED] and Rivermaniac like this.
  16. Mar 26, 2018 at 5:36 PM
    #2696
    Rivermaniac
    Rivermaniac Well-Known Member
    You should see if you can extend the ends of the swaybar links to not be engaging already ( since its lifted ) and that will give you the ride still and have the sway bar on . I did this on a dodge dakota that i lifted . The end links need to be longer ....... oh and what about the clunk , did it go away without the swaybar ?.
  17. Mar 26, 2018 at 5:54 PM
    #2697
    AzDevil
    AzDevil Member
    Scottsdale, AZ
    That would be cool. Next time I go off road I would consider taking it off again.
    Yes the sound was gone. Could have been sway bar links causing the noise or where the sway bar is attached to the frame with the U bracket. Since it only makes the sound occasionally and over bigger impacts, I decided to put it back on.
  18. Mar 26, 2018 at 5:59 PM
    #2698
    Rivermaniac
    I just searched , hellwing and other brands make longer end links for the tacoma , some even adjustable , others like an inch longer . So you can buy them longer .....i googled and saw some people break theirs because how tight they are after a lift .
  19. Mar 26, 2018 at 11:48 PM
    #2699
    Carrot Top
    Mark
    Las Vegas, NV
    Thanks for the feedback. I drive a lot of highway miles with curves. I don't think I want more body roll. I think I will keep the stabilizer bar on.
  20. Mar 26, 2018 at 11:52 PM
    #2700
    Carrot Top
    Mark
    Las Vegas, NV
    I might try the longer end links. Great idea. Does the front end lift preload the front swaybar?
    Does the longer links bring it back to normal ride characteristics?
