PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Apr 14, 2018 at 9:33 AM
    #2821
    RadoTaco
    RadoTaco Well-Known Member
    Justin
    18' Tacoma DCSB TRD OR White
    Tiee size? Looks great
    Dee1seven[QUOTED] likes this.
  2. Apr 14, 2018 at 11:04 AM
    #2822
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    Thanks man tires are Falken Wildpeak AT3w 65/75r17
    RadoTaco[QUOTED] likes this.
  3. Apr 14, 2018 at 1:59 PM
    #2823
    Forge
    Forge Well-Known Member
    Rick
    Are you level in the front (Taco Lean) ?
  4. Apr 14, 2018 at 4:13 PM
    #2824
    Dee1seven
    RVA
    No Taco lean I added the HS 1/4” spacer and kept the factory OL on to keep the rake
  5. Apr 14, 2018 at 6:28 PM
    #2825
    Forge
    Rick
    What is your difference between front and back?
  6. Apr 14, 2018 at 8:50 PM
    #2826
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I had been rethinking my tire choice as I was concerned 265 might look too small. Your truck is perfect, 265 will be perfect. Well done.
    Rob Daman likes this.
  7. Apr 15, 2018 at 10:13 AM
    #2827
    Carrot Top
    Carrot Top Well-Known Member
    Mark
    Las Vegas, NV
    2016 Inferno Tacoma TRD 4x4
    I believe you mean 265/75/16 for your tire size.
    Are you getting any rubbing on your mud flap when turning?
    drewhaus and Rob Daman like this.
  8. Apr 15, 2018 at 10:47 AM
    #2828
    Dee1seven
    RVA
    Correct 265 and No rubbing at all
    3/4” difference
    Center or hub to bottom of fender
    Front - 22-1/2”
    Rear - 23-1/4”
    Thanks man, I like the look of them i wanted to go with 285’s but this tire size in this brand is still lightweight and doesn’t affect the mpg or loss in power.
    Forge[QUOTED] and Rob Daman like this.
  9. Apr 16, 2018 at 5:51 AM
    #2829
    Dee1seven
    RVA
    So after a more miles post kit install and alignment, I’m feeling a slight vibration only upon accelerating from a complete stop from 0mph to 10mph then it goes away... any insight on this.
    Do I need to install a carrier bearing shim kit?
    Also, my rear axle had 1/8” to nothing wedge shims under the leaf springs I left those in place not sure if I should have taken them out as it might change the angle on the driveline for better or worse.
  10. Apr 16, 2018 at 7:03 AM
    #2830
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    It’s your needle bearing on the driver side axle. Just take it to the dealership and have them change it per the TSB or buy and install the ECGS bearing yourself.
  11. Apr 16, 2018 at 7:05 AM
    #2831
    Dee1seven
    RVA
    Already did the ECGS bearing while doing the lift
    DavesTaco68 likes this.
  12. Apr 16, 2018 at 9:09 AM
    #2832
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    i have both vibration issues the needle baring is more if a buzz i can only feel it only in the floorboard with my left foot and it got a pretty defined rhythm that goes away in 4Hi! i haven't decided yet weather to just eat the cost and install ECGS bushing or go haggle with the dealer "Im starting to feel bad since every time i go in there i have an issue".
    the other one is a slight vibration i can feel it in the steering wheel from 20 mph to 24 mph! i tried the bearing drop kit by old man emu but that did not fix it!
  13. Apr 16, 2018 at 9:26 AM
    #2833
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    So I had the exact same issue. Feels like rumble stips under my left foot every 3 seconds (50Km/H to 85 Km/H). The dealer replaced my bearing last week under warranty, and the bearing failed almost immediately again. Its slightly better than before, but failed within the first 30KM after replacement.
    Next up, ECGS.
    I'm also going to install the OME Carrier Bearing Drop as I get some different vibrations when braking.
  14. Apr 16, 2018 at 10:04 AM
    #2834
    Dee1seven
    RVA
    @sxe4533
    @Rocky.Mtn
    Did you guys have the axle shim from the factory prior to doing to anything to the rear and did you keep it in place?
  15. Apr 16, 2018 at 10:24 AM
    #2835
    Rocky.Mtn
    Canada
    I don't remember seeing anything - would they have been obvious as under the leaf pack?
  16. Apr 16, 2018 at 11:17 AM
    #2836
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    thats what i was afraid off, same crappy needle bearing! sounds like its best to avoid the dealer headache! im going to order the ECGS bushing
  17. Apr 16, 2018 at 11:18 AM
    #2837
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    i didnt notice any original shims when i did my AAL. look like i may need some
  18. Apr 16, 2018 at 12:02 PM
    #2838
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @Dee1seven
    No answer for your vibes, but I had the factory axles shims. I left them in there.
  19. Apr 16, 2018 at 2:57 PM
    #2839
    Dee1seven
    RVA
    @Rocky.Mtn
    Yes they sit between the leaf pack and the axle, If you had the factory shims you would have definetly seen them as the the center pin has to go though them.
    @sxe4533
    I’m not sure if you need the shims or not because the geometry has now changed with the new lift.
    I remember seeing a thread on TW that after a certain build date in the 2017’s they started to add the axle shims because of vibes complaints with the stock suspension. That may be why some people have them and some don’t.
    Every truck is slightly different so what may/may not work for mine may be fine on another.
    I did the ECGS so I ordered the carrier drop kit, if that doesn’t help I suspect the shims may be contributing to the problem bc the thick part of the shim is toward the back, therefore the angle of the diff may be pointing downward
  20. Apr 19, 2018 at 10:56 AM
    #2840
    NorthCountryTRD
    NorthCountryTRD Well-Known Member
    Patrick
    New Hampshire
    2015 Tacoma TRD Off Road V6 Manual
    Current Mods: - Locking Lug Nuts - Weather Tech floor Liners - N-Fab light bar - 32” Led Light bar - TRD skid plate - Leer Cap (Pyrite Mica) - Rigid TSM-22 Tow Strap Shackle Mount - Rigid Orange Shackle - @ACEkraut License plate bracket - Flashwolves LED reverse bulbs - TRD Stainless Cat Back - AFE Pro Dry S drop in filter - Glove box organizer - Center Console organizer - Bed Stiffeners - Color match grille - Custom Car Grills Perf SS Mesh flat black - Thule Cap roof rails - TRD PRO Suspension - Wheelers 2" Add a Leaf - HS 1/4 inch strut spacers - SCS Ray 10's in Brushed Copper - Cooper Maxx St's 275's - Under hood Led Light Kit Future Mods (as of right now): - 20inch LED Bar (Caliraised,Rigid, Baja) - 32inch LED Bar (Caliraised,Rigid,Baja) - LED Pods Side Projecting (Caliraised, Rigid) - Toyota Bed Matt - Quick fist Axe and Shovel mounts in Truck Bed - Cap mounted Awning - 100% No Drill Bolt on sliders - Wet Oak Seat covers (All black with TRD in them) - VooDoo Bed Bars/Basket that works under a cap
    Thought on these alignment numbers ?? Installed TRD Pro Suspension with HS 1/4 inch top plate spacer and Wheelers Offroad 2 inch add a leaf. The truck is a 2015 Access cab v6 manual
