PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Nov 30, 2018 at 4:47 PM
    #3081
    valdomero
    valdomero Well-Known Member
    Valdo
    2017 Tacoma TRD 4x4 Offroad
    Plasti Dip Grille and Emblems Removed V6 badge
    Which is better upper control arms?
    JBA or SPC?
    I heard both good things about them and the price difference aren't much.
  2. Dec 10, 2018 at 2:32 PM
    #3082
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Same here, but I am going with jba since they are red
    valdomero[QUOTED] likes this.
  3. Dec 30, 2018 at 3:15 AM
    #3083
    doorsidedown
    doorsidedown Well-Known Member
    Did you get a 14” or 13” spring?
    Has anyone thrown a 14x700 spring on these shocks to hold extra weight? I can’t find specs anywhere online to see if that’s too long or not...
  4. Dec 30, 2018 at 7:09 AM
    #3084
    noexcuse4you
    noexcuse4you Well-Known Member
    2017 TRD OR MGM
    I bought 14”. You’d have to be packing a lot of weight to need 700lb springs. My 650’s are pretty stiff even with the hybrid bumper and winch.
  5. Dec 30, 2018 at 8:13 AM
    #3085
    doorsidedown
    Yeah I think you’re right. I have an ARB bumper and sliders, but that’s it. I already have king 14” 700lb springs and I just put them on yesterday. I wanted to avoid buying another set of springs. Do these shocks have enough down travel for a 14? Have you had any issues?
  6. Dec 30, 2018 at 11:17 AM
    #3086
    noexcuse4you
    2017 TRD OR MGM
    The originals are 14", so there's no difference in down travel.
  7. Dec 30, 2018 at 11:32 AM
    #3087
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I've developed a pretty solid clunk up front. It wasn't present initially after installing, so imI going to go back through it and see if something is loose. I also thought maybe the sway bar could be causing it.
  8. Dec 31, 2018 at 7:12 PM
    #3088
    WhiteTacoTRDOR
    WhiteTacoTRDOR Well-Known Member
    DFW, TX
    2017 Tacoma DC TRD Off Road
    AFE Dry Filter, HPS Intake Tube, 265/75/16 Falken Wildpeak AT3ws, Bilstein TRD Pro Shocks/HS 3L AAL pack
    Could be that front body mount under radiator support, seems to be common and worth a check.
  9. Dec 31, 2018 at 8:46 PM
    #3089
    Lt. Dangle
    Ohio
    Yeah I'm gonna go over it tomorrow, I'll check that while I'm down there. Just so annoyed with it right now.
  10. Jan 1, 2019 at 10:53 AM
    #3090
    Lt. Dangle
    Ohio
    Yeah the nut on the sway bar link mount driver side was loose. All good now. I double double checked everything else while down there.
    I'll recheck everything again in a week or so. Hopefully all is good.
    The firmer ride is growing on me though.
    WhiteTacoTRDOR likes this.
  11. Jan 21, 2019 at 7:57 AM
    #3091
    microman2006
    microman2006 Active Member
    Sask, Canada
    2017 Tacoma TRD Off-Road DCSB / White
    I have also developed a clunk sound, i will have a look this weekend and reply.
  12. Feb 5, 2019 at 8:48 AM
    #3092
    noexcuse4you
    2017 TRD OR MGM
    Has anyone else started getting a "click" sound on large bumps or dips? It's been going on for a while now and I can't seem to figure it out. It only happens on the driver's side. I've tried torquing the LCA's, all shock bolts, UCA bolt, and replaced the body mounts with Energy polyurethane mounts. I even removed the sway bar entirely to get it out of the picture. Nothing seems to get rid of it. I'm now 90% sure it's the shock. Next I'm going to try swapping the driver and passenger shocks to see if it goes to the other side.
  13. Feb 5, 2019 at 8:52 AM
    #3093
    Lt. Dangle
    Ohio
    I'd say yeah I have something similar. It seems like every 2 weeks my truck goes from normal, to some new noise or clunk. I thought it may be the body mounts, but I have not really dug into it due to the weather. I also thought it may be the spring so switching sides would be a good way to test that.
  14. Feb 5, 2019 at 8:55 AM
    #3094
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    the fronts shock/coilover, has taco lean built onto it. Switching will cause you to lean in a major way on drivers side.
  15. Feb 5, 2019 at 8:56 AM
    #3095
    noexcuse4you
    2017 TRD OR MGM
    Yeah, I know. I was also going to move the spring perch.
  16. Feb 5, 2019 at 8:58 AM
    #3096
    na8rboy
    WI
    I don't think they have other perches/grooves on theses pro's.
  17. Feb 5, 2019 at 9:01 AM
    #3097
    noexcuse4you
    2017 TRD OR MGM
    Each side has 2 grooves. I'm going move them to the appropriate location when I do the swap.
  18. Feb 5, 2019 at 9:07 AM
    #3098
    noexcuse4you
    2017 TRD OR MGM
    I'm not sure it's the spring either. I changed my springs to 650lb and it made the click sound both before and after the swap.
  19. Feb 5, 2019 at 9:16 AM
    #3099
    na8rboy
    WI
    Ok, good to know. Did you check your brake pads? Some have had pads rattle. Retainer clip broke.
  20. Feb 9, 2019 at 10:32 AM
    #3100
    noexcuse4you
    2017 TRD OR MGM
    Figured it out. Turned out to be the UCA bolt. I loosened it and retorqued it and the sound went away. :thumbsup: That click drove me crazy for months!
