PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 11, 2019 at 6:59 PM
    #3121
    Ran-TRD
    Ran-TRD Well-Known Member
    Hey guys I’ve been. Following your issue of the clunk. I have the shocks install but haven’t had any issues with it so far. I haven’t done anything in the rear either. Reading your issues is making me wanna go back to stock, since I installed it I wasn’t to sure about it and now with this is making me a bit un easy being that my truck is fairly new and hate to have issues with it. Any advise for me in regards to the issue what should I watch out for ?
  2. Feb 11, 2019 at 9:11 PM
    #3122
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I sent you a pm. It will all get sorted out in the end, just the way it goes sometimes.
  3. Feb 12, 2019 at 9:12 AM
    #3123
    Lt. Dangle
    Ohio
    Removed sway bar, noise 90% gone. No noise, clunks, or otherwise unusual stuff from driver side. Passenger-side still has a clunk. Pretty sure that is because my UBJ is toast. I could probably jack it up to confirm, but the pic looks to confirm what I think. I really didn't want to do UCA's, but I don't see much of an option now. I'm certainly not going with another stock one as warranty is a non-option now.
    Driver:
    Passenger:
    I left my bar off as I will give it more time to verify if it is the bar or not, but i'm going to go ahead and order a relocate kit.
    It was extremely smooth without the bar though...
  4. Feb 12, 2019 at 12:22 PM
    #3124
    Lt. Dangle
    Ohio
    So I have an appointment tomorrow to verify what I think is going on. If I am right I will have to decide whether I just replace the BJ or do UCA's. I only have about 1000 to 1,500 miles or so on the lift so I got to imagine it was going south before I did the install. Timing sucks for sure though.
  5. Feb 12, 2019 at 1:23 PM
    #3125
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Mine has been on for a year now, no problems at all. I also raised rear 2"
    Ran-TRD[QUOTED] likes this.
  6. Feb 12, 2019 at 1:46 PM
    #3126
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    What’s the mileage on your truck? I’m at 27,500 or so now. I do notice the lack of caster MUCH more on this truck than the last one, even with similar alignment numbers.
  7. Feb 12, 2019 at 1:52 PM
    #3127
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    I've had this kit on my 2013 for almost a year and no clunks or vibes. I bought the ECGS bushing but haven't put it in...Yet. Check your ball joints.
  8. Feb 12, 2019 at 1:55 PM
    #3128
    Lt. Dangle
    Ohio
    Around 35k.
  9. Feb 12, 2019 at 4:23 PM
    #3129
    Ran-TRD
    did do an aal in the rear?
  10. Feb 12, 2019 at 4:26 PM
    #3130
    na8rboy
    WI
    Yes, 3 leaf progressive and left overload in 2 degree shim.
  11. Feb 12, 2019 at 7:13 PM
    #3131
    Ran-TRD
    nice! Any chance you can share pics of your set up?
  12. Feb 12, 2019 at 7:17 PM
    #3132
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Could you share some details about the shims? I think I understand how they work but I don't fully understand where they are supposed to be installed.
    Ran-TRD likes this.
  13. Feb 13, 2019 at 6:05 AM
    #3133
    Ran-TRD
    Are you having vibration or noise issues as well ?
  14. Feb 13, 2019 at 6:10 AM
    #3134
    na8rboy
    WI
    Only pic I have.
  15. Feb 13, 2019 at 6:15 AM
    #3135
    na8rboy
    WI
    The shim goes between bottom of leaf and axle perch, thin side to front. Rule of thumb is 1 degree per inch of lift. Two different styles, one gets bolted to spring with longer center pin. other style slides in (u shape cut in shim) but you need longer center bolt, with center bolt extension collar.
  16. Feb 13, 2019 at 6:40 AM
    #3136
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Any CB drop for you?
    I installed the 3leaf AAL sans OL leaf when I originally installed the lift almost a year ago. I did not install shims or the CB drop at the time, and haven’t noticed any drive line vibrations. I’ll be putting the OL back in the weekend. While I’ve got everything apart, I’ll be adding the center bolt extension collar on the new center bolt to eliminate a step if I need to add shims later.
  17. Feb 13, 2019 at 7:08 AM
    #3137
    na8rboy
    WI
    Yes, I installed CB drop a few months after. I made my own out of some steel I had, purchased new bolts. I had a very slight vib. CB drop took care of it.
    backcountryj[QUOTED] likes this.
  18. Feb 13, 2019 at 10:26 AM
    #3138
    Lt. Dangle
    Ohio
    Dealer couldn't locate any problem. I'm kind of in a holding pattern as of now. Not sure whether to push on or take it back to stock and see if problem still exists. I'm also dealing with a vibe issue and squeaky leafs...
  19. Feb 13, 2019 at 10:56 AM
    #3139
    na8rboy
    WI
    So, your UBJ was ok?
  20. Feb 13, 2019 at 11:06 AM
    #3140
    Lt. Dangle
    Ohio
    That's what I'm told. I find that hard to believe though.
