PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 13, 2019 at 11:20 AM
    #3141
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Has the weather cleared up there, so you can check it yourself. Also, be chance have you checked rack-n-pinion mounting bolts? Just running things through my head, what could be causing you clunk. I see the Ohio salt is really messing up finish on those Bilstein's.
  2. Feb 13, 2019 at 11:22 AM
    #3142
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    That's like 6 weeks of use or so! I installed the front's on Dec 12th according to the pic I took, so actually 8 weeks.
    Today was 20 degrees colder than yesterday so i'm wondering if that is changing the issue. I noticed the clunk more this afternoon than I did this morning after the service.
    I appreciate all the helpful suggestions though.
  3. Feb 13, 2019 at 11:27 AM
    #3143
    Lt. Dangle
    Ohio
    Dealer did quote me over $400 for a new UCA though lol.
  4. Feb 13, 2019 at 7:46 PM
    #3144
    Lt. Dangle
    Ohio
    Jacked truck up, I can't see anything wrong with my BJ either. Checked everything I could think of and some things that were recommended to me. So like any good troubleshooter faced with an apparently impossible problem, i'm just gonna ignore it for now. I will update when my wheel falls off or such.
    Flip-side is I can now move on to the other end of my truck and deal with squeaks and vibes...
  5. Feb 13, 2019 at 8:11 PM
    #3145
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I had zero issue prior to the weather getting cold. I had a warm day and my clunk was noticeably reduced.
    My metallic rattle is definitely still there as is my clunk. Have you ruled out body mounts? If you swap back to your stock uprights it will rule out the Pro uprights. I had strut clunk in my old car, but it was at low speeds, so I'm reluctant to point fingers at the Pro assemblies.
    But regardless what you are saying is that your sway bar is still off and the clunk is back to what it was before you pulled the bar?
    I'm waiting for warm weather (tho that will likely mask the issue) and pull the Pro skid and sway and see.
  6. Feb 13, 2019 at 8:19 PM
    #3146
    Lt. Dangle
    Ohio
    Sorry for replying with colored text, just seemed easier. Can you describe your noise again?
  7. Feb 13, 2019 at 8:22 PM
    #3147
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Fair enough. Thanks for the clarification. I'm hoping I've just got the sway bar issue myself.
    Do you have any metallic rattling on yours? Mine is noticeable at low speeds. It's definitely not normal 6MT noise as it occurs under load and not brake pad rattle as it occurs with the brakes on. I'm hoping it's all related.
    The only reason I mention the body mounts is that it seems like a common occurrence on the 3G that's exacerbated with the cold.
  8. Feb 13, 2019 at 8:24 PM
    #3148
    Lt. Dangle
    Ohio
    Body mounts probably are bad according to what I've read here lol. Have you checked your dust shield on your front brakes? After I did my driver side I had a rub from that, but otherwise I got nothing.
  9. Feb 13, 2019 at 8:27 PM
    #3149
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I'll give it a look when I pull the wheels to look at the sway. I swap to snow tires each winter so it's possible I've got something going on there.
    Maybe I should have just stayed stock on this truck.
    Lt. Dangle[QUOTED] likes this.
  10. Feb 13, 2019 at 8:30 PM
    #3150
    Lt. Dangle
    Ohio
    Before I swapped mine I really asked myself if I wanted to as my truck was super smooth and rode nice as was. I had bought all the stuff to do the lift almost a year before and it sat in my garage. If it keeps up, it may end up back on the garage floor. The only reason I am not racing to do it is I am afraid I will go through the trouble of reverting it and still have my clunk.
  11. Feb 13, 2019 at 8:38 PM
    #3151
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Realistically the only way you wouldn’t is if the assemblies themselves are the culprit. Otherwise it’s somehting in the truck which failed.
    My grumpiness is strictly from losing out on the passing off the problem to someone else (ie dealer under warranty) because I changed things. I don’t want to pay to have them throw parts at it which won’t fix things. Of course the crummy winter weather isn’t helping things.
  12. Feb 13, 2019 at 8:47 PM
    #3152
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Only a very slight amount of vibration under heavy acceleration from a stop. Icon 3 leaf with overload still in.
  13. Feb 13, 2019 at 9:36 PM
    #3153
    Lt. Dangle
    Ohio
    My dealer charged me nothing to look at it on a lift a drive it around. They even had me ride along. Of course it chose to not do it except twice which the mech said he didn't hear or feel. I switch back to stock and it's still there I will be back at the dealership.
    MikeyMcFly[QUOTED] likes this.
  14. Feb 22, 2019 at 11:19 AM
    #3154
    Lt. Dangle
    Ohio
    So at this point my front cluck seems to be less, or I have just learned to tune it out. I did put my sway back on after installing a relocate kit. That was def. part of it, but not all of it. I'm convinced that it is either something with the brakes or the coilover themselves. I also clearly have a bad mount somewhere as I have a horrible metal screeching sound that occurs only when I do something that twists the frame. That is my next project.
    So I consider the lift done as of now. I have the dakar HD in the rear and originally had a 3 degree shim but could not resolve that with any amount of CB drop and shimming so I removed it. I now have a cb drop and flip and no vibes. I got about 2" in the front and 3" in the rear. I have sumos in the rear, but only have about a finger width of space to the frame, I will eventually switch them out for the shorter version. Towing causes the sumos to contact the frame. I do need to redo the zip tie on my rear shocks as the boots are loose and collapsed.
    Otherwise it is what it is.
    charcharias likes this.
  15. Mar 15, 2019 at 1:28 PM
    #3155
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    I have one of these lifts NIB for sale. Sold my TACO. Only thing I did with the lift was open the box to make sure it was complete with the right parts.
  16. Mar 15, 2019 at 4:11 PM
    #3156
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    Location?
  17. Mar 15, 2019 at 4:30 PM
    #3157
    fzj40
    R
    2017 TRD OR MGM 6MT
  18. Mar 21, 2019 at 6:18 PM
    #3158
    Gmetaco
    Gmetaco Well-Known Member
    Greg
    2017 OR
  19. Mar 23, 2019 at 9:50 AM
    #3159
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    For those who have installed this kit, any long term issues?
  20. Mar 23, 2019 at 9:54 AM
    #3160
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Had mine on for a little over a year and no issues, still rides great.
    Xx_Evilvirus_xX likes this.
