PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 2, 2018 at 6:06 PM
    #341
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I hate to admit it but nobody needs "expertise" in the internet age, but I will always shop at the places with the best warranty. I don't care if it costs me another $50 it's priceless to know if something breaks a couple years down the road it gets exchanged quickly without argument.
  2. Feb 2, 2018 at 6:13 PM
    #342
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    It sat lower in the rear without anything but the new pro suspension. I later changed it to a stance I preferred when I added weight, etc.. That is the first photo/first day of Pro Suspension mounted without canopy--just the kit on with '16 trd pro wheels and 265/70/16 Toyo AT2s.
    I previously owned a '15 Pro with the same kit. When I placed a new one on my '16 OR, IMO seemed to sit slightly higher than 2nd gen Pro. I did not take measurements though for you number guys. I have no idea why--different wheel wheel design or placebo effect maybe...???
    Really, I just used my own judgement making the same lateral suspension move from 2nd gen to 3rd gen as I really liked the plush ride and moderate lift.
    Hope this helps with your decisions:)
    Forge[QUOTED] likes this.
  3. Feb 2, 2018 at 6:27 PM
    #343
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Is this post a photo of your truck with JUST the TRD Pro suspension and no other add-on spacers / blocks / AAL, etc?
    You say you had 265 tires in this post. 265/70 or 265/75? They look closer to a 70, but it might be because they look like highway tread to me compared to a knobbier tire.
    It looks pretty level to me, if a smidge nose high. One of those Warn / SSO bumpers would probably level you out quite well.
  4. Feb 2, 2018 at 8:27 PM
    #344
    18Taco
    18Taco Well-Known Member
    PNW
    18 DC OR
    Can you explain plush ride? How is it with this setup compared to stock? On road handing, cornering, nose dive, lean around corners, absorbing imperfections in the road? How about off road? Absorbing high speed bumps, small jumps, wash boards, and low speed handing like rock gardens, etc? Does this kit feel like it mates well to the 3rd gen like it did for your 2nd? Thanks for any input you can provide. It'll help with my purchasing decisions.
  5. Feb 2, 2018 at 9:03 PM
    #345
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    why Doesn’t someone order from rogue, get him to give the numbers ..and then cancel the order.
    Cmon just for fun...
    valdomero likes this.
  6. Feb 2, 2018 at 9:06 PM
    #346
    pocketsmcaaron
    Oregon
    Y
    Yes that’s just the pro suspension without jack- no spacers, blocks, etc. just a virgin installed pro suspension with nothing else. Tires were 265/70/r16 pr, you’re right! I now have 265/70/r17 ko2 s c rated on pro 4 runner wheels. I wanted more off-set and a better off road tire. With the old set up it sat about approx 1”-1.5” lower in rear. The desert pro tune with added weight in your bed without either a block or added leafs will tilt down further & too easily imo.
  7. Feb 2, 2018 at 10:08 PM
    #347
    pocketsmcaaron
    Oregon
    FTR I’m no expert &as the saying goes: “One man’s bane is another’s bliss.” That being said, compared oem off road bilsteins, I really like how these handle. They are far superior. They are a magic carpet ride compared to orm. You’ll notice a significant weight difference too and solid beefiness comparatively when your Oems are pulled.
    Going at high speeds there is a slight sway on say two lane sharp curves, but I got used to it, hardly ever hit the brakes, maybe downshift while accelerating holding at 65-70 mph just fine.
    Just went desert running in eastern Oregon this past weekend. They handled confidently especially /wasboards,etc. They abdorb and soak up bumps and hit a small jump with ease. Again these will offer far less jolting than the oems. Depending on what/how you intend to use them I think most given the price will be shit-eating grin content. I truly have zero regrets. Modded them about 3 weeks after install with rear blocks to accomadate the weight of my shell and platform and recently with the 17s & more offset. I prefer a slightly higher rear to even it out esp when I put heavier gear in the bed. Good luck with your decision.
    https://youtu.be/v7XVEfIWIkg
    (Photo taken last Sunday)
    Orco59 and bigdood like this.
  8. Feb 2, 2018 at 10:23 PM
    #348
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Dang.... based on what you are saying, it would appear that the truck could sit a little nose high with the kit.
    I like a little rake myself. Bummer.
  9. Feb 2, 2018 at 11:05 PM
    #349
    tow-coma
    tow-coma Well-Known Member
    H
    He's given the numbers. We weren't talking about that ...
  10. Feb 3, 2018 at 7:06 AM
    #350
    JS760
    San Diego
    2017 DC Sport
    Then what are they ?
  11. Feb 3, 2018 at 7:12 AM
    #351
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    :"1.5-1.75 of lift . You can addd spacer if you choose more"
  12. Feb 3, 2018 at 7:14 AM
    #352
    charcharias
    charcharias Well-Known Member
    Chuck
    Denver
    2013 TRD Sport
    Let me know if you need a hand bud. I'm over in Lakewood and planned on a 1st notch 6112/5160 install after tax season but might just get these instead. Looking at the 1.5" AAL or light duty dakars with top overload removed too.
  13. Feb 3, 2018 at 7:27 AM
    #353
    JS760
    San Diego
    2017 DC Sport
    I’m calling bullshit on that, and that the 5160’s alone are giving any lift in the back.
  14. Feb 3, 2018 at 7:32 AM
    #354
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Agreed.
    The 2G truck sits 1" lower than the 3G truck. The 2G truck gets 1.75" of lift from these.
  15. Feb 3, 2018 at 8:02 AM
    #355
    EasTexan
    EasTexan Active Member
    Texas
    2017 TRD/OR SB
    So what exactly is needed in the rear to level a gen 3? Just New leafs? Probably a 1.5” from icon?
  16. Feb 3, 2018 at 8:18 AM
    #356
    pocketsmcaaron
    Oregon
    I wanted leafs, but didn’t want to void warranty with a new truck, so went with blocks.
  17. Feb 3, 2018 at 8:42 AM
    #357
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    My prediction is
    About .75" lift front
    No lift rear
    Looks level after settling.
    Whoever gets them installed first make sure you drive around a bit after install before taking measurements/pictures. All cars stand on their toes after coming off the jacks.
    1truckdriver likes this.
  18. Feb 3, 2018 at 9:45 AM
    #358
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    Pockets looks higher than 3/4 of an inch in front though.
  19. Feb 3, 2018 at 10:41 AM
    #359
    ATCDZ
    ATCDZ Active Member
    Miguel
    2017 White Tacoma Limited
    Please keep us posted if you decide to install today. Your doing the lords work.
    charcharias and backcountryj like this.
  20. Feb 3, 2018 at 1:29 PM
    #360
    vtboater
    vtboater Member
    Nick
    Vermont
    2017 TRD OR Double Cab White
    Remote starter, tonneau cover on the way
    NerdTaco likes this.
