PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 4, 2018 at 8:35 AM
    #421
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Right now I have just ordered the single 1/4" spacer. I'd rather not use the top spacer at all, but for $29 I figured it would give me another cheap option to get the look I want. I'm concerned that the 1" spring perch spacer will give me more lift than I care for, but if my new leafs are too high, then I will bring that back into the mix.
  2. Feb 4, 2018 at 8:35 AM
    #422
    Lt. Dangle
    Ohio
    Yes, this is my plan B. It's still almost $300 cheaper than the 6112's.
  3. Feb 4, 2018 at 8:39 AM
    #423
    Lt. Dangle
    Ohio
    I also need to order new bumpstops and the bushing, so mine won't be getting done for awhile. I also am due for my 15k check up, so i'm going to wait for that before I do anything. My wife is going to vegas for 4 days at the end of the month, that will give me plenty of time to do my lift and slide it right by her unnoticed lol. Kidding, she was home when my leafs got delivered and the UPS guy was kind enough to joke with my wife about all the stuff I was getting delivered...
    charcharias likes this.
  4. Feb 4, 2018 at 8:43 AM
    #424
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    So I need to order bumpstops and a bushing too? I'm sorry for coming off as such a novice. I had never planned to lift my truck, but just wanted something better than the Hitachi shocks my SR came with. Anything else I need to buy for this kit to work?
  5. Feb 4, 2018 at 8:46 AM
    #425
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Ok thanks. Yea that is actually was I was contemplating as well. Get both to the same clip and use the spacer to account for the lean.
    My concern is I’d rather not put too much preload on the coils and potentially firm up the ride too much. Also curious if the 1/4” spacer might be too much as it will produce1/2” lift on that side. Couldn’t that produce reverse taco lean?
  6. Feb 4, 2018 at 8:47 AM
    #426
    Lt. Dangle
    Ohio
    Not at all. I'm just trying to get everything lined up. I'm a "in for a penny, in for a pound" kind of guy and would like to cover all my bases at once if possible.
  7. Feb 4, 2018 at 8:49 AM
    #427
    schultzj01
    schultzj01 Well-Known Member
    San Diego
    2017 DCSB SR 4x4 MGM
    Are the stock leaf springs on a TRD OR the same that are used on an SR?
  8. Feb 4, 2018 at 8:49 AM
    #428
    Lt. Dangle
    Ohio
    Anything is possible I guess. I have yet to hear too many complaints of the driverside being high on any Toyota product, not just the Tacoma though.
  9. Feb 4, 2018 at 8:51 AM
    #429
    backcountryj
    Jonathan
    GA
    Bumpstops aren’t mandatory, but worth the upgrade while you’re in there.
    He’s probably referring to replacing the needle bearing bushing. I’ll be swapping that out as well. Too cheap not to replace while it’s all apart.
  10. Feb 4, 2018 at 8:53 AM
    #430
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Yeah, while it's apart anyway might as well. I don't even have 4,000 miles on mine yet.
    Need to do more research about this.
  11. Feb 4, 2018 at 9:01 AM
    #431
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    So, with this kit I can just bolt on the shocks and be on my way? Or do I need to do a Diff drop, needle bearing replacement and all that? I just want better shocks. I'm not against a small lift, but this is getting more complicated than I initially thought.
  12. Feb 4, 2018 at 9:05 AM
    #432
    backcountryj
    Jonathan
    GA
    I hear ya. I’m at 5200 miles.
  13. Feb 4, 2018 at 9:06 AM
    #433
    Lt. Dangle
    Ohio
    Some trucks need the needle bearing, some don't. No way of knowing until you do the lift.
    Garrett75x likes this.
  14. Feb 4, 2018 at 9:26 AM
    #434
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Is there an extended range 5160 like the non rezzy 5100 b110s? (16-27" range) I'm adding the extra 3rd leaf to my Dakars
  15. Feb 4, 2018 at 9:35 AM
    #435
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
  16. Feb 4, 2018 at 9:44 AM
    #436
    backcountryj
    Jonathan
    GA
    This kit is a very user friendly suspension upgrade, that will result in some lift, and is OEM. It’s not for everyone, as is lifting in general. Any lift of any height can have some negative side effects.
    Best of luck to you :hattip:
  17. Feb 4, 2018 at 9:47 AM
    #437
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Don't cancel just yet ..... you don't need bumpstops and you likely won't need the needle bearing with such a small lift. People start getting vibrations and issues that require diff drops and carrier drops and needle bearing when you go 2.5"++++
    Garrett75x and Jared8907 like this.
  18. Feb 4, 2018 at 9:50 AM
    #438
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Wish I could, just sent the email. Oh well.
  19. Feb 4, 2018 at 1:51 PM
    #439
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I’m not planning to do the ECGS bushing from the get go. I’ll have 25k on my truck by the time I install this kit. If the bearing blows I’ll buy the ECGS bushing and have my dealer swap it under warranty, assuming the dealer plays nice (they have to date). Rolling the dice...
  20. Feb 4, 2018 at 1:55 PM
    #440
    Frito
    Frito Well-Known Member
    Think you'll also need an alignment ?
