PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 7, 2018 at 7:08 PM
    #721
    TPC
    TPC Well-Known Member
    TIM
    DELAWARE
    2017 DCSB TRD SPORT
    Are those stock tires? Also we are comparing a Sport to an Offroad, the factory shock dimensions could be slightly different and have an effect on the initial measurements.
  2. Feb 7, 2018 at 7:09 PM
    #722
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    It’s an offroad.
  3. Feb 7, 2018 at 7:15 PM
    #723
    Frito
    Frito Well-Known Member
    HA ! :laugh:
  4. Feb 7, 2018 at 7:17 PM
    #724
    Frito
    Ball Bustin' aside, I'm impressed with the level of participation in this thread !
    But listen, I thought there was a left and right shock that was supposed to even out the lean ?
    1truckdriver and Lt. Dangle like this.
  5. Feb 7, 2018 at 7:18 PM
    #725
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I noticed he had a lean of 1/2" also. Or some other strange measurement of your choice.
    Rocky.Mtn likes this.
  6. Feb 7, 2018 at 7:23 PM
    #726
    Frito
    Yeah, a quarter up front and 3/8 in the rear ?
    ( " Post measurements LF-37 1/2 RF-37 3/4, LR- 36 2/8, RR-36 5/8. " )
  7. Feb 7, 2018 at 7:23 PM
    #727
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Your before measurements echo what I got for mine quickly with a tape measure with a full tank of gas, although I was a bit more level in the rear. TPCs truck actually has 265/70-17 tires compared to our 265/70-16 so we must sit higher stock.
    You definitely got more lift and a more significant lean as his was dead even side to side. You also got rear lift which he isn't showing at the moment as I believe he hadn't installed his.
  8. Feb 7, 2018 at 7:25 PM
    #728
    Lt. Dangle
    Ohio
    Yeah a quarter. Not sure where I got 1/2"
  9. Feb 7, 2018 at 7:30 PM
    #729
    UAL777jet
    UAL777jet Well-Known Member
    Bill
    Norwalk, IA
    2019 Tacoma TRD Pro Voodoo Blue
    TRD Performance Air Intake
    That’s good to hear, made me go out to the garage and take another look :D
  10. Feb 7, 2018 at 7:34 PM
    #730
    TPC
    TIM
    DELAWARE
    2017 DCSB TRD SPORT
    They only go in one way without rotating the piston. I tried every hole combination but only one allowed everything to line up. I have seen guys stick something through the lower mount and turn the piston but I think this is done when you assemble everything yourself and need to get it to line up.
  11. Feb 7, 2018 at 7:36 PM
    #731
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Holy shit. That thing is beefy compared to the stock shock
  12. Feb 7, 2018 at 7:43 PM
    #732
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    If you guys measured from center of hub to the bottom of fender you don't have to worry about tire/rim size, easier to compare your lifts
    1truckdriver and Frito like this.
  13. Feb 7, 2018 at 7:47 PM
    #733
    Timmcc02
    Tim
    2017 TRD OR
    Ya this is why I think it was still preloaded a bit after lowering on the ground
  14. Feb 7, 2018 at 7:47 PM
    #734
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    That's how I typically have done it. I was just backing up data with what I've seen. When I reported the lift I got on my 2G I had it as hun to fender.
    DavesTaco68[QUOTED] likes this.
  15. Feb 7, 2018 at 7:58 PM
    #735
    TPC
    TIM
    DELAWARE
    2017 DCSB TRD SPORT
    I had about 1/8 inch of lean before things settled, then they ended up perfect.
    I’ve got a headstrong 3 leaf add-a-leaf in the mail right now. Next weekend I will be installing the rear lift.
    MikeyMcFly[QUOTED] likes this.
  16. Feb 7, 2018 at 8:06 PM
    #736
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Excited for your results. I have a suspicion your setup is exactly what I'm after, a non-huge lift OEM+ look that is functional and rides better.
    Now Im eagerly awaiting to see if that Warn bumper plays well with the Pro skid.
  17. Feb 7, 2018 at 8:40 PM
    #737
    Rivermaniac
    Rivermaniac Well-Known Member
    Ordered in california , los angeles area . Going to install on a dclb 2 wd . Will post numbers before and after . I have 265/70/17 tires and rims ....
  18. Feb 7, 2018 at 8:48 PM
    #738
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Measure from the center of hub to fender. Tires are irrelevant!
  19. Feb 7, 2018 at 9:02 PM
    #739
    Lt. Dangle
    Ohio
    Does it matter where you measure from as long as pre and post lift numbers are listed? Doesn't the difference between the two tell you the lift regardless of tires and wheels?
    backcountryj and 09 Redneck like this.
  20. Feb 7, 2018 at 9:06 PM
    #740
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Measuring from hub to fender eliminates differences that tire/wheel size introduces. It standardizes the measurements so they are useful to everyone regardless of wheel/tire size.
    1truckdriver and DavesTaco68 like this.
