PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 9, 2018 at 7:39 PM
    #881
    Frito
    Frito Well-Known Member
    Lipstick will work just as well.... :wink:
  2. Feb 9, 2018 at 7:41 PM
    #882
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    The shocks are identical to the 5160, otherwise Toyota would not have added the brake line extensions, if it did not provide more travel. Meaning they are longer than the regular offroad billies. So i assume they can handle an extra 1.5 inch.
  3. Feb 9, 2018 at 8:14 PM
    #883
    indevo
    indevo Well-Known Member
    2019 T4R Pro
    My main concern was corrosion, and it being an entry point for water/salt. One is at the top of the coil, on the other it’s at the bottom. Bottom, not as big of a concern, but trickling in top down worries long term. I thought of attempting a patch of some sorts, but contacted Conicelli Toyota to see what they think. Send me some new coils and I’ll send the others back, or I’ll send the whole kit back if they want. Even considered buying the coils for the Baja kit which are heavier. At $111 each it’ll push the kit’s bargain out of benchmark. The only way I think I’m screwed is if they sell the rest of them by Monday. If not.........there’s still hope! Maybe I’m too finicky. I do know, when I buy something new, I like it to be new.
    Lt. Dangle[QUOTED] likes this.
  4. Feb 9, 2018 at 8:29 PM
    #884
    indevo
    2019 T4R Pro
    How many coats? Dry time in between?
    Slickwhenwet and Frito[QUOTED] like this.
  5. Feb 9, 2018 at 8:29 PM
    #885
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Honestly I think that's a bit overkill. I get your point but my set has chips and I'd venture to think that at least 75-80% of the kits out there have similar chips.
    They're going to get chipped up under the truck regardless and you aren't going to see them. If you are concerned hit them with some clearcoat and some Fluid Film.
    Who's to say the next set won't be identical? I'm the first person to be overly critical of perfection, but it's going to be a tall order to get a set without chips, if they send a new set at all. What is your time worth to go through the process of shipping everything back, assuming they pay return shipping?
    bigdood likes this.
  6. Feb 9, 2018 at 8:35 PM
    #886
    indevo
    2019 T4R Pro
    Well said. Clear coat it is, plenty of fluid film in this household too. Thank you
  7. Feb 9, 2018 at 8:36 PM
    #887
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Understable, but I'm not sure its worth the hassle. But do what you gotta do man. Or woman.
    Edit: Or CC it and FF it lol.
    indevo[QUOTED] likes this.
  8. Feb 9, 2018 at 10:51 PM
    #888
    Carrot Top
    Carrot Top Well-Known Member
    Mark
    Las Vegas, NV
    2016 Inferno Tacoma TRD 4x4
    I ordered a set today from my local dealer here in Las Vegas. They are charging me $600 plus sales tax.
    This deal is too good to pass up on. I will keep my stock tires and wheels. I'm not sure if I will lift the rear. I guess I will know more after I install the fronts. Thanks to everyone who has posted to make this decision easy.
    DavesTaco68 likes this.
  9. Feb 10, 2018 at 4:24 AM
    #889
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @Timmcc02 @TPC @shackley @UAL777jet
    And anyone else that has already installed this kit on their rig.
    Care to report back any follow up measurements?
    It seemed like most everyone was gaining around 2-2.5" on the Driver's Front and 1.5-2" on the Passenger's Front immediately following installation (my numbers may be incorrect).
    I'm curious to hear how much settling is taking place after some miles and alignment?
  10. Feb 10, 2018 at 6:18 AM
    #890
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    I may or may not align my truck today depending on how busy I am at work, but at the least I’ll measure again and see what I’m at.
    Rownan and backcountryj[QUOTED] like this.
  11. Feb 10, 2018 at 6:44 AM
    #891
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    Would you mind measuring length of the front if you have them handy?
  12. Feb 10, 2018 at 6:50 AM
    #892
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Ah, the seldom mentioned Hellwigs. I think the Hellwig helper springs are a good, cheap, easy to install solution as opposed to a new leaf pack. I had a heavy-duty set on the '05 Tundra (very similar leaf pack to a Taco), they made a huge difference handling the trailer tongue weight, topper, gear.
    A benefit is the extended length of the rear shocks isn't negated by too much lift, you still get the extra droop. They are also adjustable for stiffness, loosen the nuts for a softer ride, tighten the nuts to stiffen. The rear swaybar was also nice to have.
    http://www.hellwigproducts.com/hellwig-products/2016-tacoma-line-released/
  13. Feb 10, 2018 at 7:46 AM
    #893
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i got confirmation that mine shipped yesterday from Des Monies. Anyone else going to be installing these on a 2.7??
  14. Feb 10, 2018 at 8:02 AM
    #894
    Dc2tacoma
    Dc2tacoma Well-Known Member
    I have the same little Nick's also. I think the person is just being overly dramatic.
    blu92in99 likes this.
  15. Feb 10, 2018 at 8:09 AM
    #895
    wolfman00
    matt
    '16 dclb
    i usually end up with more nicks and scratches doing the install haha
    blu92in99 and Frito like this.
  16. Feb 10, 2018 at 8:11 AM
    #896
    indevo
    2019 T4R Pro
    No drama, just a question. Text can easily be misinterpreted.
  17. Feb 10, 2018 at 8:40 AM
    #897
    Frito
    Probably why they are selling them so cheap.... they are all "seconds" ! I wonder what else is wrong with them.... :rolleyes:
    09 Redneck likes this.
  18. Feb 10, 2018 at 8:42 AM
    #898
    Frito
    :devil:
  19. Feb 10, 2018 at 9:11 AM
    #899
    Carrot Top
    Mark
    Las Vegas, NV
    I was reading the installation instructions that was posted on this thread. It says the 2 front shocks come set at different c clip heights. Upper clip for drivers side (for taco lean) and lower for passenger. My question to everyone who has received their order is did yours come that way from the factory?
  20. Feb 10, 2018 at 9:21 AM
    #900
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    They come preassembled from Toyota
