PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 11, 2018 at 12:47 PM
    #1001
    tacoma_supreme
    tacoma_supreme Member
    2018 TRD OR 4x4 DCSB Quicksand
    That's what I'm searching for right now. There's already info/talks on this thread saying that these shouldn't be any different from the regular 5160s that bilstein already has. I wouldn't be surprised if Toyota just slapped the TRD stickers on them and did a slight change to them to justify why its a "TRD" part.
  2. Feb 11, 2018 at 12:54 PM
    #1002
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
  3. Feb 11, 2018 at 12:57 PM
    #1003
    tacoma_supreme
    Looks about right. That seems to be the general consensus on the thread to what can be achieved on the rear. For someone like me who doesn't really haul heavy things in the bed, I might be leaning towards just going with add-a-leaf. I just don't want to the ride to suffer because I do kind of like how it feels right now even if it nose high.
    DavesTaco68[QUOTED] likes this.
  4. Feb 11, 2018 at 1:24 PM
    #1004
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    So assuming these are the same as the regular 5160’s they should be able to handle a Dakar leaf pack or would they be too much?
    Between the Dakar “Medium Duty” and “Heavy Duty” do they both provide the same amount of lift and just different weight capacities?
    Lastly, anyone with HD Dakar’s how stiff is the ride?
    SN: If there is a Dakar thread about comparisons I haven’t found it yet.
  5. Feb 11, 2018 at 1:56 PM
    #1005
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    @tacoma_supreme
    Did you take any pre-install measurements to see how much lift you gained in the front?
    Care to provide any comparison of the on-road feel of the Pro kit to the stock OR suspension? Firmer or softer, nose dive or body roll? Pretty much any feedback, other than ‘I like/hate it’ or ‘so much better/worse than stock.’
    Thanks, truck looks great. I’ve got the exact same truck but 2017.
    indevo likes this.
  6. Feb 11, 2018 at 2:43 PM
    #1006
    EasTexan
    EasTexan Active Member
    Texas
    2017 TRD/OR SB
    Would I be correct in thinking this lift with the aal will be able to fit 275/70/17s?
  7. Feb 11, 2018 at 2:44 PM
    #1007
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    Same questions! I'd like to do a leaf pack replacement with these rear shocks. I need something that will get me slightly nose-down, handle a few hundred pounds without squat, and decent ride. I'm assuming I won't need HD for that.
  8. Feb 11, 2018 at 2:53 PM
    #1008
    homesteader
    homesteader Well-Known Member
    Southern Quebec
    2017 TRD SPORT DCSB
    I am running 275/70-17 on a stock 2017 sport on stock wheels, I ordered a kit and am going to go with 255/80-17 km2s
  9. Feb 11, 2018 at 3:01 PM
    #1009
    Dee1seven
    RVA
    Exactly, I like the rake even with a 2-300# load I still want the truck to be “nose-down”.
    I carry about 80lbs worth of tools everyday and I can’t stand the slight sag I see.
    I don’t think I need the HD either I assume the medium duty is still far superior than the stock.
  10. Feb 11, 2018 at 3:11 PM
    #1010
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    I have the Icon mini leaf pack and it gives me 1 inch over stock with a canopy on, Deaver looks good as well https://www.deaverspring.com/products/toyota-leaf-springs/tacoma-2wd4wd-6-lug-2005-2015/
    OME looks like mostly over 2 inches with their stuff.
  11. Feb 11, 2018 at 3:38 PM
    #1011
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    Just went outside and measured my truck, 2017 AC 4x4, 4 cylinder 5 speed. Measured from the ground up to bottom of fender, center of tire. I have swapped out the stock shocks to some 2017 TRD 4x4 ones. Did not get any lift when this was done. Stock 245/75/16 tires. Measured LF 35 1/4, RF 35 1/4, LR 36 3/4, RR 37. Full tank of gas. Anybody else with a 4 cylinder AC 4x4 measured their truck? If I get 1 1/2 inches + I may not have to do anything to the rear. Any thoughts?
  12. Feb 11, 2018 at 4:28 PM
    #1012
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Supposedly. Also if you buy the hd leafs and remove the third leaf(I think it's the third) it becomes the med pack. If you buy the medium pack and sag, then order the missing leaf it converts to the hd pack. It's slightly more expensive to order the med plus a leaf if needed vs. ordering the hd and removing the leaf. It's very simple, yet all confusing at the same time.
    Allegedly the lift on med dakars is 2" with 0 load and 2" on the hd Dakar at 600#. That's all third gen, it's 3\4" higher with second gens. Allegedly...
    I run probably about 600# since I have a cap, rack and stuff in the back so I went with the he pack. If it's too much, I'll remove a leaf.
    DavesTaco68 likes this.
  13. Feb 11, 2018 at 4:55 PM
    #1013
    Dee1seven
    RVA
    Thanks that makes sense, it would save time and money to just have the HD pack from the beginning remove the leaf if too stiff or add it back on if my current load needs change for whatever reason.
    Is there extended bumpstops needed as well?
  14. Feb 11, 2018 at 5:07 PM
    #1014
    Lt. Dangle
    Ohio
    Yes on the first sentence. That's exactly why I ordered the HD pack.
    Second sentence: Needed, I dunno, but I am getting some bump stops. Seems logical too me.
  15. Feb 11, 2018 at 5:20 PM
    #1015
    Dee1seven
    RVA
    My same thoughts on the bumstops.
    Thanks for the response.
  16. Feb 11, 2018 at 6:13 PM
    #1016
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    I'm thinking Wheelers bumpstops, good quality and the price looks right
  17. Feb 11, 2018 at 6:33 PM
    #1017
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    finally Got the truck off-road today on a trail up in Santiago canyon. Trail is pretty slow 1st and second gear as it’s pretty rocky and dirt bikes on the trail kicking it everywhere. Impressions is the front end is completely transformed. A lot better articulation running tires through uneven ruts. The rear honestly unloaded was still pretty bouncy considering stock leaf springs but did articulate well when I was going slow enough. I think the rear will show it’s advantages on flatter dirt roads with washboard.
  18. Feb 11, 2018 at 7:13 PM
    #1018
    indevo
    indevo Well-Known Member
    2019 T4R Pro
    What are your On-Road impressions? Sway, dip, shake, twerk, etc?
  19. Feb 11, 2018 at 7:19 PM
    #1019
    Timmcc02
    Tim
    2017 TRD OR
    So to get to this trail you take a pretty fun windy road and it definitely corners flatter. I feel like the nose dive when braking is similar to the stock offroad suspension. My only complaint is when the bed is unloaded the rear end is still a little bouncy
    DavesTaco68 and indevo[QUOTED] like this.
  20. Feb 11, 2018 at 8:13 PM
    #1020
    indevo
    2019 T4R Pro
    Thank you for explaining
